11-22-2023, 10:15 PM | #1 |
140
Rep 100
Drives: '21 A90 Supra 3.0, '11 E92 M3C
Rear Shock Mounts for ST XTA Coilovers
Need some help with looking for the correct rear shock mounts for ST XTA coilovers. My car has OEM EDC so I got the coilover part number that would be compatible for EDC-equipped cars (but I will leave them unplugged).
Do I purchase a new OEM EDC rear shock mount kit (i.e., something like this: https://www.turnermotorsport.com/p-1...SABEgLQifD_BwE) or go with aftermarket mounts (I saw some folks recommending Monroe, but I think they don't make a 14mm ID one)? Car has around 115k mi so it will definitely need a refresh on RSBs. The main thing I'm confused on is that it looks like there is a 10mm/12mm/14mm option for rear struts, so wondering if anybody who has ST XTAs / aftermarket EDC-compatible coilover kits purchased a new EDC rear shock mount kit, and if so, whether they went with 12 or 14mm? I have done a ton of searching on this forum as well as on E9x owners on facebook and couldn't find a definitive answer on which rear shock mount I needed. Any help would be very much appreciated! Thanks in advance
2021 A90 Supra 3.0 Nitro Yellow, 2011 E92 M3 Comp Jerez Black
Instagram @hans.device Last edited by hson10; 11-22-2023 at 10:37 PM.. |
11-25-2023, 04:07 PM | #2 |
3911
Rep 4,176
Rear strut mounts are 10mm for non-EDC and 12mm for EDC. I'm not aware of 14mm RSM. I just installed my TracTive a little while back and they are definitely 10mm or 12mm.
If the ST coilovers are direct replacement for non-EDC dampers then get the 10mm ones. Even if you made a mistake you can go to a machine shop and get the metal sleeve bored out to 12mm. Monroe does make a 10mm one. I would recommend just going Powerflex Black and not ever think about them again. Zero impact to NVH. |
03-06-2024, 09:49 PM | #4 |
Rep 16
03-06-2024, 11:11 PM | #5 |
2335
Rep 5,795
