06-12-2016, 06:24 AM | #1 |
103
Rep 999
DIY: CAE shifter install
So I want to start off by saying that it was easier to install my ESS supercharger kit than this beautifully built shifter, mostly because I had to do everything by myself. I am by no means an expert or certified in any way. DO THIS AT YOUR OWN RISK. I AM NOT RESPONSIBLE FOR EXTRA PARTS, BROKEN PARTS, OR BROKEN FEELINGS.
I love learning so I decided to knock this out solo, and share my experience with you guys. The lack of DIYs for this install was what stopped me from purchasing one of these a long time ago. I finally took the plunge and I couldn't be happier. I am also installing a DSSR instead of the OEM linkage, I didn't test it but I'm positive the OEM linkage will fit. The "Before" :thumbdown HERE WE GO Big BIG thanks to: wrh3 his DIY for a UUC SSK helped me a lot to get down to the shifter carrier. Link to his DIY http://www.billswebspace.com/M3UUCEvo3DIY.htm You can follow majority of his steps all the way until he takes apart the shifter from the shifter carrier. He used two screwdrivers, spinning the locking mechanism clockwise. BUTTT remove your exhaust and heat shields, you are going to want all the space to do this. All the foam and rubber shift boots will be discarded. You will also need to trim the foam that is in the car, and cut some of the plastic off. I used a cordless dremel to do the cutting and sanding. I'll show what I did in later posts. For this install you will have to remove the center console cover (the instructions call for the removal of the whole center console but I couldn't find a DIY, and couldn't figure it out, so I left it on. Which to me it turned out for the better because it eliminated the guessing when it came to the cutting and trimming. The cover is held on by a few pressure clips so it just pulls straight up with some pressure. I started from the front and moved back. There's also two bolts I decided to remove that holds the center console down. it gives a little bit of extra "leg room" to work with. Back to the bottom of the car; first you have to support the transmission with a transmission jack if you have one. I didn't, so I used a piece of wood with my regular jack. Once supported you will need to remove the transmission cross member and exhaust hanger that is bolted to the transmission with torx bolts. Transmission cross member Two bolts on the right bolted to the frame Two bolts on the left bolted to the frame One nut on each side bolted to the transmission itself. At this point I recommended replacing your transmission mounts, the cross member is out and it's the easiest at this point to replace them. I did not know I was going to be in this deep and it didn't cross my mind... and again there is no DIYs for it... NOT perfect but I'll be the guinea pig for us all. Once the cross member has been taken out, next you want to remove the exhaust hanger that is bolted to the transmission, you want to do this purely to have more space to work with. Removing the two clips there's a locking mechanism. I slid a small flat tip screw driver in the flat spot on the side of them and then they swing up once unlocked. Next removing the carrier from rubber grommet (back) and two pins (front). once you remove the two pins you have to release pressure on the jack, and let the transmission go down. The carrier can only go up over the transmission and then slide down on either side of it. you will have to push up on the carrier and pull down a bit on the transmission at the same time to make it slide out, it didn't take much. How it will look like from the bottom and top with the carrier removed. Initial mock up of how it will look.... still more to go after this point. Now it's time for the part where most people start second guessing this purchase. I for one plan on keeping this car till it can't drive anymore, and even then I'll rebuild. So cutting and drilling wasn't an issue for me. This pic is so you guys can get a basic idea of the cutting and trimming that needs to be done. This is what it looked like after it was all said in done. I had to cut and mock it up a few times till I found a perfect position for the shifter. It doesn't look pretty but that is fine there is a plate provided by CAE that will cover this all up. The plate mentioned above. Bottom Top Almost done... Next it's the drilling of four holes to bolt the shifter down. Like I said its not pretty... I messed up the first set of holes. Again the plate covers this all up. Exhibit A :confused2 So once you drilled the four holes IN THE