12-04-2011, 09:13 AM | #1 |
61
Rep 234
The Best $ 599 Exhaust Mod
Yesterday Installed the Berk Resonated Midpipes.
If you're not quite ready to pull the trigger or can't decide on a new 6k exhaust, I highly recommend this pipe either as a interim solution or as a permanent mod. The sound is actually not as loud as I expected. Deeper sound with more gurgling when downshifting. This is the sound the car should have had from the factory! |
12-04-2011, 09:34 AM | #3 |
61
Rep 234
Yes, you re-use that bracket and Berk gives you a slightly longer allen bolt to use in place of the factory bolt because the diameter of the pipes are larger than the factory pipes. I'll have to work on the video!
12-04-2011, 01:15 PM | #4 |
66
Rep 308
Was curious if there was any weight savings?
2024 X3 M40i
2011 1M Coupe VO (Sold) 2015 MB GLK 250 Blutec Deez (Sold) 2001 S54 M Coupe (Sold) 1998 M3/4 (Sold) |
12-04-2011, 08:17 PM | #7 | ||
61
Rep 234
HP Autowerks weighed both and said there was a 7.1 lb savings vs stock.
Most everything I have read puts gains in the 10-15 hp range. |
12-04-2011, 08:26 PM | #8 |
336
Rep 1,590
Without a tune you really won't see much power, the guys at Berk say you will make the same power but at a lower boost level. With the tune you unlock some power. However I did the tune before I did the Berk mid pipes. I highly recommend this mod to anyone that is thinking about it.
12-04-2011, 09:02 PM | #10 | |
61
Rep 234
I don't know but - If you make equivalent power at a lower boost level - that sounds like an increase to me? It's early but my initial feedback with the butt dyno is some more power, (I know that's subjective), a little more turbo whine and a slightly more responsive engine (less lag). All good. |
12-04-2011, 09:27 PM | #11 |
398
Rep 9,156
12-04-2011, 11:28 PM | #12 |
377
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
video!!!!!!!!
12-06-2011, 07:45 PM | #14 |
Rep 258
12-07-2011, 09:35 AM | #15 |
Rep 83
Gator-- Can you comment on this installation's effect [if any] on the 2200-2800 rpm DRONE that so many 1M's have ?? Dit you have the drone before installing the pipes, and did it change the drone any ??
Thanks, Joe B [aka oldbmwguy] |
12-07-2011, 11:06 AM | #16 |
450
Rep 1,358
HP Autowerks posted a while back. Berg midpipes is the only change. I bought some based on this vid
http://www.youtube.com/embed/nvhKObY...de=transparent |
12-07-2011, 12:37 PM | #17 |
27
Rep 131
Will my car still be California smog legal with this mod? I just installed the magnaflow cat back system and am very happy with it for the same price, approximately $600 but during the install when the car was up on the lift the mechanic was telling me the mid pipes are the ones you want to change out. What is the estimate on the install time?
12-07-2011, 07:17 PM | #18 |
734
Rep 3,274
I know I don't have a 1M, but I have the full catback Berk Sport exhaust on my car and I absolutely love it. Berk is a really great company and I stand behind their products 100%! Contact Bryan through the forum (user name BerkTechnology) and I'm sure he'll give you guys great prices!
And the cats in the midpipes are NOT required to stay emissions legal in any state, as long as you have the stock downpipes, at least on the 135i. Unless the engine tuning in the 1M produces a whole lot more smog, which I doubt, I don't think anyone would have an issue. Electronically, there is no issue, as the sensors are only in the downpipe cats and not on the midpipes. They're completely bolt on, so very quick to change out. Less than an hour. A friend and I did this in about 30 minutes, and that was taking our time. Robertm, for some reason the sound on that clip isn't working for me. It's working for every other youtube video though. Maybe it's just my computer? I'm curious to hear what the midpipes sound like on the 1M.. Here's a video of my car with the pipes. Same stock downpipes as 1M, plus the Berk sport muffler instead of the quad M exhaust. Only other mods at the time were a JB+ and an intake, so I'm thinking the sound should be pretty similar:
2022 X4 M40i - 2008 135i - 2015 F700GS On Order - 2024 i4 M50 Scruffy's gonna die the way he lived... Mmhm. |
12-08-2011, 01:18 AM | #19 |
31
Rep 148
So does it make the exhaust that much louder? What kind of warranty issues does this create. Is this a slightly less intense mod than changing the downpipes in terms of that?
12-08-2011, 01:46 AM | #20 |
156
Rep 4,995
Changing midpipes is like 10x easier then DP !
My car actually got quieter after swapping my stock mids without resonator with resonated midpipes. This is only during normal driving when you go WOT is slightly louder or about the same as before. |
12-08-2011, 07:36 AM | #21 | ||
61
Rep 234
I did have the drone between 2200-2600 and it my initial reaction is it is definitely less (this was around town driving) - I will be on the highway this weekend so I will report back Quote:
I am not aware of anyone denying a warranty claim for a midpipe change. The dealer would have to prove that the midpipe change was the reason for the warranty claim. It is downstream of the primary cats so you will not have any CEL light issues. This is MUCH easier than installing DP's! |
