08-24-2020, 02:11 PM | #89 |
687
Rep 973
Drives: 2012 E92 M3 DCT ZCP
Ended up getting the new hose at my local dealer and installed it a little while ago, buttoned her back up and she's running like a champ! Thanks for all the help.
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
DrFerry6731.50 |
12-18-2020, 02:45 PM | #90 |
31
Rep 69
this and the comments and the reference to that youtube video are great.This part should arrive today and I look forward to doing this tomorrow - I'll report back. For the difficult end of hose, I expect to push in and pinch and then pull out, and if that doesn't work I think I read that I may need to pull up, and if that doesn't work then I'll be using a pick tool to pry it off. And if that doesn't work it appears to be easy to detach the hose at the other hand, and the just take off the entire hose which should make it easier to work with. In fact I should do that right off if it doesn't come away easily. Actually I may detach the other side of the pipe and lift the entire pipe and pump out to make it easier to access. Oh yeah and also occasional bizarre idling bounces. I mean seriously. I almost get all the plastic in the car - weight adds up and if it does the job then why not - but the plastic doesn't always do the job does it. I just changed the coolant and that plastic bleeder screw snapped off on me. I heated up a phillips head screwdriver with a butane lighter, drove it hard into the plastic threaded piece still in there, tapped it with rubber mallet, put ice around it, and when it cooled unscrewed it. whew.
On a side note isnt anyone else irritated about this, I mean I've had to self-diagnose a bad EDC that kept killing the battery, which took years and I bought a few batteries, and an intelligent battery cable, and paid a reputable BMW professional in my area to take a whack at the problem (fail), and god knows what else. And I read this post and was like mind blown, my car has stalled after refueling several times - and also sometimes when I'm refueling at the pump, it stops early as if the car is full, then I drive off and the tank isn't full - now I realize the vacuum thingy here is responsible lmao. I am sincere when I wonder if this is a lemon. Recently I had a bunch of EDC-related warnings which kicked out errors including a steering wheel angle problem. After taking apart the cover over the battery in the trunk and then disconnecting the battery, I removed the driver's air bag and then took apart the steering wheel and then detached and cleaned the steering angle sensor. This alone didn't fix the problem but weeks later I used BMW tools and my PC to recode the value to 0 and this somehow worked. Now I'm waiting for the actuators to die. In a way this car is a perfect DIY project car because so many things have been wrong with it. I bought it new and so this many problems are frustrating. I can't imagine not being a DIY'r and having to deal with this stuff year after year. Also I work from home and this is my driver, if this were my driver and I had to go to work every day I would have dumped it long ago. Don't get me wrong when everything is running correctly this is, as you all know, a great car. But so many problems, ugh. Last edited by RedCardinal; 12-18-2020 at 03:21 PM.. |
DrFerry6731.50 |
12-18-2020, 03:22 PM | #91 | |
2386
Rep 3,739
Drives: 2018 M2
DrFerry6731.50 |
01-06-2021, 02:56 PM | #92 |
93
Rep 146
A BMW tech advised lubricating the shafts that connect all of the throttle body flaps to the actuators. This way you eliminate the chance that the motors and gears wear out due to friction. This is what he recommended.
https://www.amazon.com/08897-Silicon.../dp/B000PJED72 This is what I did at 75k miles and again at 100k miles. So far everything works great and no actuator failure. |
DrFerry6731.50 |
01-06-2021, 04:09 PM | #93 |
Astronaut
514
Rep 732
Changed mine out last night since I'm installing my supercharger and decided to do maintenance while everything is off.