RIGHT PLACE Bolt the shifter down. Hardware is provided you can use either nuts and washers, or a bar the comes with threads welded on. I used the bar on one side and nuts on the other. At this point you have to do a few things; connect the DSSR to the transmission and then shifter, or OEM rod if you didn't upgrade, then bolt the transmission cross member back on (There's other steps you have to follow provided by CAE) One of those steps is attaching the little dust boot provided by them.. which actually is a lot harder than it seems... I have big hands so it took me a while to figure it out. I used a small pry bar to hold one side down while I pulled as much as I could on the other side, working it little by little all the way around. Once that lil F!@#!# is done you're on the home stretch!!!!! :party0030::party0030::bow: Here it is all bolted down where it's supposed to be. Next and third to final step, trimming of the center console cover... you will have to remove your ash tray (mine) or any other accessory you may have in that upper spot. To mark it: place it where it supposed to be see where it hits the shifter and cut that piece... All done in this picture. And cover reinstalled Second to final step: is trimming the shift boot, I'm using the OEM one for now till I can have something custom made for the boot and the front part where the accessory was. FINAL STEP!!!! is fine tuning the shifter. Step by step on how to tune the shifter are provided. :confused0068::thumsup::cool!::clap::thumbsup::hap pyanim: BBBUUTTT BEFORE YOU GO DRIVING heat shields need to be bolted back on, exhaust mounted back on with its hangers, do one more check everything is tight! and finally lower the car and then go drive it like you stole it! Thanks for looking. If anybody has any questions I'll answer them at the best of my ability! I made a few short video clips for Instagram check them out @luis.1sl0m3 :party0030::party0030:
Performance ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe Looks M colors grill - CF trunk - Sapphire Blue Forgestars F14 |
06-12-2016, 01:44 PM | #2 |
coupe la goon
373
Rep 1,644
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
Awesome, awesome work! When I had my 6MT I dreamed of installing one of these shifters. Since you've incorporated the factory boot, I might suggest that you roll the top portion under, use a low-profile zip-tie and you can eliminate the raw edge of the boot showing on the shift selector.
06-12-2016, 01:48 PM | #3 | |
103
Rep 999
And believe or not I actually tried that method buy it kept sliding off so I left it off for now. I want to get a tri stitch cover and a CF plate on the front eventually so not to worried on how it looks now.
04-17-2017, 10:25 AM | #4 |
11
Rep 81
Hey guys anyone have experience with this one ?
http://www.billswebspace.com/M3UUCEvo3DIY.htm the uucevo3 shifter it looks to be easier to install then tha CAE |
04-19-2017, 07:03 AM | #5 |
5257
Rep 10,629
UUC and Auto Solutions and Rogue and other stock design aftermarket replacement shifters are very different from the CAE, Samsona, RTK and other bolt in spring loaded shifters. The bolt in shifters work best with stiffer engine and trans mounts since there are no longer rubber bushings locating the shifter that can move a little as the motor and trans move a little.
People love the CAE, Samsona, RTK and similar bolt in spring loaded shifters on the track. For purely street driving, they get mixed reviews. You can buy an extension for a stock style shifter for more leverage. You can also make a stock style shifter perform better under load by using solid or very stiff motor and trans mounts, but very stiff trans and motor mounts make these cars miserable to street drive due to the vibration. |
msan404.00 |
04-19-2017, 12:02 PM | #6 |
40
Rep 85
Hi, great write up, I'll be sure to use this when I install my CAE. Quick question though, which DSSR did you install?
Cheers
Instagram - @pistonheed
Team Schirmer M3 CSL Last edited by Pistonheed; 04-20-2017 at 06:34 AM.. |
05-07-2017, 10:32 PM | #8 |
11586
Rep 12,728
how do these work with a 6mt? what exactly does it do? i'm completely ignorant to these things. sure, its faster, but how does it work?
Instagram; @roastbeefmike
05-08-2017, 12:03 PM | #9 |
141
Rep 980
I have one as well, it completely eliminates slop, throws are very short and the shifter handle location is literally at steering wheel height and super close, so you don't have to find the lever when gear change comes up, rather just move your right hand slightly right and shift.
