XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      06-29-2018, 03:46 PM   #89
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
Even if they fit you don稚 want them. The angel eyes are yellow and even if you put led bulbs they値l look dim.
      06-30-2018, 09:40 AM   #90
Njerts
126
Drives: x3 m40i
Originally Posted by eyeamgrewt View Post
Bumping this as I'm looking to swap my stock halogens to aftermarket projector assemblies.
I found a seller on ebay selling a set that are listed to fit 09-12 X1's, I asked if they'll fit a 2015 and he said only up to 2012. I know there was a bit of a facelift in 2012 and one of the things noted is redesigned headlights, however they look pretty identical. Can anyone confirm if there were any changes to the headlamps or are they indeed the same fit from 09-15?
Not sure about 2015 but up to 2014 is the same.
I upgraded my 2014, see higher up in this thread.
The upgraded lights I installed worked great, you would not be able to tell the difference from outside to LCI.
I had to remove them because I am trading my 2014 today.
      06-30-2018, 01:41 PM   #91
jd__m4
jd__m4's Avatar
415
Drives: AY M4
Thanks- I had noticed the vendor you and spoolin used says both 09-12 and 09-14, so I have a feeling they fit.
What are you going to do with the set you just took off?
      06-30-2018, 07:32 PM   #92
Njerts
126
Drives: x3 m40i
Probably Craigslist, shipping anywhere from here (Vancouver) is expensive.
Was hoping to get someone local to just pick them up.
      07-06-2018, 09:30 AM   #93
jd__m4
jd__m4's Avatar
415
Drives: AY M4
I've been searching on Alibaba for suppliers and have been talking to one for the past few days that seems to have what I'm looking for- the 2013+ Xenon lamps w/ the LED eyebrow that was incorporated with the LCI. The OEM parts they reference are 63117290261 / 63117290262, which look to be for the European market X1. Anyone aware of any differences? The seller is offering them for a few hundred less than what I've been able to find and has a good history/rating on Alibaba..
      07-06-2018, 09:54 AM   #94
Njerts
126
Drives: x3 m40i
Do you have a link?
      07-06-2018, 09:57 AM   #95
jd__m4
jd__m4's Avatar
415
Drives: AY M4
https://teambill.en.alibaba.com/prod...6c06788aEF8uiG
      07-06-2018, 10:24 AM   #96
Njerts
126
Drives: x3 m40i
They look the same as mine, except mine have clear corners.
From what I can see, it looks fine.
What I can稚 see is what ballast they used and what bulbs.
Is it ds1 ?
      07-06-2018, 11:09 AM   #97
jd__m4
jd__m4's Avatar
415
Drives: AY M4
Is it ds1 ?
They have another listing that shows D1S bulb/ballast, but this one does not include anything for the low/high beams, I believe- which I'm OK with- I've contemplated just using LED's for the low/high beams anyway.
      07-06-2018, 12:03 PM   #98
Njerts
126
Drives: x3 m40i
Got it, this is more like the ones spoolinX1 got.
See his posts earlier in this thread.
      07-08-2018, 09:24 PM   #99
jd__m4
jd__m4's Avatar
415
Drives: AY M4
So it looks like the same setup you had- seller is including d1s bulb/ballast for another $90. Total is right at $600 with shipping.
      07-08-2018, 10:45 PM   #100
Njerts
126
Drives: x3 m40i
That is a good price.
      07-18-2018, 08:33 AM   #101
jd__m4
jd__m4's Avatar
415
Drives: AY M4
So the vendor sent me some pictures and will be shipping the assemblies out today. From the pictures, they show stock Valeo xenon housings and Osram D1S bulbs/ballasts, all with BMW p/n's on them- these look exactly like the OEM housings.
Based on the reading I'm doing now, it sounds like I have to do a little work on the factory harness to get a ground to the ballast and swap the shutter on/off to the high beam socket. I'll continue reading up in preparation for the swap...
EDIT: also, the coding, which I've already coded some things with Carly, so that's not an issue for me.
      07-18-2018, 10:09 AM   #102
Njerts
126
Drives: x3 m40i
The ones I got was pin compatible with the halogen housing.
Just had to code off voltage monitor for high/low and angel eyes and then switch DRL to angel eyes.
      07-18-2018, 10:28 AM   #103
jd__m4
jd__m4's Avatar
415
Drives: AY M4
My plan is to first code out voltage monitoring for the lights and switch DRL to angel eyes, then plug in the new assemblies prior to installing to see if everything works as it should.
If not, then I'll have to troubleshoot and see if the harness needs to be re-pinned or tapped based on the findings from E90 swaps.
      07-18-2018, 11:00 AM   #104
Njerts
126
Drives: x3 m40i
Good plan, I got mine working 100% by just plugging it into the harness before installing.
      07-28-2018, 10:24 AM   #105
jd__m4
jd__m4's Avatar
415
Drives: AY M4
So I received my headlamps...with no LED modules for the angel eyes. I wrote to the seller, we値l see what happens.
      08-02-2018, 11:25 AM   #106
jd__m4
jd__m4's Avatar
415
Drives: AY M4
So, the seller admitted they made a mistake, however wouldn't budge on supplying the led modules, or giving me a partial credit. I've filed a dispute with Alibaba, but I'm not counting on getting anything out of it. In the meantime, I purchased the led modules on ebay for a total of $150 (6 in total), bringing my total cost to $750.
While I'm waiting for those to come in, I wired up the xenons and tested them, and all is well- bi-xenon functions fine, shutters kick in when hi-beam is engaged, blinkers work. I haven't done any coding yet, which will be done once the modules come in and I can test the angel eyes.
      08-04-2018, 03:20 AM   #107
Danny174
Drives: BMW X1 E84 S Drive 18d
Hello there people, I have a question, I have a BMW X1 2010 with halogen headlight assembly, my question is if I purchase a BI Xenon headlight assembly with the matching part numbers compatible for my car would this then just be plug and play to fit maybe with a bit coding?
Thanks Daniel
      08-04-2018, 02:52 PM   #108
jd__m4
jd__m4's Avatar
415
Drives: AY M4
Thanks Daniel
The OEM Valeo bixenon headlamps will require some changes to the wiring as the pin outs don稚 100% correspond. Aftermarket headlamps seem to address this and are plug and play.
      08-07-2018, 04:41 AM   #109
Danny174
Hello there thanks for your reply, I値l probably look into a plug and play version, I came across these https://eurowagens.com/angel-eyes-he...-x1-e84-09-12/ they have the angel eyes and projectors but use halogen bulbs for high/low beams. I知 thinking these may be slightly cost effective for me.
      08-07-2018, 07:56 AM   #110
jd__m4
jd__m4's Avatar
415
Drives: AY M4
Seems like a good deal, but those look like projector lenses, so you may be able to put xenons in there and not blind oncoming traffic.
At the least, you can probably throw some LED's in there- that'll be a nice improvement over halogens. You'll just have to code out the voltage monitoring if you don't want it to give you a warning every time you start them up.
xbimmers
