330D Induction
02-28-2009, 05:24 AM | #45 |
14
Rep 213
Drives: BMW 330D M SPORT
Sorry this might sound a bit dumb to most. But if you dont ask you never know. What is the difference between the BMW performance intake and the K&N that SpeedReligion do?
I understand that the K&N is only the Air Filter! While the BMW Performance Intake looks like the whole section. |
03-14-2009, 07:35 AM | #46 |
310
Rep 1,314
Sorry to dig up an old thread but K&N now do a proper induction kit for the 330d, not just a replacement filter.
http://www.knfilters.com/news/news.aspx?ID=1609 Has anyone tried this??? Instruction fitting and pictures here:- http://www.kandn.com/instructions/57A-6041_inst.pdf |
03-14-2009, 10:56 AM | #47 |
Right Responsible
58
Rep 1,646
And the lazy buggers still dont have anything yet for the 335d!!!!!!!!!!!!!
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys. |
06-02-2009, 04:29 PM | #48 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
Almost certainly warranty null & void as the K&N is not an OEM filter.
06-03-2009, 05:13 AM | #49 | |
45
Rep 408
I wouldn't be so sure... For numerous reasons, including the fact that BMW issues a K&N filter with the BMW Performance induction/air intake for the E90 330i as part of the kit. They also fitted a BMC K&N style filter to the M3 CSL and the new M3 4.0 V8 also uses a K&N type filter. If they are so bad and un warrantable, why would they offer them for the above cars? I'm not saying they will accept it straight away on a 330d, as dealers have a lack of reasonability in areas like this, but I can say that if anything happened the air filter shouldn't be to blame and you would have a case for discussion, that is if you where to leave it in the engine if you had a problem rather than removing it before it went to BMW... |
06-03-2009, 12:31 PM | #50 |
112
Rep 5,541
I would think BMW would take the line that if the filter had *caused* the failure or was in any part consequential to said failure, then that parts warranty would be null and void.
I don't know how they look at mods - anybody out there been brave enough to test it?
06-03-2009, 03:09 PM | #51 | |
50
Rep 395
How much is exhaust and filter fitted, and is it just the back box, thanks |
07-05-2009, 06:41 AM | #52 |
112
Rep 5,541
Well I've just replaced the air filter in my 330d at 50,000 miles and it was filthy!
I would now change it at 20,000 mile intervals, 60k is far, far too long a period. I've taken some pics so will do a comprehensive how-to later.
07-05-2009, 07:06 AM | #53 |
310
Rep 1,314
Totally agree....60k is far,far too long. Should be changed much sooner. Extra cost to change will be offset to some degree by fuel savings.
07-05-2009, 07:09 AM | #54 |
112
Rep 5,541
Indeed; and I have you to thank Rich for alerting me to the 'problem'.
I was shocked when I opened the casing (which is no mean feat!) Looking fwd to an economy increase now. Bit of a trip later down the 303, so we'll see.
07-05-2009, 10:08 AM | #56 |
19
Rep 732
had a similar airfilter layout on my E46 320d- I've found pieces of windshields in there.
just a thought, why put in a high performance air filter, and install a cold air intake with a second filter? In principle the downstream filter (far from easy to get to) filter should stay clean forever with minimal pressure loss, yet you avoid any risk on leaks in the plumbing (I would not run the risk of leaving this filter out). And the 1st filter will stay much cleaner than the orignal over time. One badly sucked leaf in the orginal set up ruins your intake performance without you knowing it. regards, |
