01-16-2021, 05:13 AM | #46 |
BMW Novice
69
Rep 237
Drives: M Coupe
Can someone explain what "loudness from E86 to E85" means?
01-17-2021, 04:27 PM | #48 | |
BMW Novice
69
Rep 237
Drives: M Coupe
Alright, thank you. Just had a guy code my amber DRLs off and why I was interested in the coding. Will post pictures soon.
01-17-2021, 04:48 PM | #49 |
886
Rep 2,551
Drives: Z4MC-X3-35i-525i, Corrado G60
01-17-2021, 11:45 PM | #50 | |
BMW Novice
69
Rep 237
Drives: M Coupe
Wasn't apt enough to di it myself
04-09-2021, 08:48 AM | #51 |
74
Rep 264
So I finally decided to take a crack at coding, and was able to enable some neat features on my Z4M successfully. However, the main reason I decided to attempt this finally is my OC3 mat has kicked the bucket, and I was informed BMW will not cover replacement (my build is 05/2006).
After a lot of online browsing, I thought I found all the options to adjust, but am still coming up with the error 93C3. After updating the coding using NCSEXPERT, it corrects the error for about a minute then triggers again. Any ideas? Here is what I am showing coding wise, OC3 mat is unplugged ABG module Seat Occupancy Detection (SBE1) - nicht_activ Seat Occupancy Detection (OC3) - nicht_activ Delay Seat Occupancy Detection - nicht_activ Passenger Seat Belt Warning Sensor - nicht_activ Passenger Seat Belt Warning - nicht_activ Gk/OC3/POL_1 - nicht_activ I clearly am missing something. Any thoughts?
2017 M2 - Camber Hubs, MPE, and some other goodies 2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s 2004 Z4 3.0i - Gone, but not forgotten! |
09-08-2021, 11:33 PM | #53 | |
28
Rep 161
07-30-2022, 11:57 AM | #54 | |
19
Rep 86
Drives: 3.0si Coupe
10-05-2022, 06:36 PM | #55 |
Rep 17
Where could I find a description of the module and ecu abbreviations used for coding? I want to do a couple things such as change the RPM of the engine at startup, comfort closing, etc. but not sure which ECU/Module to select based on the short abbreviations in the NCSExpert/Dummy programs.
I did find a video online that had a walkthrough of the abbreviations and took screen shots. So this gives me module names. Still looking for ECU descriptions. Last edited by Vin Man; 10-05-2022 at 07:30 PM.. |
03-20-2024, 01:46 PM | #56 |
Rep 1
Hi there!
I'm a newbie to the forum and quite a newbie to the E85 platform but I love it! Since I own the USDM car I have to perform some modifications to legalize it in the EU. The main concern now is the rear fog lights (tail lights are replaced with EU ones, front - with halo aftermarket). I have the light switch module with the front fog light button only. I know it is used as the backup storage for various car data so not plug-and-play replaceable. Has someone tried to replace the light switch module and reprogram it using the manual from the thread? I assume the data from the original module should be written to the new one and the main ECU should be programmed to recognize the rear fog light option. Do I have to rewire/add some wire in addition to the reprogramming? Any hints would be greatly appreciated! |
