BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Turbo sound increase
      04-04-2024, 05:43 PM   #1
Florian80995
Drives: BMW 335i
Hello,
I got a stock 335 e93 n55, and I’m wondering how I can increase the sound of the turbo. I’m not really into tuning and the 306ps are enough for me, but I love the sound of the turbo. So can someone please tell me what options I have. Thank you!
      04-04-2024, 09:05 PM   #2
TheGoodTheBadTheUgly
258
Drives: 2011 E90 335i xDrive
Originally Posted by Florian80995 View Post
Hello,
Never really heard the compressor noise on the stock car so I am not quite sure what noise you are referring to.
If you want to increase the air intake whooshing sound then a cold air intake that is not enclosed in a box like the stock design would work. I would also do a half cowl delete and put the BMS cowl filters rather than the stock solution. I would still leave the lower part of the cowl to keep this environment protective barrier.
With my catless downpipe, you can definitely hear the turbine impeller spoon as you rev but that would require some coding/tuning to code out the check engine light and is quite a job to do.
TOTALED | 2011 E90 335i xDrive - BMS Cold Air Intake - ETS Charge Pipe - ETS 7" FMIC - MHD Stage 2+ - GFB DV+ - PE Mod - VRSF Catless Downpipe - xDelete - xHP Stage 3
2015 E84 X1 35i M-Sport
      04-06-2024, 07:20 PM   #3
Xalithar
12
Drives: BMW E90 335I X-drive (2011)
2011 BMW 335i  [0.00]
I have an HPS intake with a VRSF turbo inlet. The turbo is much more vocal. I also have it coupled with a VRSF catless downpipe and Cobb exhaust. The sound together it paired very nicely and are complementary.
      04-16-2024, 11:35 AM   #4
Hauteknits
11
Drives: 335i E93 N55 6MT
I use the BMS intake and a cowl delete. Great turbo noise. You can also remove the seal from the cowl if you don't want to delete the cowl but BMS filters are $50 and they're oiled filters
