eliminate the brake dust...
06-28-2006, 12:04 PM | #45 | |
it can never be too clean...
165
Rep 1,100
ROTEX BRAKE PAD INSTALLATION INSTRUCTIONS: Tools Required: flathead screw driver needle nose pliers 3/8 ratchet w/ extension 7 mm allen wrench 7 mm allen socket 17 mm socket w/ extension (for easy of removing lug bolts) floor jack torque wrench Steps to follow: 1.) Use a floor jack and tools to loose lug nuts. (suggestion: use electrical tape around exterior lug wrench bore for added protection from scratches to your rims) 2.) Use a floor jack to lift vehicle so the tire is 2" off the ground. 3.) Remove loosened lug nuts with 17 mm socket and extension. (use electrical tape on this socket as well) 3.) Use flat screw driver to push piston clip to compressed position. Place screw driver in the back side of caliper between rotor and inboard pad. Twist screw driver against pad and rotor to move piston back. 4.) Remove front caliper clip with screw driver or pliers. 5.) Remove sensors gently by pulling on sensor to unplug. 6.) Remove black plastic caps on backside of caliper. 7.) Use 7 mm allen socket and/or 7 mm allen wrench to remove both long allen bolts. 8.) Remove caliper from rotor (do not allow caliper to hang by brake lines). Set caliper on top of rotor, securely. 9.) Remove factory brake pads. Install inbound "Rotex" pad into caliper piston. Install outboard pad onto rotor bracket housing. 10.) Side caliper over rotor. Secure caliper by inserting caliper allen bolts into the rear of caliper. Make sure bolts are in place correctly. Then tighten 7 mm allen bolts firmly. (*Note: Caliper will seem semi-loose, but this is normal). 11.) Reinstall sensor wire. 12.) Reinstall plastic caps on backside of caliper. 13.) Reinstall front caliper clip. 14.) Reinstall wheel and tire. Hand tighten lug nuts with 17mm socket. The tighten securely with lug wrench. Lower vehicle with floor jack and retighten lug nuts when vehicle is on the pavement. Torque lugs to oem specs. 15.) Start car and apply brake pedal repeatedly until pressure has built up. Drive as normal. Note: I always add anti-squeal goop to the backing plates and brake grease to the contact points. It can't hurt.
'14 328xi wagon / m sport / white / red leather kw v1 coilover kit / 19" staggered 351 M double spoke wheels / upper strut bar / sport line grille & exhaust tips / 50% tint / painted reflectors / debadged / complete clear bra |
06-28-2006, 12:33 PM | #46 | |
189
Rep 2,068
i dont have much to do this summer so anyday is fine with me when will u be free? andrew how bout u? or we can meet up for the brake installation lol and then treat andrew to a dinner or somethin i wont have my car till friday though
mod = crack
06-28-2006, 01:00 PM | #47 |
52
Rep 996
andrew 330i, you da' man!
2006 330i Monaco Blue | Grey | Walnut ...Manual | Sports | Premium | Cold | Nav | Comfort Access | PDC | Sirius | Sunshade ...M-Tec Steering Wheel | M-Tec Shifter | TLC ...Performance Center Delivery | Oct 14, 2005 |
06-28-2006, 01:39 PM | #48 |
Moderator
497
Rep 27,441
for now, i'm going to let bmw do their thing under the free maintenance period. when that's over, i'll probably switch over to axxis deluxe plus pads which are low dust.
06-28-2006, 05:01 PM | #49 | |
1114
Rep 2,327
how about a g2g mid-july or so? i have a garage and i have beer! |
06-28-2006, 05:46 PM | #50 | |
189
Rep 2,068
and columbus gold i cant go in either
mod = crack
06-28-2006, 05:51 PM | #51 | |
1114
Rep 2,327
06-28-2006, 06:04 PM | #53 | |
165
Rep 1,100
solid gold... my wife only allows me to go to jason's in windsor come detroit auto show... and strip clubs in vegas during sema. not so impressed with the locals... the last weekend in july or sometime in august would work best for me and my schedule. saturdays preferred.
06-28-2006, 06:56 PM | #54 | |
189
Rep 2,068
i'm down for it, armoredsaint how bout u? how do i get to your home andrew? 315north, 270 dayton?
mod = crack
06-28-2006, 07:01 PM | #55 | |
1114
Rep 2,327
pm to you appriadi with my cell. |
06-28-2006, 07:59 PM | #56 | |
165
Rep 1,100
pm me for exact directions.
06-28-2006, 08:21 PM | #57 |
The World is Not Enough
166
Rep 1,088
solution
I just prefer to just drive w/ no pads at all ...............
I love the grinding noise and the holy @!*#^) look people give me when it takes a mile to stop! |
06-29-2006, 11:51 PM | #58 | |
189
Rep 2,068
lets do a meet soon! i dunno when will i get the car back though, hopefully tomorrow
mod = crack
06-30-2006, 03:45 PM | #59 |
Rep 256
I bought and just had installed and they are AWESOME. Two days of hard driving and no brake dust!!!! They also perform very well...on par with OEM pads.
BMW should install as OEM...no need to make loyal Ultimate Drving Machine fans suffer with brake dust. |
06-30-2006, 05:50 PM | #60 | |
1114
Rep 2,327
06-30-2006, 10:06 PM | #61 | |
189
Rep 2,068
i've some other stuffs as well just collectin dust in the room, you should come over and look at the pile lol! front lip, rear apron, intake...exhaust soon maybe...and sideskirts by end of september i'm putting those on once everything's here...so far i'm still waitin for exhaust and sideskirts.... hey wanna meet in andrew's house? is it near yours?
mod = crack
07-02-2006, 03:05 PM | #63 | |
517
Rep 18,858
buuuump... Where can I find these???? |
07-02-2006, 03:27 PM | #64 |
Captian
Rep 49
I ran Axxis dust-free pads on my '02 e46 for 2 yrs and had to replace the roters at my cost. Axxis pads ate right through them. $600 down the toilet! Driving on the motorway when raining was also a little scary too, as they often wouldn't "catch". Stick with the dust.
07-02-2006, 06:30 PM | #65 | |
15
Rep 145
Tom
35% Formula 1 Ceramic Tints, //M E-Brake handle, //M Steering Wheel |
