01-19-2010, 12:30 AM | #1 |
49
Rep 807
JL Audio HD 600/4 Question...
So far I have a Audison BitOne, 2 Earthquake SWS-8's and a Kicker L7 Sub 12" I wanted to know if to start off would that combination be okay to put on the JL Amp? I know I would need another one of those amps for the 4 focal components but I wouldnt sure if the kicker would be too much to put with the 2 earthquakes. Thanks
01-19-2010, 04:20 AM | #2 |
8 tracks of madness
62
Rep 2,735
You're wasting your time with the SWSs if you're running an L7. You want a midbass driver to complement the sub, not another pair of subs. You're also grossly underpowering the L7 with only 300 Watts.
01-19-2010, 07:22 AM | #3 |
49
Rep 807
im not underpowering the L7 I had it on my previous car with a rockford t1000.1 but I dont see the necesity of having so much bass with the earthquakes... but do you suggest anything else?
01-19-2010, 10:13 AM | #4 | |
8 tracks of madness
62
Rep 2,735
You are correct, if you're running the SWSs as subs you don't need much, if anything from the L7. But you're also going to have a gap between where the SWSs drop off and the 4s in the doors pick up which is another good reason to run a real midbass instead of the SWSs. If you want to keep the L7s and have something that plays the bottom ocatave with much more authority then I'd do something like a single 15. What kind of music do you listen to and how loud do you listen to it? And be honest. |
01-19-2010, 04:32 PM | #5 | |
49
Rep 807
01-19-2010, 06:19 PM | #6 | |
221
Rep 2,339
You're still left with the problem of how you're going to use the SWS and L7 together and make it sound good. Like others have said, the SWS is meant to be a subwoofer and not so much a midbass. So you'll have to get your Focals to play really low or you'll end up with a gap between those and the SWS. If you weren't going to use the L7 and just use the SWS as your subs, you probably have an easier time making it work.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
01-19-2010, 06:45 PM | #7 |
2307
Rep 13,013
What model of Focals are you getting?
If you are getting the bit one then use it to get the best mid bass that you can between the 4" and the SWS-8. You will have plenty of tuning capabilities there... |
01-20-2010, 12:30 AM | #8 |
49
Rep 807
I already own the BitOne, SWS-8's and the L7. The L7 was previously installed in my previous vehicle so thats why I still have it along with my Rockford T1000.1 amp.
So you would recommend running the 4 focal K2 powers with 1 JL Audio HD 600/4? And the SWS's and L7 would need 2 seperate amps then? Im looking for clear/crisp sound with nice bass. so give me your input before I go buy this amp lol thanks |
01-20-2010, 05:59 AM | #12 |
49
Rep 807
I do but they are 2 ohm both of them and Im just asking to see what or which is better. Im still confused on what amp to get. Im pretty sure the JL is fine for the 4 focals but for the sws's im not sure what to do since I also have the L7 and I dont want to have 3 amps...
01-20-2010, 07:22 AM | #13 |
8 tracks of madness
62
Rep 2,735
Neither is "better" they're just different. They just let you tailor the load to whatever amp you want to use. ince you have 2 Ohm SWSs just use a 2-channel amp that makes the power you need at 2 Ohms per channel. You could to 4 Ohms mono on a bridged 2-channel amp as well but I wouldn't just because it won't get you anything extra and it'll work the amp harder.
How about a 600/4 and a 900/5 or two 900/5s? You'd have an unused sub channel with 2 900/5s (or have to level match them at least) but either way you have plenty of channels and more than enough power. I'm debating what amps to use but I want a TON of power. |
01-20-2010, 11:38 AM | #14 | |
221
Rep 2,339
01-20-2010, 07:09 PM | #16 |
49
Rep 807
Well I want to do front, rear, and trunk sub but I also want the sws's. How many amps can a bitone run anyways? I bought it about 6 months ago and have yet to even use it
01-20-2010, 07:37 PM | #17 | |
221
Rep 2,339
You could also do a semi-active front like quality sound said. I don't know exactly which way he's doing it but I would assume its going to be mid and tweeter in the door with the tweeter being passively crossed over, the mid is sent a high pass signal from the BitOne through whatever amp its hooked up to. Then the midbasses, rears, and sub under the seat would get their own dedicated output channels from the BitOne. You could also instead of sharing BitOne channels with the mid and tweeter, share between the mid and rear. The only thing bad about that is that you lose the ability to control the volume of the rear with respect to the mids unless you install an external volume control like an L-pad. I did this in my last car and it worked pretty good. I'd probably do it the last way since I've done it before and I'd rather have independent control of the mid and tweeter rather than having control of the rears from the BitOne. That and the sound coming from the rears would be mids only which is actually kind of nice for ambient sound. The rear passengers can just suck it because I don't really care about them.
01-20-2010, 11:51 PM | #18 |
49
Rep 807
how about a JL Audio HD900/5 I guess for the focals and the L7 and a HD 600/4 for the 2 SWS's? Is there any other amp options possible? I wanted the 600/4 for the focals but Im not sure how to fit the L7 in giving it the sufficient power it needs
01-21-2010, 12:22 AM | #20 | ||
8 tracks of madness
62
Rep 2,735
What do you mean? |
01-21-2010, 01:35 AM | #21 | |
49
Rep 807
01-21-2010, 01:43 AM | #22 | |
221
Rep 2,339
You could even do it another way to keep it all active but it gets way complicated. You could use 2 channels of the BitOne to high pass the signal where you want to high pass the mid and the rears. Then you send that signal to a 4 channel amp with a built in x-over like a 600/4 or something smaller. Then you use the amp's x-over to low pass the signal for 2 channels on the mids effectively making the signal bandpass and then you use the other 2 amp channels with no filtering from the amp to let the rears play all the way up. Possible but way to complicated because you end up with controls at the BitOne and at the amp that you need to worry about.
