03-12-2016, 01:21 AM | #23 | ||
1722
Rep 5,110
And how do you know this isn't done on the S55? Yes, both cold and hot blowing will work on a turbo engine. Keeping gas flow high also under off throttle situations by not shutting the throttle. Just as Porsche has confirmed they are doing... |
03-12-2016, 01:27 AM | #24 | |
1722
Rep 5,110
I've been in this dyno room and seen a prototype of that engine running |
03-12-2016, 01:37 PM | #25 | |
707
Rep 886
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
03-12-2016, 03:31 PM | #26 | |
1722
Rep 5,110
The ECU can't "force excessive amounts of air through the engine". In fact the only thing the ECU can do is keeping the throttle open and retard ignition timing (and inject fuel if "hot blowing" is employed). A internal combustion engine is basically a air pump. The exhaust flow that created downforce by "cold blowing" is dependant on two parametres: RPM and throttle opening. For "hot blowing" it's three parametres: RPM, throttle opening and fuel injected. By keeping the throttle open on the overrun, the engine keeps pumping just the same amount of air as it was doing when on throttle. As RPM decreases, so does the volume of air (per minute) the engine pumps out via the exhaust. But if the throttle was closed, it wouldn't pump any air at all... It was this fact that was used in the F1 engines. At any given rpm and any given throttle opening, the engine pumps just the same amount of air regardless of whether the car is accelerating or decelerating. As long as the throttle stays open, the engine just keeps on pumping that air through to the exhaust manifold. Thereby keeping exhaust flow sufficient to either have an effect on the diffuser (F1) or on the turbo (S55 and 911 Turbo S) Introduce some fuel and the velocity of the air in the exhaust system increases. Thereby increasing the effect of the exhaust (either on the diffuser on the F1 cars, or on the turbo). The Porsche 911 Turbo S does EXACTLY the same to the exhaust flow to the turbo as what "cold blowing" did to the exhaust flow to the diffuser in F1. It keeps the throttle open so that the engine still continues to pump air and thereby the turbo spooled. There is no way the ECU can force more air through the engine than it's mecanically capable of though... Last edited by Boss330; 03-12-2016 at 03:37 PM.. |
03-12-2016, 04:26 PM | #27 | |
707
Rep 886
That being said, of course the ecu cant force more air through the engine than it's mechanically capable of. What you were incorrectly referring to was when I was mentioned the ecu can go through different protocols to keep blowning air (through the engine/turbo) at an accelerated rate while off throttle... Now if you mean that we could theoretically modify the S55 anti-lag setup by injecting fuel (as you say the new 911 turbo does), that is potentially possible once the tuning is available to support that. I do question why you would want to do that though, is the S55 anti-lag not sufficient for you?
03-12-2016, 05:11 PM | #28 | ||
1722
Rep 5,110
We are speculating if the anti lag on the S55 is similar to the method used in F1 when they had the blown diffusers. Further we are speculating if the S55 uses cold or hot "blowing" to keep the turbo spooled. No modifications. Just trying to understand how the S55 anti lag works. I think this was pretty clear from the OP... Now we recently got confirmation that the latest 911 Turbo S employs cold blowing (confirming my original theory in the OP about a possible anti lag method). Exactly what kind of "protocols" can the ECU use to keep up exhaust flow at "an accelerated rate"???? Apart from the ability to control the throttle opening (cold blowing), and injecting fuel while under off throttle scenarios with throttle open (hot blowing). Which is exactly what was explained in the OP... Remember that the exhaust flow isn't accelerated neither during hot or cold blowing compared to what it is while under throttle... Hot or cold blowing is just a method to maintain a portion of the exhaust flow the engine had under acceleration instead of stopping it as it would with a closed throttle. |
03-12-2016, 05:34 PM | #29 | |
707
Rep 886
Why does it even matter if the S55 anti-lag is similiar to the F1 blowing tech, it's not like we could additionally leverage that knowledge to a potential advantage in our cars. Again, misinterpreting what I was saying about "ecu protocols". What I said was the the S55 engine computer KEEPS the turbines spinning at a medium/high rate of speed in off throttle events, THAT is the protocol I am referring to (compared to a standard turbo engine, that does not do this) I do not have specific knowledge to whether hot or cold blowing is employed on the S55, but again, even if it was either hot or cold blowing, so what?? I would assume cold blowing is used as hot blowing creates a ton of heat in the engine and exhaust, something that is not sustainable over time in a production car...probably why porsche adopted cold blowing (as you mentioned)
03-12-2016, 05:53 PM | #30 | ||
1722
Rep 5,110
The whole point was to point out a possible anti lag method. One we later have learned is used by Porsche. There was quite a bit of discussion when the F8x was launched about what was meant by "pre tensioned" turbos. So this thread was an attempt at explaining one possible method that could be used. It's not about "using it to our advantage" (Even though a tuner could do just that by having a more agressive setup on throttle opening and/or fuel, like the M4 GTS most likely has). It's just a discussion about a possible method for anti lag in the S55. Some people, like me, want to understand how technology works. Others don't. Simple as that. Some people are happy about not knowing how a DCT transmission works as long as it shifts how it's supposed to. Others also want to find out how the double clutch system works. This thread was for those that wants to know how stuff works... |
03-12-2016, 07:23 PM | #31 |
184
Rep 760
Wouldn't it be easy to tell which is employed through logging? I don't know about BMW platforms, but when I had an Audi with VagCom, I could log throttle position.
