FS: Titan7 T-S5 18x8.5 Wheels & Nitto NT05 245/40/18 Tires for BMW F22 or F30 |
04-23-2024, 05:03 PM | #1 |
Rep 40
Square 18"x8.5" Set +44mm Offset 5x120 Bolt Pattern 72.5mm Center Bore 245/40/18 Nitto NT-05 tires with ~5mm tread all around BMW TPMS Installed/Included Center Caps Included I ran these on my 2015 F22 M235i with a 10mm spacer in the front and 5mm spacer in the rear. The same set up should fit F3X 3/4 Series. These should also fit the FK8 and FL5 Honda Civic Type R, not 100% on that, you should check for yourself if buying for your Honda. Everything pictured would cost you brand new: Wheels - $2340 Center Caps - $116 Tires - $800 TPMS - $464 Located in Heath, TX (DFW area). Feel free to email me at timsgt153624@duck.com in case I forget to check this post. Link to more images: https://drive.google.com/drive/folde...3h?usp=sharing Last edited by TIMSGT; 05-10-2024 at 11:09 AM.. Reason: Adding Photos |
04-30-2024, 12:18 PM | #3 |
262
Rep 518
https://www.2addicts.com/forums/show...t=titan&page=8
Look around in these thread, there is a few of them. I would be interested if these are closer to LA. They are made to order in our sizes I believe and are always out of stock unfortunately |
