Help installing rear silicone inlet (MMP)(pic)
08-13-2016, 03:46 PM | #1 | |
Roll Tide
591
Rep 2,345
*edit* Is the inlet supposed to route through the red or green circle? It wants to naturally go through the red circle but then it's a bit too short to mate up with the turbo snout. It seems to me it should go through the green circle but I can't for the life of me get it to route that way.
Original post: Quote:
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306 Last edited by wren57; 08-13-2016 at 08:21 PM.. |
08-13-2016, 03:51 PM | #2 | |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
08-13-2016, 04:17 PM | #3 |
648
Rep 779
+1 used the same tool. $20 for the kit at Walmart. I had the motor mount out while installing the turbos and that bracket bolt was still a pain. Have fun
08-13-2016, 05:05 PM | #5 |
Roll Tide
591
Rep 2,345
So to be clear, it does need to go where the arm is? Guess I'll be taking a trip to Wal-Hell.
http://www.e90post.com/forums/showthread.php?p=20230306 |
08-13-2016, 07:56 PM | #6 |
Roll Tide
591
Rep 2,345
Got the bracket off finally. Can't get the inlet to move "up" into where the bracket was tho. Have tried a strap underneath and pulling up and just pushing with a large bar. No dice. Suggestions?
08-13-2016, 08:53 PM | #8 |
Roll Tide
591
Rep 2,345
I wouldn't think so. It's very thin.
08-13-2016, 09:58 PM | #9 |
648
Rep 779
I didn't remove the heatshield, but you can bend it back a bit with a pry bar. Hosing the outside of inlet with WD40 helps it move around between the motor and firewall easier, but be very careful not to get any on the inside. Make absolutely sure that the inside of the inlet hose and outside of the turbo inlet snout are 100% dry/degreased or the inlet will slide off when you try to clamp it down. Even if it doesn't right away, it could still pull off down the road. The inlet snout on the rear turbo is very short, so make sure the clamp is as close to the compressor housing as possible to get a good bite with it.
08-13-2016, 10:19 PM | #10 |
648
Rep 779
Didn't see your edit. I have RBs, but I'm sure they are more or less the same and will pretty much only go on one way.
I was by myself, so used speaker wire around it to be able to get some weight on it to pull. I couldn't get a good grip on the inlet itself from underneath. I used soapy water on the outside at first, but WD40 wound up getting it done. No matter what, you're going to have to manhandle it through, it's not just going to slide in. So you can see about where it all sits to make the connection: |
LMB335IS1299.00 |
08-14-2016, 09:32 AM | #11 | |
Sua Sponte
1299
Rep 2,850
08-14-2016, 02:16 PM | #13 | |
19
Rep 184