Can confirm, I too broke the nipple off lol. After spending too much time trying to pry it out, I decided to cut the hose instead. |
DrFerry6731.50 |
04-10-2021, 05:20 PM | #94 | ||
38
Rep 78
Thank you for the great write up |
DrFerry6731.50 |
03-26-2022, 09:48 AM | #95 |
Rep 31
Older thread but for people who have problems with that one push together style connector at the fuel tank breather valve I ended up actually replacing that hose because I mangled the plastic pinch style connector. Also be really careful with the crankcase breather hose connector at the front of the intake plenum. In practice it sits very near the thermostat housing and I think over time it gets brittle.nmine ended up breaking.This is something that I did not have any want replace has the connector in the back is all the way in the back of the motor and very hard to get to. I bandaided mine with some barb style, brass connectors and hose clamps..
DrFerry6731.50 |
03-26-2022, 11:18 AM | #96 |
336
Rep 724
It seems that enough people had issues with all of the hoses that ECS has a kit now!
https://www.ecstuning.com/b-assemble...13907838281kt/ |
DrFerry6731.50 |
05-31-2022, 05:34 PM | #97 |
Bub
Rep 7
hi all, as someone who is absolutely ZERO mechanically inclined, i was able to do this without damaging any clips or cutting any rubber hoses. sharing what i thought was helpful & what i did differently from the OP:
1) you don't need to take off the t-screws by the grill to remove the plenum, i was able to pull the entire airbox + elbow off simply by removing the 2 intake box screws & loosening the elbow hose clamps 2) regarding the rubber hose on the front side of the fuel breather valve: i went ahead and removed this hose first contrary to OP's suggestion. i took a flat head screwdriver and pried back and forth where the hose & FBV meet to loosen it and then shot some WD40 and let it cook for a few minutes. after prying a little more (to try to get the WD40 to penetrate deeper into the hose) it got pretty loose and slipped off with (relative) ease. 3) regarding the rear (most difficult) hose/clip, you want to remove the FBV from the mount by wiggling it off until the rubber grommet comes off. the reason for this is because you can rotate the FBV assembly so that the top & bottom of the clips are exposed so you can actually pinch them down. otherwise, the top clip is blocked by the plug for the other electrical connector you had to remove. once the FBV is free from the mounting spot, like OP stated, you have to PULL the rear hose/clip INTO/TOWARD the FBV. by pulling it into the FBV first you'll notice the clips have a little more slack & give. don't waste your energy just trying to do 500 reps of taking the clip off but instead, do a snug/strong tug toward the FBV BEFORE pressing the clips and with literally all of the power your fingers have, press on the top and bottom clips and it should pop out hope this helps, thanks to OP for this ultra detailed guide. helped me tremendously! |
09-09-2022, 01:51 PM | #98 |
475
Rep 699
Drives: 2011 BMW M3
I met twice of my engine just shutdown when I stopped at red light, one of them just happened right after I filled up the gas. So figure out it should be Fuel Tank Breath Valve issue and I am going to order and replace it.
Any suggestion to do more pre maintanance works cause you just have the plenum off and already there?
2016 F15 X5 xDrive 35i Space Grey M-Sport - BM3 Tune/ER charger pipe/afe power dry panel filter.
2011 E92 M3 DCT MW - AA intake/Akrapovic slip on/Ohlins R&T/Stoptech ST60 and ST40/Underdrive Pulleys/Antigravity H6 40ah/Alpine Tune |
09-09-2022, 03:11 PM | #99 | |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
E90325M475.00 ///M Power-Belgium64189.50 |
09-09-2022, 05:17 PM | #100 |
475
Rep 699
Drives: 2011 BMW M3
TA done.
Thermal stat done. Sensor done.
DrFerry6731.50 |
10-27-2022, 09:02 AM | #102 |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
I maybe looking at doing mine. I've been getting a "tighten gas cap" notification. I replaced the gas cap and a few days later the message returned. It could be a loose connection or connector at the gas tank breather valve or the valve itself - though the idle after filling up is fine. I just read the codes with the Carly App and no DMTL malfunction code is present only the "loose gas cap" occurrence code shows up. I will monitor and report back.
