whats faster turbo tuner or jbs2?
10-10-2007, 05:43 PM | #23 |
these cars waste alot of fucking gas
51
Rep 992
you guys have been realy helpful ... But we need more time slips of the Turbo tuner. I would go to a drag strip but the closest one near me is a 2-3 hour drive .
e90 335i sport- (with following mods) sstt, afe intake, custom zoomers exhaust , dimisa 4" tips, m6 reps , painted oem front splitter, carbon fiber grill.
10-10-2007, 05:52 PM | #24 | |
38
Rep 762
Let's not also forget that this is a direct injection system so now the DME can control fuel timing just like ignition timing and can control timing for the intake and exhaust camshafts depending on other inputs sensors like crank position, cam position, TPS, TMAP, etc. |
10-10-2007, 05:59 PM | #25 | |
38
Rep 762
If it's really bad it may go into limp mode and set off a service engine soon light. |
10-10-2007, 07:05 PM | #26 | |
Samtaro!
125
Rep 2,601
Rich AFR means more fuel mixed into a given volume of air. Lean means less fuel per volume of air. "Timing" refers to the moment of time the spark plugs are fired, or the time when ignition of the air/fuel mix begins. Aftermarket parts can cause a lean condition by either increasing the volume of air (increasing boost) or decreasing the input of fuel. Since the SSTT increases boost, it can potentially cause a lean condition to occur (too much air, not enough fuel). Hope this helps... |
10-10-2007, 07:15 PM | #27 |
Samtaro!
125
Rep 2,601
If the oxygen sensors sense too much oxygen in the exhaust, it flags a lean condition. But I'm not sure how the ECU reacts to that... probably logs an error code, lights up the check engine light... because theoretically I don't think a stock engine with the stock mappings should ever reach a lean condition, unless there is a problem with the engine somewhere.