Mods: too many the list wont fit in the sig page. PM me
Tesla Referral code: http://ts.la/juliana77782 |
05-08-2017, 02:13 PM | #10 |
122
Rep 451
Drives: 09'M3, 16'M3, 11'550i, 17'X5
Great install Luis! I did this on my DCT and i can shift way faster now!
2009 Grigio Telesto M3 DCT. ESS 700, BPM Tuned, GTS Tune w/ Euro MDM, Catless custom exhaust, TE37SL/Rays G07EX, Amuse Ericsson Bumper, CSL Carbon Trunk
2016 M3. JB4, VRSF Downpipes, Custom exhaust, Cornfed 2011 550i. Dinan Stage 3, JB4 Piggyback, Catless Downpipes, Custom Exhaust 2017 X5 35i. STOCK, boring, and sold! |
CIFUM3102.50 |
11-20-2017, 02:05 PM | #11 |
Rep 56
CIFUM3 do you still have this collection of pictures anywhere? if so could I possibly get a copy of them? Photobucket has ruined so many good posts like this one. Thanks
SYT_Shadow11498.50 |
11-20-2017, 02:14 PM | #12 | |
2434
Rep 11,668
it was difficult as the shifter had to be modified to install 180° from the way it normally goes.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
11-21-2017, 09:16 AM | #13 | |
///M Powered for Life
11499
Rep 10,332
It's incredible how much damage a single company has made. |
11-21-2017, 12:04 PM | #14 |
Rep 56
it really is incredible how many great sites they have ruined... It was the worst thing they could have done as a business in terms of customer relations but I guess they are making more money now. But back on topic, thank you inTgr8r for your DIY. Hopefully CIFUM3 might still have the pics but if not your DIY is a fantastic resource.
11-21-2017, 12:51 PM | #15 | |
11499
Rep 10,332
There is no way a DIY guy who is not getting paid will pay $400/year to host their pics. It's just impossible. No one wants to help others THAT badly How could no one at Photobucket think that they should limit the $30/year plan to, say, 500 pics? Friggin dumbasses
inTgr8r2433.50 |
11-21-2017, 02:17 PM | #16 |
2434
Rep 11,668
^WHS!!!!!
They PO'd a LOT of people
12-06-2017, 10:45 AM | #17 | ||||
103
Rep 999
12-06-2017, 11:52 AM | #18 | |
2434
Rep 11,668
There are add-ins that bring the pics back. I've been adding this to the top of all my DIY threads. "If you're using Google Chrome, go to the three dots on the right side of the screen and click them. A drop down should appear. Hover your mouse over "More Tools," and when the next drop down appears, click on extensions. Go to the link towards the bottom that says "Get more extensions." In the search box, type "Photobucket Fix," and hit enter. Click the install button and once it's done, you should be able to see photobucket pictures again. For FireFox users, click on the three bars on the right side of the screen, then click on add ons. Click search for "photobucket hotlink" and click install. Same result."
12-07-2017, 03:21 PM | #19 |
62
Rep 531
I'll be looking to try an RTD shifter when spring comes around, on a different car though. That may be a similar solution that doesn't require cutting the center console to fit.
!!! Completely off-topic, but stumbled here and didn't know this existed. The plugin is available and works for Opera as well. |
12-07-2017, 06:58 PM | #20 | |
Dom
1080
Rep 1,718
01-07-2018, 07:46 PM | #21 |
Rep 56
CIFUM3 thank you for your response! Your guide even without pictures was incredibly helpful and made my install very easy! I just saw inTgr8r post and it fixed it so now I can see your pictures anyways!
01-07-2018, 09:14 PM | #22 | |
40
Rep 85
Sorted the pictures for those that can't use the Photobucket fix on their browser.
Team Schirmer M3 CSL |
