2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions 6WA coding question
      11-08-2019, 12:25 PM   #1
RuleNormaliai
RuleNormaliai's Avatar
237
Drives: 2022 G20 330E
6WA coding question
Hey, today i have retrofited 6WA to F10, but when i went to flashing procedure i only got cdDeploy checkbox active,all other were greyed out, coded succsesfully, cluster works as it should, but tamper dot is visible (Cluster was virginized, mileage lower than the cars actual).
Main questions:
Why were other flashing options greyed out?
Why there is tamper dot still visible?
Thanks!
      11-10-2019, 02:40 AM   #2
vuthy335
vuthy335's Avatar
103
Drives: 2008 335i montego blue - 2011
To my knowledge I-step is incorrect that's why those others are greyed out. Did you code the kombi to the car first before flashing it? Red tamper dot could possibly mean cluster wasn't virginized correctly. Pm me and let me know your steps on how you did it. And I can go thru with you which steps you might have missed or is incorrect
      01-19-2020, 04:10 PM   #3
SSgtC
SSgtC's Avatar
Drives: BMW F10
2016 BMW/550i  [0.00]
Hey vuthy335, does this mean this is not a plug-and-play DIY? Please excused the potentially dumb question, however, I've been wanting my F10 to have the same digi-screen I had on a 6 Series. Thanks for your response.
      01-21-2020, 09:38 AM   #4
Unspec
Unspec's Avatar
1312
Drives: 2015 BMW 535xi
The install itself is plug and play. Actually getting it to work correctly requires some coding work.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets
ISTA VM Setup/Tutorial
SSgtC5.00
      01-28-2020, 11:30 AM   #5
vuthy335
vuthy335's Avatar
103
Unspec is correct. The install is plug and plug. But you have to do some coding for it to adapt to your car correctly. Otherwise you will get the infamous "red dot".
      01-28-2020, 02:07 PM   #6
OnlyGerman
OnlyGerman's Avatar
364
Drives: F15, F13, F10, E60
There is a member on here who has done plenty 6wa and 6wb. He can do it all remotely.
      02-12-2020, 09:38 AM   #7
SSgtC
SSgtC's Avatar
Drives: BMW F10
I'd definitely would like to further explore these option. I used to have a 6 series with it and it was awesome. I would love to have it on my F10 550i.
      02-12-2020, 09:41 AM   #8
OnlyGerman
OnlyGerman's Avatar
364
https://f10.5post.com/forums/showthread.php?t=1599955
You can find a used one and ship to him
      04-23-2020, 06:38 PM   #9
pinski
Drives: 2015 550I M
where can you find a good used one for cheap? What cars have the 6WB besides the 7 series? Thank you!
      04-23-2020, 08:17 PM   #10
OnlyGerman
OnlyGerman's Avatar
364
eBay
      05-30-2022, 05:56 PM   #11
lilstevie68
Drives: f10
Can someone tell me the steps cuz im getting somekind of error when i press start and also most of the tabs are greyed out even thought i chose the right istep version.
5post
