F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 335i Oil temp
Studio RSR
      05-06-2024, 10:31 PM   #1
rchklk
Drives: BMW 335i f30
2013 BMW 335i  [0.00]
F30 335i Oil temp
Can anyone help?
I have a 2013 BMW 335i F30 N55
And my oil temp gauge doesn’t read
Even in the secret menu it just shows -48C
It does read coolant temp but not oil
The gauge work when you do the system test
I changed the oil temp sensor and it didn’t do anything, the car seems to overheat my assumption is because oil temp doesn’t read so the car doesn’t know when to cool down itself
Is there anymore temp sensors I could replace ?
      05-07-2024, 07:39 AM   #2
Wires
1665
Drives: 2016 340i xDrive
Is it showing any codes? That looks like a sensor disconnected issue.
      05-07-2024, 10:02 AM   #3
rchklk
I have replaced the sensor that’s under the oil filter housing cap but that didnt do anything and no no codes with normal code readers. I’m waiting for my protool app, waiting for the Bluetooth connector to come in
      05-07-2024, 12:42 PM   #4
rchklk
is there any more locations for oil temp sensors on n55? besides the one in the oil filter housing ?
      05-08-2024, 06:50 AM   #5
zinner
zinner's Avatar
561
Drives: `17 X5 35d/`15 335i/`18 M550IX
Go to Realoem.com and put in your VIN, search for part "Temperature sensor coolant / oil" There is a sensor in the block and in the head. It will show you the locations.
Wires1664.50
      05-09-2024, 08:41 PM   #6
rchklk
These are the codes I’m getting
      05-11-2024, 09:05 AM   #7
F32Fleet
F32Fleet's Avatar
3637
Drives: 2015 435i
Check the connector for oil and give it a good cleaning with electrical contact cleaner.
If you see oil you may want to check the connector to the DME for oil.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      05-13-2024, 06:34 AM   #8
Revoltos
Revoltos's Avatar
53
Drives: BMW F30 335i
The N55 oil temp sensor is on the block under the inlet manifold, but it is down low on the block. You will probably have to remove the boost pipe and depending on your dexterity, you may need to loosen off the inlet manifold to access it. The sensors around the oil filter cap are oil pressure and coolant temp.
      05-13-2024, 10:40 AM   #9
rchklk
Found the issue. It was an issue with the oil temp sensor on the block under the intake manifold however … sensor wasn’t the issue, the wiring was.. seems like it was a rats nest and the wires are chewed up. Need to re solder the wires ..
Wires1664.50
      05-13-2024, 02:35 PM   #10
Wires
1665
Good find!
      05-16-2024, 10:22 AM   #11
rchklk
After fixing the wires .. these are the codes I’m getting and the car cranks but doesn’t start
f30post
