01-04-2009, 10:27 AM | #24 |
Commander-In-Chief
2196
Rep 8,944
Drives: 2023 M2 Coupe, 2020 GLE 450
Nope, that would be too easy! It took about 20 minutes for the rear sump to quit dripping, by the way.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
01-04-2009, 11:04 AM | #25 |
148
Rep 1,400
Both sumps need to be drained correct?
Does the oil from the filter element housing not drain out when you remove the plugs on the bottom? |
01-04-2009, 11:22 AM | #26 | |
Commander-In-Chief
2196
Rep 8,944
Correct.
01-04-2009, 03:04 PM | #27 |
112
Rep 1,311
good post and pics. I'm about to do my first oil change in about 1000miles. Of course the 1200mile was already done by the dealer so now I'm going to do them by myself for now on. Are there any "packings" or O-rings, gaskets, seals that I should order along with a new filter element? I have the same instructions downloaded but I can't find anything about any oil-filter housing O-rings. I had a 93 Aero saab that had the same internaly type oil filter and there was a O-ring that had to be replaced everytime I took off the oil filter cap.
01-04-2009, 03:26 PM | #28 | |
Commander-In-Chief
2196
Rep 8,944
01-04-2009, 03:36 PM | #29 |
112
Rep 1,311
Awesome, thanks. I'd ask the dealer when I pick up the filter but wanted to hear from you guys that have already done it.
By the way, since this engine has two sumps. There is no special suction tool or any special procedures needed, right? May be a dumb question but I've done many oil changes on all my prior vehicles but none ever had a dual sump so just wondering. I've changed oil on Jet Engines and it's just bunch of chip-detector plugs and a filter. Can't be that much more complicated...I hope. |
01-04-2009, 03:46 PM | #30 | |
Commander-In-Chief
2196
Rep 8,944
01-06-2009, 09:33 PM | #32 |
80
Rep 961
01-06-2009, 09:35 PM | #33 |
Commander-In-Chief
2196
Rep 8,944
Not sure, but shouldn't that drain by gravity? If not, not too much to do about it. BTW, after putting in 8.9 liters the display was still telling me to add "1 qt.", even after driving it a couple times. Today, on the third drive, it finally updated to show that the level was proper. What a poor system! Glad we know enough not to blindly follow the electronic nanny, though it sounds like some dealers have done that!
01-08-2009, 12:29 AM | #34 | |
80
Rep 961
It took unique components of an "old" oil about two changes to "decay" to around zero after changing to a "new" oil. They dropped to about 15% of the original PPM measure on the first change, 2% on the second, then after that they were undetectable. It didn't seem to matter as far as performance was concerned. On that basis the 100cc in the filter body is just noise when you're changing from used TWS to new TWS. And, if I didn't say it already, THANKS! for posting the DIY pix - I will do mine next April at about 8,000 miles/1 year on the car. |
01-08-2009, 10:16 AM | #35 |
74
Rep 610
About 7 years ago I was talking to a guy at a peugeot dealer (overseas obviously) and he said that they add a slight pressure (I am assuming air) to the engine to help force all old oil out of the system when they did an oil change.
Has anyone ever tried to pressurize the engine when changing the oil?
EDC.....viagra for your car
01-08-2009, 11:04 AM | #36 | |
Commander-In-Chief
2196
Rep 8,944
Oil draining enhancement
01-23-2009, 05:15 PM | #38 |
13
Rep 376
Nice post Greg - thanks for sharing and while I have a ways to go yet, I will be changing the oil somewhere in the 6K - 7K mile range. Sure wold be sweet to have a lift in my garage for this
M3 ...the ultimate driving machine
2008 M3 6MT Cabrio, Jerez Black w/ Bamboo Beige interior, Tech/Preimum Packages, I-Pod, SAT/HD Radio, 19" MWheels 2008 535i tt, 6MT, Monaco Blue w/ Cream Beige interior, Preimim/Cold Weather/Sport Packages, HUD, HD Radio, etc. |
02-26-2009, 09:11 AM | #39 |
145
Rep 409
I changed my oil a few days ago at ~5800 miles. Here is what I learned:
1. I woud have gladly paid a few hundred dollars more for the car for a dipstick. 2. If the S65 had an ununsed plug in the engine that was somehow magically in exactly the right spot, I would happily invest the time and effort to retrofit a dipstick. 3. I find it hard to believe that BMW race engines do not still have dipsticks. You would think BMW would go for some ///Marketing points with "M cars are old school and still have dipsticks". 4. I do not have a mityvac and I did not remove as much oil as Greg did. I drained the oil and used about 8.2 liters of new oil, and the oil level indicator read slightly above the min mark after a round trip drive. I added another .2 - .25 liters of oil. After ~10 minutes of my drive in to work this morning, the level indicator had not moved at all. So maybe the indicator cannot see .25 liters of change, right? Just before I got to my gym, I went down a long, steep hill. In the midst of the hill the level indicator jumped up to about 2/3 of the way up to the max mark. From the gym to my office, the level indicator is still reading at the 2/3 mark. I would prefer to fill my oil to the nominal/mid mark. My dealer went to the max mark at the 1200 service. Maybe this is as close as I am going to get. Seems like an inaccurate system, based on how my indicator behaved today. It definitely makes oil changes harder. The mechanical part of the oil change is quite easy. I was happy with access and orientation of both drain plugs. The oil filter cap will leak oil however, so be prepared with paper towels when you start to open it.
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe |
03-29-2009, 08:39 AM | #40 |
Rep 43
Just changed my oil with 8.7l and it wound up being overfilled, I'll probably start with 8l next time. As an experiment, we only opened up the front drain plug for the dry sump and about .5 l came out. Reset the oil sensor and it came up as ok. Does anyone know if the dry sump is designed to collect the overflow in an overfill situation? If so, it could make these overfills a lot easier to fix.
04-05-2009, 11:37 AM | #42 |
172
Rep 2,373
the best thing you guys can do for your engines esp if you run them how they are made to be run is keep good clean oil in them! but yea the oil level deal is a royal pain in the you know what...esp if your flat rate like me and actually have to make money making sure the oil level is right...
04-07-2009, 11:04 PM | #43 |
188
Rep 1,153
Great post Greg! I just had it done at the dealer for about $180 (includes oil, filter, etc, ...) so this DIY is definitely great info... but it just sucks that I do not have a garage do this myself!
2019 M2C MT (ED + PCD) | 2008 M3 Coupé MT | 1995 M3 LTW MT | BMW CCA HPDE Instructor
04-13-2009, 06:27 PM | #44 |
28
Rep 309
What size socket is needed for the drian plug?
The Verdict: Every other manufacturer should give up on building their own cars and just make M3s instead. -Car and Driver June 2008
