03-10-2019, 05:00 PM | #1 |
78
Rep 169
Is the bottom section of the door card made from hard plastic?
I saw briefly in a review video that the reviewer mentioned that the bottom part of the interior doors below the armrests are now hard plastic. In the past, every single 3 series has always had soft Sensatec covered bottoms. Can anyone in the US verify if the doors are hard plastic on the bottom or are they upholstered with Sensatec, as has been the case in the past.
I certainly HOPE BMW has not cheeped-out and decided to put in ugly, hard plastic on the bottom of the doors. I may refuse my order if that is the case. That is inexcusable in a car that I'm paying ~54k for. |
03-10-2019, 07:08 PM | #2 |
Ring Leader of G8X Haters
25136
Rep 8,768
Wasn't the bottom of the F30's doors hard plastic as well? I've never owned a F30, but I know that they've been criticized for having cheaper materials than the E90. Anyways I don't pay attention to the materials at the bottom of the doors so I wouldn't really know.
03-10-2019, 07:19 PM | #3 | |
5118
Rep 6,327
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
03-10-2019, 07:31 PM | #4 | |
101
Rep 348
03-10-2019, 07:59 PM | #6 |
78
Rep 169
Can anyone confirm that a US spec car has the hard plastic. It is NOT an area you hardly see, it is comprised of most of the surface area of the door. Basically, the arm rest and above is leather and all below is hard plastic. It's not a minor issue, I can assure you. If it were a Toyota Camry, Honda Accord, etc. then it may be an acceptable material. However, not in a car that STARTS at 40k.
No 3-series in the past has EVER had the hard plastic doors. I am exceedingly disappointed in this. |
MT4life575.50 blinkme323510.00 |
03-10-2019, 09:29 PM | #7 |
25136
Rep 8,768
Theres not many G20 owners yet it seems, your best bet would be to sit in one at whatever dealer nearby has a G20. Another option would be to PM an owner of a G20 on here, there are 2 posts of owners on here I believe.
03-10-2019, 11:44 PM | #9 |
393
Rep 487
Door Panel Trim: Soft Touch Plastic or Hard Plastic?
4:04 and 25:46 - Based on how reviewer touches the door panel trims below armrest, it seemed to be soft touch plastic instead of hard plastic?
03-11-2019, 12:05 AM | #11 |
688
Rep 429
So yea...it ain't the soft touch material but honestly it doesn't detract from the overall feeling of quality IMO. I've never had doors on a BMW close as solid as this car and all of the haptics and lighting are done really well.
joca107.50 |
03-11-2019, 01:10 AM | #12 |
2003
Rep 2,499
Is the center console at least soft touch now? IMO, if they made the lower part of the center console soft touch and the lower part of the door panels hard plastic, that'd be a worthwhile change. If they're both hard plastic, it's a bit disappointing.
hans007604.50 |
03-11-2019, 01:19 AM | #13 |
605
Rep 1,077
pretty sure it was all plastic in my F30 as well, I put all sorts of drinks and items in there over the years and I'm fairly certain I'd have noticed if it was soft touch
http://3.bp.blogspot.com/-MiFkMb4FnF...0_Sport_47.jpg Looks plastic in this pic of a 2012 |
03-11-2019, 01:26 AM | #14 | |
2003
Rep 2,499
03-11-2019, 01:57 AM | #15 | |
605
Rep 1,077
03-11-2019, 11:51 AM | #16 | |
19
Rep 31
Just checked a G20 in my showroom. The lower door cards are a harder plastic but it's not offensively hard. Not squishy like the F30 lower door cards (the door pocket is also not carpet-lined like it is on F30) The centre console sides are also hard plastic, but I think this is pretty standard for this class and was the same on F30. The places you DO actually touch are much nicer than F30 though and you can tell thought was put into this interior. |
Jmpascual687.50 |
03-11-2019, 12:03 PM | #17 |
BMW Client Advisor
3459
Rep 2,504
Drives: 2020 M340i
I just checked an F30 and a G20 and they feel the same to me.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
03-11-2019, 12:04 PM | #18 |
79
Rep 126
I don't know about the plastic, but the G20 has an insanely comfortable cabin. Even if it's hard plastic at the bottom of the doors, I have a feeling that won't be enough to take away from the rest of it.
03-11-2019, 01:43 PM | #20 |
688
Rep 429
I can't tell the difference between the softer plastic up top unless I press into on the bottom plastic. There's no other perceptible difference.
03-11-2019, 04:44 PM | #21 |
2003
Rep 2,499
My right leg rests up against the center console a lot. They should at least make that part soft touch, especially for more spirited driving. One side benefit of this cheapening is that the plastic is probably lighter.
There is definitely a difference in appearance, though. Hard plastic shows scratches much more easily. |
03-11-2019, 05:06 PM | #22 |
5118
Rep 6,327
There is a definite, perceptible difference between the soft touch material and hard plastic. The 2er uses hard plastic and you can tell by dragging your fingernails across it. If you can’t tell a difference between the material used in the F30 and the G20 that says to me they have used the soft touch material on the G20. The softness of the soft touch plastic is subtle, but when compared to the hard plastic in a 2er the difference is evident.
