BMW
X7 and XM
forum
BMW X7 (G07) Forums General BMW X7 Forum 2023 X7 trim starting to discolor
      01-17-2023, 11:01 AM   #1
coolerbythelake
coolerbythelake's Avatar
282
Drives: 2024 X7 M60i
Hi everyone,
Almost at 3,000 miles now on my 2023 X7 and everything has been perfect so far - until today. I was driving around and I don’t know if it was just perfect lighting or what but I noticed the wood trim around my shifter and click wheel is starting to discolor. It’s starting to turn black. I got home and took a better look and it’s every single piece of trim in the vehicle, front and back. I have the individual silver ash root open pore wood trim.
I called the dealer to make an appointment and they said to just bring it over; I’m going this afternoon. Any ideas? I can’t imagine it’s dirty but I tried a warm cloth anyway and it didn’t change anything. I’m kind of afraid of what the dealer is going to say. I suspect this will need to be replaced… but every single piece of wood in the car? Thoughts?
      01-17-2023, 01:01 PM   #2
workstation
15
Drives: (coming soon)
The wood trim you show looks like the Silver Ash Root Open Pore Wood, which is a gradient trim.
shameson164.00
      01-17-2023, 01:09 PM   #3
MystroX5
MystroX5's Avatar
6290
Drives: 2020 X7 M50i/ 911
I guess because the grain has not been sealed with a protective lacquer it could absorb contaminants and get damaged by UV light. It does look really grimy but I would think your environment would have to be really filthy for that to start to happen and highly unlikely. Your surrounding leather would look significantly worse if it were a dirty environment and it doesn’t. That fact alone says it’s a defect.
Hopefully this is a one off manufacturing defect. I would file a warranty claim.
      01-17-2023, 02:16 PM   #4
PinkNinja400Guy
506
Drives: '22 X7 M50
The online configurator lists "Color Gradient" under the name of the trim; it also shows the gradient on the dashboard piece of wood. The grading in your car looks too orderly and consistent to be caused by a defect.
      01-17-2023, 02:42 PM   #5
Ace6180G07
264
Drives: 2022 X7 M50i / 2024 X5 40i
Originally Posted by coolerbythelake View Post
Hi everyone,
Hey! Long time no hear. Do you leave this outside or in a garage? The only reason I ask is that it may be UV damage from the sun. It would make sense in those areas. Like the top of the wood on the door panels. And obviously any horizontal piece that the sun hits. Dash through the windshield and center console maybe through the roof or sun coming through the windshield and then hitting the back of the console for a little bit. Dash piece is at an angle so the top would get be exposed longer than the bottom of it.
Curious if on the next sunny day you have, look from the side window in at different times during the day. I want to say that you will probably find out that the sun is doing this.
Looks grimy. Like MystroX5 said. But you’re pretty particular with your vehicles so I highly doubt it’s dirt. It’s like when you leave a pine board outside in the sun it turns grey over time. If this is it then BMW should have thought of that.
      01-17-2023, 02:50 PM   #6
coolerbythelake
282
Thanks for the feedback and input. I took it to the dealer and they didn’t think it looked right, either; they took some pictures of their own and opened up a warranty claim with BMW so we’ll see what they say. I’m not too keen on having all of this torn up so a part of me hopes this is just how it’s supposed to be. It just really looks like it’s dirty and needs a good cleaning (which it doesn’t). Just doesn’t look right but I could be wrong.
This is a new trim so there’s not a lot of pictures out there. I have some from around delivery but the details aren’t in the right area. I found a couple more from then in sunlight (see attached) - it’s gorgeous and very evenly colored. If only I had captured a bit farther down in the pictures.
If anyone else out there has this trim I’d love to see some pictures to compare.
      01-17-2023, 02:57 PM   #7
coolerbythelake
282
That would make sense, but my car is kept in the garage - my garage is fully temperature and humidity controlled (I detail cars in there). I work from home and when I'm driving it's usually in the evening hours.
      01-17-2023, 03:10 PM   #8
MystroX5
MystroX5's Avatar
6290
Certainly you would think BMW would have done some testing on open pore wood to see how it ages without any protective lacquer??? No wants that “mildew/tarnished staining” look over time.
      01-17-2023, 03:37 PM   #9
nynd
175
Drives: X7 M8 Convert
Hopefully they replace, if defective. I hope they don't come back and say this is a natural wood product which will have environmental effects. Good start dealer is on your side.
