01-05-2023, 06:48 AM | #1 |
Rep 55
Dashcam Fitting - Part Number Help
I've obtained the fitting instructions for the BMW dashcam which I'd like to follow even though I'm fitting a Blackvue.
The instructions show some miniature connectors that fit into the power distributor Z7 in the passenger footwell and a bit of a search shows a part number that is no longer available. Does anyone know what these part numbers are by any chance? |
01-05-2023, 07:14 AM | #2 |
142
Rep 296
The fuse box you need to connect your blackvue for the 2GC is behind the glove box and the two fuses that need to be piggybacked are fuse 64, switched, and 40, empty and live. As per post #68 here https://www.babybmw.net/threads/dash....125353/page-4 Piggybacks are readily available from such places as Amazon.
This is how a dashcam installer would go about it.. Last edited by cukeuk; 01-05-2023 at 07:33 AM.. |
01-05-2023, 07:33 AM | #3 |
Rep 55
Thanks for that, I have the fuse piggyback connectors but the BMW ACE instructions show a connection into the Z7 module using miniature connectors so the dashcam can be fused independently using spare ways in the fuseboard.
I'd rather wire it in this way as it's a bit safer and is following BMW's instruction therefore no reason for them to raise any warranty issues. The connector is item E on this diagram. Last edited by ChristianF; 01-05-2023 at 07:52 AM.. |
01-06-2023, 07:27 AM | #5 |
Rep 55
I got the parts from my local BMW dealer but it turns out both of the fuse ways in the above instruction (46 & 48) are already utilised on my car.
75 & 40 were unused so I used them instead. |
03-23-2023, 10:37 AM | #7 |
Rep 7
Hi,
I have a new one like your M235i GC Yesterday the installer was sent by Next Base to install my 622 NextBase dash cam I chose the switched option, i.e. after turning off the ignition in the car, the dash cam should turn off permanently. The installer had a problem with finding the right fuse to connect the dashcam and which turns off immediately after turning off the ignition. After advice from his colleagues from RS Connect, he connected somewhere, but the effect is that it is a shutdown with a delay of 6 minutes So after turning off the ignition, this fuse is still live for 6 minutes. and the camera records << the sky << and takes up space on my memory card. This is unacceptable to me and I have written a complaint, waiting for a reply How did you do? Have you found a fuse that has no delay and turns off immediately with the ignition If you can, please help me because I can't deal with these ,,experts,, **I got a list of fuses in our model < but I don't see an option to attach to my answer Maybe this will help mark the correct one for me Chris |
03-23-2023, 10:40 AM | #8 |
Rep 7
Hi,
03-24-2023, 05:33 AM | #9 | |
15
Rep 46
I'm using a Viofo A129+ currently and honestly the parking mode has been a pain. Sometimes it works correctly like it should, sometimes it goes into parking mode while driving for no apparent reason, sometimes (rarely) it forgets to turn on with the ignition*. I've half a mind to replace it with 70mai since I've used their cameras before and they gave me no such problems (albeit on a different, simpler car). Maybe BMWs are too complicated for its software to handle or maybe I've got a faulty camera power adapter. I've learned to live with it for now *I say ignition/engine but the switched fuses go live after unlocking the car and opening the door. Honestly it's been a pain compared to my previous car when if you took out the key the switched fuses went, and stayed dead Last edited by YogiPL; 03-24-2023 at 05:39 AM.. |
03-24-2023, 08:29 AM | #10 |
99
Rep 334
I don't believe that there is a fuse that drops to 0V as soon as you switch off. This is probably a rational design point to allow things to shut down gracefully. If you are worried about 6 minutes of recording filling your memory card then, given how cheap memory is these days, I'd suggest getting the biggest card that your dashcam will support, and moving on.
Just another thought: when I unlock my car the instruments generally light up and my dashcams start up. By the time I'm ready to drive the cameras are already fully operational and recording. If they were asleep until the car was ready to move you could be missing something important. Last edited by cjn; 03-24-2023 at 11:37 AM.. |
10-04-2023, 07:37 AM | #11 | |
Rep 16
10-04-2023, 08:07 AM | #12 |
15
Rep 46
