BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
BPM
      03-04-2013, 08:53 AM   #23
InterJon
Drives: 2011 E92 M3 ZCP
Very straightforward. Thank you for the write-up.
Be careful, I sheered off one of the three 13mm bolts on the strut tower. So, now I will be purchasing a new retainer for $110. Sucks! I had a torque wrench to proper spec; just bad luck. Go at them gently.
      03-04-2013, 09:18 AM   #24
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Nicely done Rich.
      06-09-2013, 11:53 PM   #25
pkimM3r
pkimM3r's Avatar
209
Drives: m3 saloon in granny mode.
Anyone in socal friendly enough to lend a helping hand (and a garage) to do this on my car?
Maybe at a track day? (Preferably not)
My outter tread is bald already lol.
      08-06-2013, 02:36 PM   #26
M3 Esq
Automobilist
M3 Esq's Avatar
395
Drives: E70 X5, 911 GT3
Reviving this thread just to say I successfully pulled the pins over the weekend following this DIY. It was super easy. Thanks Richbot for the write up!
      08-23-2013, 05:52 PM   #27
spr
94
Drives: F80 M3; e92 ESS650+ M3
So I just did this and have EDC. It's quite simple. I did it while I was changed the oil so the car was on ramps with the drivers rear jacked up. Start one side from start to finish at a time and you will have no EDC errors. There is no reason to disconnect the wires!
Start by pulling the cover off the top of the shock- large rubber. Then you will see where the cable gromett goes into that. Pinch and push it back into the body so you can pull the large rubber cover over the wire. Now you see the 3 13mm bolts. remove them. Then remove the bolts on the strut brace. The are a bit tricky to get a socket on. However, if you have a buddy pull the plastic firewall cover back a little you can get straight on with an impact.
Now the fun part. You have to pivot the top strut mount over the three bolts while dipping the bolts on the opposite end. If you do it in the correct twisting motion while pulling up on the silver strut brace to give clearance it will come off. Then just twist out of the way to get at the allen head. Remove the alignment pin with the allen.
Then take a prybar and push against the sheetmetal and the top strut washer being careful to not nick the rubber. You want to go towards the engine. with a little fudging it will just move all at once. Now you're done. Reassemble pivoting the strut brace moutn back then use blue locktite on all threads. Viola .5+ negative camber. I have no EDC errors. Stoked!
      12-01-2013, 11:40 PM   #28
W Cole
145
Drives: 2009 M3
Just did this this weekend. Very easy. Both of my pins came out with an allen key.
If you are worried about stripping the pins and you want to reuse I would jack up the entire front of the car and drop the strut out of the chassis as with the strut in the car there is some side load on the strut which causes friction when removing the pin.
Also, I didn't bounce or move the car around before putting back together. I didn't really understand this step as I don't see why it matters to bounce the car, etc before the top hats are bolted back up vs. after during the first drive?
      12-02-2013, 07:32 PM   #29
longuyen88
Drives: Non-BMW
I did this during my H&R race springs install along with e36 bumps. Final alignment camber is -1.6 and -1.9 lowered on the front.
      03-10-2014, 02:27 PM   #30
AndrewLakes
Custom User Title
AndrewLakes's Avatar
16
Drives: E90 335i
Is there a reason no one is filing/grinding the strut tower camber slots further to elongate them for just the cost of some touch up paint?
Unless there is something in the way underneath, or the hat wouldn't seat correctly, I don't think it would weaken it too much.
      03-22-2014, 08:36 PM   #31
Kunman
26
Drives: m3
what is the torque value for the 8mm bolts?? and what tools should I use to torque it? Cant use my torque wrench, there is not enough room.
holy foook, the black brace circle took me 2 hours to remove.
what does it mean "to bounce the suspension?"
      03-23-2014, 10:09 AM   #32
adc
2762
Drives: 2018 F80 M3 ED
I just use an 8 mm socket on top of a handle (looks like a screwdriver handle). I torque it by hand to a low reasonable tightness.
Before tightening the 3 brace lugs, you push the car forwards or backwards a few yards, while your buddy energetically rocks that corner. This ensures none of the parts stick or bind together due to some residual tension.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      03-23-2014, 10:13 AM   #33
adc
2762
Yes, it's called a camber plate. I bought a BNIB GC from a forum member for $300 and it allowed my alignment shop to do the settings I wanted to perfection.