      01-17-2023, 03:59 PM   #10
x7m60i
38
Drives: X7 M60I
I have the same trim and we see similar gradient effects as yours. Will post pictures later. Now I don’t remember what it looked like when first taking delivery.
      01-17-2023, 07:09 PM   #11
BMW5and7
1062
Drives: X7;X5;S-Class;Navigator
The question is, if it’s a material/design defect, why would anyone replace it with the same!? Wouldn’t that issue appear again unless they fix the issue with a new/revised part number?
      01-19-2023, 09:18 PM   #12
andykitty
156
Drives: BMW M2 Competition
I have the same trim, and it looks exactly like yours, so I don’t think it is a defect. And I actually kind of like how the color change from dark to light.
Appreciate 2
      01-20-2023, 11:09 AM   #13
xlover
No_Country
2191
Drives: 2023 X7 40i
my understanding was the open pore wood does in fact have a protective sealant coating on it, just not high gloss, but matte to match the unsmoothed wood look. Without sealant every interior would be ruined after the first rainstorm where a door was opened.
As far as i can tell, and i spent some time looking before i ordered, open pore does not come with different care instructions (like matte paint does which is missing the protective clearcoat)
I don't think BMW would introduce a product without protective sealant and not say something. Considering open pore is part of the standard offering it will be on many orders/lot vehicles for customers significantly less informed than his message board, the warranty claims would be off the chart if unprotected.
      01-22-2023, 01:36 PM   #14
BMW5and7
1062
coolerbythelake
Any updates? Just curious to know since this is my preferred color which I have on two vehicles now, and in future, I’ll again go with same color for trim. I have the one with gloss finish, but I may consider the non-gloss one in the future as a change.
      01-22-2023, 02:06 PM   #15
coolerbythelake
282
BMW5and7 I did, I heard from BMW Corporate this past Friday asking for a few more pictures. No confirmation yet but it’s all in review. I found a video on YouTube with my same interior color and trim and it all looks similar, as reported by a few here.
What was interesting is that BMW specifically asked for some more pictures of the trim running along the dash and wanted to see the one picture I have from when it was new. I took the car out in the sun again and took a few updated pictures and attached them (the same ones sent to BMW). Again, it could totally be the light and normal so we’ll see what they say. I work from home and don’t drive a whole heck of a lot during the day. We also don’t get a lot of sun this time of the year so this could all be me. But doesn’t it look a little different? Mystro used the right word, it looks as though it’s a little tarnished. This could be by design I suppose. I really like BMW’s lighter toned woods and I think I’d go with the glossy one next time.
      01-24-2023, 11:08 AM   #16
Taktix1
88
Drives: 23 X7 40i
I really love this trim (but didn't get it) so I'm sad to see this. But weirdly, in your first picture (the like new one) towards the bottom there's a dark streak. In your last picture, it appears that same dark streak is now lighter? That's pretty strange to say the least. Keep us updated on what BMW says.
      02-01-2023, 05:17 PM   #17
arciga18
arciga18's Avatar
1729
Drives: LeMans/ Chestnut E90, RWD
Need gossip updates please
      02-06-2023, 11:17 AM   #18
x7m60i
38
Drives: X7 M60I
Pictures from mine. These are taken in the garage with no light.
      02-06-2023, 11:36 AM   #19
coolerbythelake
282
I appreciate the pictures! I’ve been able to find a few pictures of it from dealer lots and what I’m seeing looks normal and like the others. I feel kind of dumb for not noticing until now but I just need to drive the thing more LOL.
The response to this from BMW has been pathetic. My local dealer has been trying to get answers but all they are able to get is just pictures which all look bright and not quite like mine. BMW corporate came back and basically said they’re not sure because of how new the trim is which is an unacceptable response. They’re sending replacement pieces to the dealer to compare. I know what I’m seeing is normal at this point but it’s just pathetic for the actual manufacturer to not be able to concretely confirm.
      08-05-2023, 10:55 AM   #20
Bimmerfun82
Bimmerfun82's Avatar
7197
Drives: M3, X7, MY
24 BMW M3  [10.00]
24 BMW X7  [9.00]
After all this, would you do it again or pick a different trim? We just put a deposit in and on the fence. Same atlas grey/white leather. We picked fineline black trim - do you all think that’s a good choice?
      03-24-2024, 07:57 PM   #21
mattsrs
624
Drives: X7
I know it has been a while. I just saw this thread and I wonder what did you end up doing? How is the trim holding up?
      03-28-2024, 07:43 AM   #22
coolerbythelake
282
It was normal and by design.
xbimmers
