04-10-2024, 11:52 AM | #177 | |
4789
Rep 2,546
I've completed your entry but had to place it in the 'Weights Not Available' section (I'm still missing just your front wheel wt). Vividracing has the rear wheel wt on their website and the Atturo website does a great job sharing their tire wts. If you can just ask your Vendor or Brixton I'm sure they can get you the front wheel wt immediately as these appear to be a standard size they produce, and then I'll move your entry up to the 'Known' list. Also, I'm guessing the wheel finish was 'Satin Black', as that appears to be the finish for many of the packages different sites put together? |
04-10-2024, 12:10 PM | #178 | |
33
Rep 113
Wheel finish is satin black. I did some digging and on vivid racing I find that wheel weight to be 34.8 lb! Vivid Racing Wheel link |
Max Well4788.50 |
04-10-2024, 12:20 PM | #179 | |
4789
Rep 2,546
04-10-2024, 01:41 PM | #180 |
33
Rep 113
My thoughts as well.. Lol. Yes i will email them
04-12-2024, 07:28 AM | #182 |
4789
Rep 2,546
brandonloos_2132.50 |
04-22-2024, 04:14 PM | #183 |
4789
Rep 2,546
Adding a great-looking combination from Rottweiler which he shared over in the G01/02 sub-Forum. I produced a data entry as we would have in our list, but I don't want to mix the F97/98-G01/02 series in case subtle fitment differences might confuse as to what will and will not definitely fit in these respective models.
Rottweiler : Total G01/02 for HRE RC104 in ‘Gloss Charcoal’ (21x9.5 ET20, 21x11 ET35)/Pirelli P Zero (265/40 R21, 305/35 R21) - 217 lbs https://x3.xbimmers.com/forums/showp...&postcount=908 ] and PM from Rottweiler 22 Apr 2024, 305PM sharing the individual wts. {Ft wheel/tire: 52.3 lbs, Rear wheel/tire: 55.95 lbs}{Separate wts - Ft wheel: 23.3 lbs, Ft tire: 29 lbs, Rear wheel: 23.95 lbs, Rear Tire: 32 lbs} |
04-22-2024, 04:20 PM | #184 | |
Captain (Retired)
4027
Rep 1,763
04-23-2024, 02:02 PM | #186 | |
4789
Rep 2,546
Also, if you can share the finish color, and ideally at least one picture that’d be great. I’ll bet it looks fantastic (and has a pretty low total wt)! |
04-29-2024, 10:48 PM | #187 |
Rep 1
How do you guys find the difference (comfort, spirited driving etc.) after changing to significantly lighter wheels?
Feeling is usually subjective, so unless the difference is measured in some way, it would be helpful it could express the difference in percentages. It's probably a weird ask but I find it to be quite helpful when others comments that the ride comfort/quality improved by approximately 20-25% for example. I am currently running 765M R21 with RFT Alenza 001. I do quite like the looks of these wheels, however as I am planning to change the tires to PS4S or ECS02. I've been wondering if I should also change the wheels to R20 while at it and drop some extra weight, primarily improve the ride quality. I've been eyeing Braelin BR10 or Superspeed RF07, which would drop about 20 lbs per corner (total weight including tires). Another option I'm considering is to just keep the 765M R21 and just put the PS4S or ECS02 on them and not bother with the smaller or lighter wheels. |
04-30-2024, 05:58 AM | #188 | |
4789
Rep 2,546
I understand your desire for objective percentages for a subjective impression, but even those become subjective making an exact number difficult to translate to others. Just look at how some of us feel the F97/98 suspension is fine, while others say it's too firm... Personally, when I reduced unsprung wt by 44 pounds with my BC Forged wheels, I have definitely (subjectively) noted a significant improvement in handling. And objectively I ran my fastest time at the Strip with them. Way too many variables going on at a Strip (DA, tire pressure, fuel, gross wt, track prep, ...), but did want to share that. It might be helpful for you to pose this question over in the G01/02 sub-forum as they'll have more experience with your series. Rottweiler in particular has a special interest in this and extensive experience with lighter wheels in his G02 X4 M40i. That sub-forum can be found at: https://x3.xbimmers.com/forums/forumdisplay.php?f=666 |
Rottweiler4027.00 |
05-02-2024, 01:44 PM | #189 |
255
Rep 173
What's up comrades:
Rays Volk G025 20x9.5 +15 front with a 275/40/20 Nitto NT555 G2 - 55.3lbs inflated 20x10.5 +20 rear with a 295/40/20 Nitto NT555 G2 - 59.1lbs inflated Total: 228.8lbs I didn't get wheel and tire weights separately as they were already mounted when I got to the shop. I can't find wheel weights online for these wheels, plus on the Rays website they're not even showing these sizes anymore. They may be discontinued. Lemme know if anyone wants more pics of anything specific. |
05-02-2024, 07:59 PM | #190 | |
4789
Rep 2,546
The only detail needed is the wheel finish. I checked the Volk site but didn't want to guess which you chose. I'll add your entry in a sec but will edit once I know the finish. Thanks again. |
05-02-2024, 08:29 PM | #191 | |
255
Rep 173
Max Well4788.50 |
05-06-2024, 09:54 AM | #192 |
2043
Rep 999
These look awesome!! I almost did G025 before my Advans. Killer setup!
05-07-2024, 04:31 PM | #193 | |
255
Rep 173
Thanks man. Your advan set up helped me pick my sizing! I'm very happy with it so far. And because the stock set up with 15mm spacers naturally clearanced the rear fenders a bit this set up doesn't rub at all, surprisingly. I think it looks tougher with 20s and a meaty tire. |
Today, 01:54 AM | #194 | |
Rep 1
Could you give me some adviсe? I want to use square setup on my X3M LCI with Rays GT090 R20 9,5J +15 inset, would it be too aggressive? Thank you! |
Today, 06:10 AM | #195 | |
4789
Rep 2,546
Alot of Members have far more experience with fitment than I, so hopefully some of them will chime in and assist answering your question. In particular, BrockDM is running a near identical square wheel spec (offset different by only +3), and his post describing it is here - https://x3.xbimmers.com/forums/showp...&postcount=135 . |
