05-17-2014, 11:24 AM | #23 |
95
Rep 809
Drives: 2014 228i Msport
My 228I is ten times worse than my 128. Having car and wheels opti coated today
A peasant and proud of it
Save The Manuals!!! |
09-23-2014, 04:38 PM | #25 |
Rep 77
Has anyone swapped out to low dust pads?
I've been searching the f30 threads and various websites and have not found much choice. I had some Akebono's ceramics on my e46, they were great and lasted forever--I'd love to find somethings similar. I'm more worried about dust than performance. I guess porterfield will make r4-s pads for our cars if you call.
2014 m235i->present: EB, Black, Hex trim, Cold, Premium, Tech, MT, sunroof delete: June 2014 euro delivery.
2001 330ci: 2005->2014 sold and already missed. 1989 325is: 2010->present s52'd - track car 1991 318is: 2013->present taking up space |
12-30-2014, 10:55 PM | #26 |
267
Rep 554
Centric PosiQuiet are great low dust, high performance street pads. I have them on my Carrera and will likely get them on my M235. I get them at Zeckenhausen, BMW brake specialists.
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
01-03-2015, 05:02 AM | #27 |
30
Rep 138
I noticed the large amount of brake dust. Im not planing on changing pads though. Any suggestion on how to keep the wheels clean? i dont have a hose so i cant wash them regularly, i guess i can wipe them with a MF towel often, but i dont want to have to go through rags so fast
01-03-2015, 09:28 AM | #28 | |
3076
Rep 5,577
Ideally it's nice to uses a pad or brush to wipe the barrel, tricky parts and calipers- no self service car washes where you can sneak in a bucket wash ? |
01-03-2015, 09:48 AM | #29 |
267
Rep 554
If you coat your wheels (inside and out) with a heat resistant sealant, and wash every week or so, you won't need to use wheel cleaning chemicals at all. And the dust will stick less.
No expensive products are required. (Resist the marketing hype) If you use a sealant on your paint, use it on your wheels, too. Even the cheapest polymer/nano sealants on the market are perfectly fine and you will see the results. Carnauba-based waxes don't have the durability or heat resistance to be of real long term value so skip them. Wash your wheels with the same car wash you use on your paint. I put a bit of it in a spray bottle and just squirt it on. If you use wheel cleaners you will just degrade the sealant you so lovingly applied to the wheels. As a detailing fanatic I shoot for perfection. And this process will make your life so much easier. And save you some money on wheel cleaners you can apply elsewhere on more fun car stuff.
The Stable
01-03-2015, 10:49 AM | #30 | |
103
Rep 1,254
01-03-2015, 11:13 AM | #31 |
3076
Rep 5,577
I don't know that sealants have greater heat resistance then carnuba. Many times organic matter is added to inorganic's to provide UV and heat protection.
P21 is a quality surfactant and lower surface tension is more relevant then nanotechnology for wheel care. |
01-03-2015, 12:21 PM | #32 | |
1403
Rep 5,262
they even have the full effect plus they say it's 30% stronger.... the beauty about this stuff is that you just spray, wait, rinse and the dust is gone..no wiping or brushing... |
01-04-2015, 06:07 AM | #33 |
70
Rep 552
I have not noticed at all maybe because I live in the desert country of Bahrain LOL!
2014 M235i {Dinan P1 Power Package}
2015 F30 320i 2006 E90 2004 C240 97 E39 VF5 Supercharged |
01-04-2015, 03:28 PM | #34 | |
127
Rep 765
If you have a coating (opt-coat, UK quartz, etc), do not use Sonax! It can may affect the treatment.
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
01-06-2015, 03:49 PM | #35 | |
526
Rep 1,078
01-06-2015, 10:27 PM | #37 |
127
Rep 765
Definitely do NOT let it dry! For heavy dust, I wait about 30-60 seconds, then agitate with a brush. Spray off immediately after, rinse completely.
02-06-2015, 02:42 PM | #38 |
Rep 2
Armor All Wheel Protectant works great until the wheels get wet. I have the brake dust issue on both my X5 and Jaguar XK. Dust-free until the next wash.
Swear by the stuff. Amazon sells it for about the same price as Walmart. Meguiar's makes something similar Hot Rims Brake Dust Barrier Haven't tried that yet. Last edited by racerx5; 02-06-2015 at 02:52 PM.. |
02-14-2015, 06:25 PM | #39 |
Mess Deck Commando
244
Rep 807
02-14-2015, 06:42 PM | #40 |
103
Rep 1,254
Has anyone used sonax with a regular hose and not a power washer. I feel like the power washer helps with removing the brake dust because of the high pressure. I would think most of us just use a regular hose to wash are cars and wheels.
02-14-2015, 06:49 PM | #41 | |
3076
Rep 5,577
Anyway a sponge will knock out whatever a power washer might have dislodged. |
02-14-2015, 07:06 PM | #42 |
1403
Rep 5,262
regular hose will do just fine..... it's just to rise... the product does all the work as long as you apply it where the brake dust is....
02-15-2015, 08:51 AM | #43 |
Mess Deck Commando
244
Rep 807
+1 with both ScottSinger and pikcachu. I should have stated my personal belief too about the use of high pressure washers on the car period. A garden hose with a nozzle of sorts is plenty. With that said, be aware too that if you use car washing stations (self or full-service), not to use the high pressure mode or ask the attendant not to use their pressure washer on your wheels.
