08-24-2022, 01:51 PM | #1 |
Rep 9
Hybrid system isses.
Hi. I just purchased a 2013 BMW active hybrid 3. It drives in gas mode fine. The problem is with the electric part of the car. The previous owner has informed me that the EME has to replace and possible the hybrid battery. However here in the Bahamas, good BMW mechanics are hard to find. I'm pretty handy with tools and have been maintaining my own vehicles for years. I have already gotten quotes on the new EME and battery. However I would use some advice on the best way to have them installed.
08-25-2022, 09:33 AM | #2 |
AH3 Owner
208
Rep 318
Drives: BMW 335i ActiveHybrid 3
You don't describe what the problem is. What are the error codes? To replace a hybrid battery, at least here you need a certificated garage with permissions to do it. What do you mean by 'best way to have them installed'?
So what is the issue? The electric mode never kicks in? If the hybrid battery is completely out, the AH3 wouldn't work at all. |
08-25-2022, 11:03 AM | #3 |
Rep 9
Ill will try to get the codes. But the AC does not work and the car is not charging the hybrid battery. Not sure if the reason its not charging is because the EME is bad or not. The problem is, I'm in the Bahamas and the only local dealer will not work on the car because it was not sold by them. They will only do the diagnostic but will not install or code the what ever parts has to be replaced.
08-25-2022, 11:11 AM | #4 |
Rep 9
The electric mode does not kick in. I've gotten quotes on a new EME and hybrid battery. I'm pretty knowledgeable with cars, how ever I've never dealt with a hybrid. I'm sure I have what ever tools are required. However getting it coded is where I hit a road block. Any idea what scanner is capable of this or maybe someone who can possibly do this remotely?
08-25-2022, 01:04 PM | #5 |
AH3 Owner
208
Rep 318
If the high-voltage hybrid battery is at fault, you should not replace it yourself, this can kill you. In terms of reading codes and whatnot, I recommend installing ISTA on a laptop. Even Bimmerlink for android can tell you a few things.
When have you replaced the batteries in the trunk? Aux and normal? Before guessing more, we'd need to see the error codes to find the issue. |
08-25-2022, 05:06 PM | #7 | |
AH3 Owner
208
Rep 318
https://www.amazon.com/s?k=enet+cabl...f=nb_sb_noss_1 |
11-01-2022, 03:43 AM | #10 |
AH3 Owner
208
Rep 318
11-04-2022, 10:00 AM | #11 |
Rep 9
Question. I got a quote on a new EME, which is more than half the value of the car. I found a few used ones on eBay. Is it possible to replace and code my EME with a used one? I also found a company that claimed to repair them. Thoughts on this?
11-06-2022, 05:44 AM | #12 |
260
Rep 955
these bmw hybrids are somewhat rare.
very doubtful you will get a 100% answer on this question as I doubt there is even anyone on here who has replaced their eme with a used one. some (very few) modules are Vin married, if an eme is one of these is the question. i highly doubt it is... but who knows. if it were me I would try replacing it with a used one without a doubt. that being said, i didn't even zoom into your pić of the module map but none of them were red... are you sure the eme module is not working at all? edit : eme is showing yellow. so it's communicating with the car. all depends on what the codes are... clear them all, see if anything comes back., go from there. |
11-06-2022, 05:54 AM | #13 |
AH3 Owner
208
Rep 318
I've seen someone replace their EME with a used one for under 3000 dollars, and having it working. What error codes are you getting? When was the last time the trunk batteries were changed? 12V and AUX?
11-07-2022, 11:26 AM | #15 |
Rep 9
Well, the car starts and drives, so I didn't bother to change those batteries. The issue is that that car doesn't switch into ECO or hybrid mode and the AC is not working. They were replaced with in the last 18 months.
11-05-2023, 10:46 PM | #16 |
Rep 2
Good evening Everyone
I am new to BimmerPost. I live in the Bahamas and own an ActiveHybrid 3. Bumped into this forum while searching for answers to a similar problem. Mikey242, did you ever get your problem sorted out? Thanks |
11-07-2023, 07:25 PM | #18 |
Rep 2
Starter motor was recently replaced.