01-01-2023, 02:02 PM | #103 | |
1547
Rep 2,069
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
DrFerry6731.50 smoothmacdaddy9.00 |
01-07-2023, 06:39 PM | #104 |
32
Rep 143
Need help was trying to remove the hose for the breathe valve and it broke with the plastic still inside,
I tried using a pic to pull out the plastic and the tip broke not sure it flew out or went to the other end where it is connected , I cut the hose and tried to look into the metal end but didn’t see anything in there and nothing inside the hose either, I have hooked up new breather valve , but not sure if should start the car take it to mechanic , I am not much mechanically inclined just basic oils change and stuff was trying to learn something new but it came to but in my back Feel so down Please help as to what is the metal part that connect to the hose and of that small piece is inside how to fix it, Thank in advance |
01-08-2023, 07:39 AM | #105 | |
336
Rep 724
Don’t be discouraged, many seemingly straight forward jobs are complicated by brittle plastics. For this replacement, I had seen that one of the vendors pairs the hose with the breather valve. If you’re worried about it, replace the hose. |
DrFerry6731.50 |
01-08-2023, 09:35 PM | #106 |
32
Rep 143
@drrust
I took out the ICV and all the hoses and tried to look inside all with a pin hole camera didn’t find the broke pic tip, I am hopping it flew off out and I was not able to see it as it was such a small small tip end of the pic, I haven’t put back car together as I am waiting for the refurbished valve cover, will put back together by next weekend and see if everything works ok Thank for your reply |
DrFerry6731.50 |
03-02-2023, 03:52 PM | #107 |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
A Few Things I Did When Replacing My Fuel Tank Breather Valve
I finally got around to replacing my fuel tank breather valve. I removed mine by first disconnecting the end of the black braided pipe that attaches to the black plastic line coming from the fuel tank (located on the driver's side inner fender below the strut tower). I did this so I could remove both the black braided fuel breather hose and the fuel tank breather valve together. Once I had them both on the work bench I pushed the rear braided black hose fitting towards the fuel tank breather valve and then pinched the connector serrated edges with some channel locks. And voila off it came!
I noticed the black plastic tank breather line on my car from the fuel tank wasn't seated in its clip holder on the inner fender. Nor was the black braided breather hose going to the breather valve seated in its clip holder below the throttle actuator shaft. I took some photos and posted them below with before and after shots. Take a good look inside the black braided breather hose fitting that clips onto the tank breather valve pipe to see the annoying clips which need to be released. Now I have no more long cranking after filling up with gas. No more "Check Gas Cap" dash warning. No more "Increased Emissions" iDrive warning message, and no more "misfiring on all cylinders" codes being thrown which can cause limp mode. I believe the misfiring on all cylinders was only happening during the long cranking after fill ups with gas. Cost me $40 and worth every penny. The idle is now much more stable - especially when cold - and rock steady at ~750RPM. Perhaps unmetered air was entering the idle control valve from the fuel tank breather valve being stuck open? Anyways, it's all fixed now. Black Plastic breather line from the tank: . . Black Plastic breather line not clipped into holder: . . Disconnected braided fuel tank breather valve line: . . Braided fuel tank breather valve line properly clipped into holder below throttle actuator shaft: . . Braided fuel tank breather valve line connection fitting to breather valve end: . . New Bosch Fuel Tank Breather Valve: . . Black plastic breather line properly clipped into holder: . . Finished job. Nestled in its hiding place: . .
02-22-2024, 09:13 PM | #108 |
180
Rep 478
Bumping up an old thread to say thanks for the amazing write up. I had the plenum removed for doing some major maintenance and decided to do this replacement too as I had the same symptoms. It was pretty straight forward and honestly I struggled a little more with the front hose than the back connector. I used pliers to pinch the clips on the back connector and pulled really hard and it came right off. All in all took me about 30 mins to remove and replace the valve since I had the plenum removed already. Definitely recommend disconnecting the back connection hose and removing it from the car along with the valve, makes things so much easier.
DrFerry6731.50 |