14 Audi S4 (sold)
16 BMW M3 (sold) 16 VW Golf GTI (sold) 20 Tesla Model 3 23 Audi R8 (on order, never came ) |
03-12-2016, 08:55 PM | #32 | |
163
Rep 387
From my experience driving the car, I think the car does cold blowing and hot blowing depending on the situation. Sometimes when you lift halfway, you'll get a humming sound, this seems more like cold blowing to me. When you lift abruptly around 3-4k rpm, sometimes you get pops and bangs, that's definitely hot blowing. It feels like every other cylinder is getting fuel when this happens, which was why I was saying how Porsche says they "interrupt fuel injection" could be interpreted as cold blowing or hot blowing 50% cylinders. I have active sound turned off and valves open, so these things are easier to hear. It's interesting to compare to F1 because Mercedes hot blows 50% cylinders and Renault cold blows, but they are blowing it for an entirely different reason. |
03-13-2016, 04:05 AM | #33 | ||
1722
Rep 5,110
The throttle valve on a valvetronic engine is just part of the equation... If valvetronic is at minimum lift, then the throttle valve being open doesn't make any difference... BTW. It was on page 1 of this thread datalogging was brought up. Not on a different thread. |
06-19-2016, 06:52 PM | #34 |
157
Rep 1,046
Was anyone able to unearth the specifics of the S55 system?
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport |
06-21-2016, 11:46 AM | #35 |
47
Rep 210
That McLaren MP4/7A is blowing INTO the diffuser.....
Obviously that design didnt stick around too long Last edited by d k; 06-27-2016 at 07:39 PM.. |
06-21-2016, 02:55 PM | #36 | |
1722
Rep 5,110
Do you mean the F1 cars with blown diffusers? It only disappeared due to being banned in the regulations. BTW, this thread isn't about the aero advantages (downforce) that the F1 cars gained from the blown diffuser. But how the same engine mapping can be used as anti lag on a turbo engine. |
06-24-2016, 03:11 AM | #37 |
49
Rep 111
I think OP's observation is spot on. There might be other ALS tricks, for example another way of hot blowing the turbo:
The guy also talked about ALS through ignition timing, which has been mentioned in the thread. Last edited by Skid123; 06-24-2016 at 03:29 AM.. |
06-27-2016, 07:41 PM | #38 | |
47
Rep 210
Sorry MP4/7A
I was just commenting how the exhaust was blowing under the diffuser, which isn't exactly the best way to create a low pressure area. Quote:
06-27-2016, 08:13 PM | #39 | |
21131
Rep 20,742
Drives: 2021 911 turbo
The point of the diffuser is not create a low pressure area at the diffuser itself, but rather to leverage the low pressure area behind the car to accelerate the flow under the car. When air flow velocity is increased, pressure is decreased. The low pressure area is upstream of the diffuser. Injecting the exhaust gases serve the same purpose where the exhausts act like a "jet pump" accelerating the air flow under the car.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 06-27-2016 at 09:44 PM.. |
06-28-2016, 04:38 PM | #41 | ||
1722
Rep 5,110
