Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Turbo leak? Crankcase breather leak?? Help! M57 330d
      10-21-2018, 09:14 AM   #45
blueh88
blueh88's Avatar
69
Drives: 2006 330d M Sport Auto
Originally Posted by MrSweet1991 View Post
Originally Posted by blueh88 View Post
Right, all done. At the same time I blanked off the EGR cooler. Just a job I was meaning to do for a long time. EGR was already blanked and coded out.
I guess it's just a matter of checking in a few days see how it goes. There isn't any notable difference at this moment.
What about tbe Oil Dipstick vapours, have they gone once the engine has warmed up?
Nope, no change in that. Exactly the same as before. I wasn't expecting that to change though, I'm more concerned about the leak/oil usage.
Cosmetics: 18" Axes CS Lite Wheels in Shadow Chrome, Custom Headlights (KYCS)
Mechanical: Hybrid Turbo, Wagner Intercooler, Ecotune Sports Downpipe, Ecotune calibration (350bhp/745Nm), xHP Stage 3, Bilstein B12, M3 front control arms, Quaife LSD
Audio/Visual: Xtrons 9" Android headunit, Match 8" underseat subs, Vibe 4" door components, Pioneer 4 channel amp, reverse camera
      10-21-2018, 10:15 AM   #46
RS DAVE
101
Drives: E91 335D M SPORT
To be honest I don't know much about the turbo build i just assumed when they said seals they meant the "piston like ring" you mentioned which I thought is what stopped the oil passing through (like one of the piston rings on our pistons would to) as can be seen at 2:30 in this video?
https://youtu.be/LZpstRZI7LQ
Thats the one, every one thinks turbo's have oil seals, can you imagine how long an oil seal would last at exhaust gas temperartures'?? the problem you are experiencing is down to crank case pressures i explained this to the other guy on the phone the other day. more boost bigger crank case pressure, simple.........
      10-21-2018, 11:09 AM   #47
MrSweet1991
MrSweet1991's Avatar
130
Drives: BMW E90 330D M Sport
Hi Dave,
Truth be told I don't understand that area enough to imagine things like that, its why I asked so that I could understand it better so I appreciate the information. Out of curiousity though, how does the increased boost pressure cause the vapour when I leave the car to warm up? My vapour occurs regardless of whether I drive it or not so boost pressure wouldn't factor.in yet would it?
      10-21-2018, 11:29 AM   #48
Andy198712
147
Drives: 2010 E91 325d
Pulled my dipstick out today while running and same, but pretty sure it’s just steam from any moisture in the oil
      10-21-2018, 12:58 PM   #49
blueh88
blueh88's Avatar
69
Yep was very much appreciated - thanks.
      10-21-2018, 01:02 PM   #50
blueh88
blueh88's Avatar
69
Hi Dave,
Lets not get the two things confused: the white vapours are going to be there regardless. Lets say it's just a characteristic. With regards to higher pressure, that is what is giving the increased oil consumption due to the lack of any oil/air separation within the breather assembly.
Put it this way, if you drive around off boost, your oil consumption/leakage will be minimal. When on boost, that's when the oil consumption/leakage will increase.
      10-21-2018, 02:11 PM   #51
RS DAVE
101
Simple hold you hand or a piece of kitchen towel over it and see what is there, easy if it's wet it's condensation if it's greasy it's oil. but all engine's make condensation, the more plodding round town and not being used out on the open road the more they make.
      10-21-2018, 02:16 PM   #52
RS DAVE
101
Hi Dave,
what happens to any oil you heat up? you get vapour. look at a frying pan.... go in a chippy.
      10-21-2018, 02:31 PM   #53
RS DAVE
101
Like i explained the other day you have to know what boost has been programmed in, when we were doing the cozzys they would take 15psi on a standard breather, you start pushing 25psi they start pushing the cam seals out. mine peaked at 36psi and held 29psi or 2 bar. it had a top spec R breather system. this is the shit mappers don't tell you. every one wants the bhp but with it comes consequences.
      10-21-2018, 02:58 PM   #54
blueh88
blueh88's Avatar
69
Yep. We are in agreement, just saying it in different ways
      10-21-2018, 03:26 PM   #55
Andy198712
147
mines mapped to 290 and used no oil i can detect in my 10k intervals i change at....
      10-22-2018, 12:36 AM   #56
rasa bmw
243
Drives: 640d sport/f31 330d x drive
too true,,like the torque benders,,thus is one of the reasons i went to bwchiptune for my remap on my 335d
      10-26-2018, 07:12 AM   #57
blueh88
blueh88's Avatar
69
Right, it has been a few days with the new vortex separator installed...so far, no oil usage. I have been checking the dipstick every morning on the drive so same conditions each time and the level hasn't moved whatsoever. I will be keeping further track of it and I will be inspecting the breather pipe too to see what oil if any is in there. I cleaned it out when I fitted the new vortex.
So far so good.....
      10-27-2018, 12:26 AM   #58
rasa bmw
243
So far so good.....
forgot to say,,the guy who srviced my 335d said if breather leaks put a cable tie on the joint..
      10-27-2018, 02:47 AM   #59
blueh88
blueh88's Avatar
69
So far so good.....
Yeah I've not had to do that as it hasn't ever leaked from that joint. May put one just in case..
      10-27-2018, 05:22 AM   #60
MrSweet1991
130
Hi mate,
Since putting the vortex on has it made any difference?
      10-27-2018, 05:50 AM   #61
blueh88
blueh88's Avatar
69
Hi mate,
Hey mate.
Well it has definitely reduced if not eliminated the oil usage so therefore the oil leak I was experiencing at the bottom of the turbo clean air intake pipe. I'm still keeping an eye on it so fingers crossed.
      10-27-2018, 10:45 AM   #62
dragerboy
84
So is this what you mean by Vortex breather? Name:  20180919_120038_crop_317x310.jpg
      10-27-2018, 10:57 AM   #63
blueh88
blueh88's Avatar
69
Originally Posted by dragerboy View Post
So is this what you mean by Vortex breather? Attachment 1925233
Yep that is it.
      10-27-2018, 03:48 PM   #64
dragerboy
84
Maybe I will put it in mine now. I left it out because the old breather I removed had nothing in it.
      10-28-2018, 03:42 AM   #65
rasa bmw
243
the older one is even begter,,ie loo roll filter,,just have to take out and replce now and again,,or clean it etc
      10-28-2018, 12:41 PM   #66
MrSweet1991
130
Hey mate.
That great news, so how much oil was you losing before the vortex? Mines on the more extreme side of 1 litre per month (around 1000 miles)
