10-29-2022, 06:13 PM | #1 |
Rep 6
Retrofitting a 125i xforce exhaust to bmw 120i e87
Hi Guys,
I have a 2005 bmw 120i. So I wanted to remove the stock exhaust and fit a 125i xforce valve controlled exhaust to it, but it won't fit because the 125i eaxhust occupieas a lot of space. My second thoughts was to try and remove the battery compartment and change its position so as to create a more bigger space for the exhaust to fit. This is the only way I can use the Xforce exhaust on 120i. Has any one done this before? I will be very keen on knowing which possible location is good for the battery compartment and possibly share some pictures. If you have done this before, but not for a 120i , I will also keen to see some pics. I wanted to explore all options before returning the exhaust to the seller, in case I can't install it on 120i. That will be lost of my money. So please help share your thoughts with me plse. I will highly appreciate your suggestions Thanks |