I experimented with almost 3 degrees and did not like it for street driving (not sure I even knew how to take advantage of it on track), so now I'm around 2.2 if not mistaken.
And the old OEM plates are ready to go back on in 30 min per side if i want to.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      03-23-2014, 12:30 PM   #34
Kunman
26
Drives: m3
thank you
Just finished. I would recommend to anyone thinking of upgrading their suspension parts to try this mod first. The steering feedback has improved tremendously, and its free!!
      04-27-2014, 02:20 AM   #35
Exclusivs
Exclusivs's Avatar
543
Drives: E92 M3
Quick question:
Is this process reversible? and, if you decide to do camber plates down the line because this doesn't achieve camber you want, do the pins need to be re-installed before the camber plates.
      04-27-2014, 06:55 AM   #36
adc
2762
Originally Posted by Exclusivs View Post
Quick question:
It is reversible only if you are very careful when removing the aluminum pins, and don't damage their threads.
The good news is that you don't really need the pins, ever. They are just a shortcut used by BMW to get the front suspension into a known configuration. You can change the camber back to stock settings even without the pins.
And if you go with aftermarket camber plates, the pins must come out anyway.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      05-24-2014, 02:43 PM   #37
TrackJunkie
TrackJunkie's Avatar
Drives: Interlagos Blue '13 M3 Coupe
2013 BMW e92 M3  [0.00]
2006 330i  [0.00]
I did mine and it is just as easy as every one says. I did not move the car - just moved the shocks in to the very end - no errors and no problems.
Interlagos Blue 20134 M3 Coupe, Comp Pkg, DTC, iDrive, No other options to keep it light
View My Garage -
http://www.e90post.com/forums/e90gar...garage&id=7562
      06-25-2014, 12:55 PM   #38
eaeRo
eaeRo's Avatar
Drives: m3 graphite
2007 BMW m3  [0.00]
Did this DIY today also, easy, did not disconnect the EDC, tricky part was taking off the strut brace part, everything else pretty straight forward. Tomorrow some testing
      01-06-2015, 11:00 AM   #39
E92M3GT
114
Drives: E92 M3
I followed this very nice guide for my Wheel allignment
Only question I have: I did not put the pins back on
After my Wheel allignment, the holes where the pins are screwed could no longer be seen
No problem to not use the pins, right ?
      02-10-2015, 06:48 PM   #40
z3papa
190
Drives: 11 E92 M3 ZCP, 07 335i
Thanks Rich.
Sold 2011.5 E92 M3 ZCP.
      11-06-2015, 10:40 PM   #41
///Mobbin
///Mobbin's Avatar
1478
Drives: m3
Thanks for sharing. I just had my pins pulled and my alignment done by a track alignment pro. Interestingly the negative camber from the factory on my ZCP car was already -1.3 and -1.4 and he adjusted it to -1.5 on both sides after pulling the pins. Not much difference but it was a freebie and I'll take it!
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
      09-26-2017, 07:47 AM   #42
chalbe
17
Drives: e92 m3, jeeps
I followed this DIY. My car has EDC, so, I popped the dust cover off and disconnected the EDC plug at the top of each strut; after that the work in the DIY is the same for EDC equipped cars. The whole process took about 10-15 minutes per side....it is really easy. I torqued the 6 top mount bearing bolts to 25 ft-lbs and the strut bar nuts as tight as I could with a long 13mm box end. I have a smart camber gauge and measured an additional -.4 degrees on each side after the work; with no EDC error codes.
Thanks to Richbot for making the DIY and to everyone that did the work and posted their results.
      04-16-2018, 02:35 PM   #43
MPower7
MPower7's Avatar
90
Drives: 11' e92 M3
Had the alignment shop max out the camber. I got -1.6 on the left and -1.7 on the front right. Why do you think they are different?
      04-17-2018, 01:57 PM   #44
dparm
Stop the hate, get a V8
dparm's Avatar
3853
Drives: C7 Corvette GS, AMG C63 S
Not uncommon -- typical production tolerances or maybe even the result of wear and tear over the years. The car's weight isn't symmetrical left-to-right anyway.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP
m3post
