Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Vrsf turbo inlet
      03-31-2024, 03:23 PM   #1
alddiem415
40
Drives: 2011 335i xdrive
Vrsf turbo inlet
Bought a vrsf turbo inlet from ecstuning for my 2011 e90 n55.
Any special way to install it? It will not go all the way in. I’ll go through the first Oring but not the 2nd oring. Should i return it and get a replacement?
      03-31-2024, 05:18 PM   #2
sleeeper90
Drives: e92 335i
Did you lubricate o rings? they are very small and tear easily if not lubed. Mine was a tight fit but didnt have any issues not fitting
      03-31-2024, 05:41 PM   #3
alddiem415
40
Yes i did.
      03-31-2024, 10:23 PM   #4
alddiem415
40
Does it need to be in a certain way/angle? Oring is about to break.
      04-01-2024, 11:11 AM   #5
alddiem415
40
Both orings are broken!
      04-01-2024, 09:19 PM   #6
sleeeper90
Drives: e92 335i
They are very fragile!! Sorry about your luck! I lined mine up with housing and tab that mounts to block and was able to press it straight in, no angle! I know its tight down there but gotta be careful with the orings
      04-02-2024, 09:46 AM   #7
alddiem415
40
I end up returning the inlet back to ecs. Ordered one through VRSF. Hopefully i get lucky on that. But i did notice something though. I feel like even if it goes in smoothly, i feel like it wont align with my injen intake.
      04-02-2024, 09:13 PM   #8
sleeeper90
Drives: e92 335i
Still might run in to the same issue, I would just double check the turbo itself is clean and be sure to lube the o rings, make sure its line up properly and go slow. As far as fitment with your intake goes I'm unsure about it, if it fit with the stock inlet it should fit with the vrsf one I would think.
      04-03-2024, 09:44 AM   #9
alddiem415
40
Hey,
Did u use the stock inlet screw & rubber when u install the vrsf?
      04-03-2024, 01:04 PM   #10
wheela
wheela's Avatar
298
Drives: 2015 BMW X1 35i M-sport
I tried the vrsf inlet. It was a bear to get in, but once I did the screw hole didn't line up with the block. I pulled the inlet back off to open up the hole a bit, and saw the o-rings had failed. Since I had no way to confirm if new o-rings would survive installation, other than pulling it back off, and then risking damage again on reinstallation (short of looking at fuel trims), I decided not to run it and just went back to the stock inlet.
Appreciate 2
      04-03-2024, 09:28 PM   #11
sleeeper90
Drives: e92 335i
I had to slot my mounting hole to get it to bolt up too-
Yes, stock hardware.
      04-04-2024, 01:32 AM   #12
alddiem415
40
Did you use the rubber gourmet from the stock inlet?
      04-04-2024, 09:17 PM   #13
sleeeper90
Drives: e92 335i
I think I did, I had stock intake w/ inlet
      04-26-2024, 03:30 PM   #14
blackwood
42
Drives: BMW 335i xDrive e92 6MT 2012
2012 335ix  [10.00]
Did you ever get this installed?
Just received mine and tried to install and it wouldn't go all the way in, and the 10mm that attaches it to the block wasn't fitting flush so I emailed Hugo at VRSF and he let me know that if you're using the stock turbo, it won't sit flush, just get it past the 2nd o-ring. He also said they usually include washers to help the 10mm sit flush, but I didn't get any washers in my package. Still trying to get it to fit.
      04-27-2024, 10:14 AM   #15
alddiem415
40
I returned it. I bought from kyle at midnight motorsports. No issue at all.
Midnight motorsports supply the inlet for shuenk
Appreciate 3
      04-29-2024, 06:57 AM   #16
blackwood
42
2012 335ix  [10.00]
Just asked for info about returning my inlet and the reply I got from Hugo was, "The inlet fits fine. I've installed about a dozen of these without issue. It takes a bit of finesse to get it on there. "
Not very helpful. . .
      04-29-2024, 08:13 AM   #17
wheela
wheela's Avatar
298
There is going to be variation between parts, and some may fit well, but mine certainly didn't. I could have made it fit better with modification, but it still wouldn't have fit great, and you shouldn't have to modify a part purpose-built for a drop-in fit.