Fault codes from BimmerLink: Error Memory Front electronic module 2 errors 8041A8: Welcome Light repeat lock active 804483: RLS (LIN slave): Faulty condensation sensor Electrical machine electronics 6 errors 220581: Emergency run manager: Request to open relay of additional device due to fault in DME 220564: Emergency run manager: EGS forced upshift request (high) due to fault in DME 220515: High-voltage power management: no high-voltage release despite request 220569: Emergency run manager, high-voltage battery: immediate contactor opening. There is a category 7 error (Battery Switch Open Immediately) on the SME. 22056A: Emergency run manager, high-voltage battery: requested contactor opening. There is a category 6 error (commanded contactor opening) on the SME. 220582: High-voltage power management: Request starter generator emergency run from emergency run manager Digital Motor Electronics 6 errors 218404: Starting voltage converter / starter generator, control: line interruption 212601: Starter generator: MSA permanently deactivated 212001: Starter generator, communication: bus error CD8F10: LIN, communication (starter generator): missing 235410: Emergency run manager: Request to increase idle speed from the electric machine control unit 21A110: Engine torque limitation: as a result of the emergency running request from the electric machine emergency running manager control unit Rear electronic module 1 error 8048C1: Rear window heating, relay: line to relay interrupted or short circuit to positive Battery management electronics 8 errors 21F0B0: HVS: CSC function: open line of a cell voltage measurement occurred 21F0C0: HVS: CSC function: plausibility error in cell voltage 21F147: HVS: Cell voltage measurement - one or more cell voltages are invalid 21F157: HVS: plausibility voltage sensors module 6 - voltage implausible 21F18A: Deactivation of the main switch after an error 21F1A1: Safety concept, level 2: high-voltage battery, voltage too low / high or unknown 21F1B2: HVS: Level 2 - shutdown detected 21F1BA: SME: Safety concept - shutdown by level 2 Integrated automatic heating / air conditioning system 2 errors E71431: Message (STAT_FOG_UP_FRONT, 0x2D1, FA): DT_FOG_WDW_FT invalid value E71432: Message (STAT_FOG_UP_FRONT, 0x2D1, FA): DT_TEMP_WDW_FT invalid value Info Memory Central Gateway Module 5 errors 101008: Non-resolvable ambiguous routing - SG not in the SVT target table 100600: Flexray protocol startup time is too high 100104: HW Weckgrund ZGW 100203: DM software error info warning 100204: Message monitoring: no system context signal Front electronic module 2 errors 804029: NVM_QUEUE_EEPROM 93071F: Outgoing error message buffer is full Electrical machine electronics 10 errors 220563: Check control message: drive malfunction. Attention, from SOP 7/12 change to: Check-Control message: Drive drive moderately. 220503: High-voltage power management, electric refrigerant compressor: power reduction 220581: Emergency run manager: Request to open relay of additional device due to fault in DME 220564: Emergency run manager: EGS forced upshift request (high) due to fault in DME 220563: Check control message: drive malfunction. Attention, from SOP 7/12 change to: Check-Control message: Drive drive moderately. 220517: High-voltage power management, high-voltage contact monitoring (High Voltage Interlock Loop): malfunction D7942C: FlexRay, message (Nav-Graph 2 current segment, 252.2.4): missing D7942E: FlexRay, message (Nav-Graph 2 Route Offset, 261.2.4): missing 220563: Check control message: drive malfunction. Attention, from SOP 7/12 change to: Check-Control message: Drive drive moderately. 220503: High-voltage power management, electric refrigerant compressor: power reduction High beam assistance 1 error 5F0000: Info memory: Online calibration initially completed Integrated Chassis Management 5 errors 4827F9: QDM-SKR - correction factor radius - learning condition 2 4827F8: QDM-SKR - Radius correction factor - Learning condition 1 482651: Slip angle estimator - inputs not valid SBS 4827B3: Internal control unit - Undervoltage at Terminal 30 4827A0: SBS function - roll rate - error amplitude due to suspected error Digital Motor Electronics 6 errors 1FB701: Check control message (ID 397): Auto start stop function failed 108932: Intake air temperature sensor: group error 1A2108: Electric fan, self-diagnosis level 1: slight fan fault 20A703: Engine cooling system: component protection Temporary engine power reduction 1FB701: Check control message (ID 397): Auto start stop function failed 1C0401: Engine oil pressure regulation: unstable Roof function center 1 error 801A20: CAN_E_TIMEOUT Rear electronic module 1 error 8049E5: CNM_E_NETWORK_TIMEOUT Battery management electronics 1 error 21F188: Throttling - Reduction of the discharge current limit due to the temperature / SOC limit Electronic transmission control 2 errors 44D4D1: Shift-By-Wire: Info counter for Auto-P when leaving the vehicle 44E532: Hybrid sequence control (HAS): close asynchronous K0 Integrated automatic heating / air conditioning system 3 errors 07800C: CANIF_E_STOPPED 07802B: COMM_E_NET_START_IND_CHANNEL_0 078043: LINIF_E_RESPONSE |
