F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Fixing Carly coding mess
proTUNING Freaks
      10-19-2023, 02:58 PM   #1
lonewolf1870
lonewolf1870's Avatar
Drives: 420d GC
Hi all,
so, yesterday I had my first coding expericne on an F30 using Carly.
I successfully coded the M logo on both the iDrive and on the cluster / KOMBI.
Then I decided to revert to the original setup: while this was sucessful for the iDrive system, Carly failed to code the KOMBI and since then it's a real mess: dials are not working, multiple error messages related to hardware I don't have (e.g. the roof is not closed, but I have no roof) - also the logo of the car is not the F30: it looks like a 1 series.
I tried to disconnect the battery for 10-15 min as suggested, but the problems persist.
To my understanding, the next step is to reset to factory settings via E-SYS by selecting the Kombi module and click on "Code". Can anybody confirm?
By the way, I actually have the "extended" cluster display: in this case, is it KOMBI or DKOMBI?
Thanks!
      10-21-2023, 03:03 PM   #2
lonewolf1870
Drives: 420d GC
Well, I solved following Carly's tips. Basically:
1. disconnecting the battery for 15 min
2. re-run Carly diagnostic and delete all errors
3. switch-off the car and wait other 15 minutes
4. set Carly connection speed to slow
5. re-code the affected ECU using a previous back-up
The errors where all there until the last step. I have the feeling that the speed config made the trick, but I'm not sure.
Hope this is useful info should anybody else have similar issues with Carly.
      10-23-2023, 07:19 AM   #3
samjavid
samjavid's Avatar
No_Country
Drives: 116i 2018 f20
2018 bmw 116i b38  [0.00]
bmw  [0.00]
Hello,
I coded the same thing as you in my f20 1 series 2018, unfortunately i got a black screen after a error popped up with coding something in i drive.
Now the idrive is dead and does nothing anymore, reflashing the backup is also giving a error.
Do you think it is the best option to now just unplug the battery or is that to risky ?
f30post
