03-31-2024, 06:37 AM | #1 |
Rep 21
Wanted coding for AIRBAG delete front seats (Recaro Pole Position)
I want to code out the airbag error for the seats (have Recaro installed in the front of a F80. Can someone confirm me the coding steps to do it with E-sys?
03-31-2024, 07:37 AM | #2 | |
BimmerPost Supporting Vendor
1801
Rep 3,070
We can help with it -> https://bimmer-remote.com/products/r...-for-bmw-supra
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
03-31-2024, 08:58 AM | #3 |
Rep 21
They are all out it only runs harnesses so no oem seatbelt or buckle.
I have found this coding: ACSM > 3000 > Sitzairbag_Thorax_Fahrer -> nicht_aktive ( was aktive ) ( this is the airbag for the driver ) ACSM > 3000 > Sitzairbag_Thorax_Beifahrer -> nicht_aktive ( was aktive ) ( this is the airbag for the passenger ) ACSM > 3000 > Gurtstrammer_Fahrer -> nicht_aktive ( was aktive ) ( this is the driver seat belt pretensioner ) ACSM > 3000 > Gurtstrammer_Beifahrer -> nicht_aktive ( was aktive ) ( this is the passenger seat belt pretensioner ) ACSM > 3000 > Gurtkontakt_Beifahrer -> nicht_aktive ( was aktive ) ( this is the seat belt contact for the passenger ) ACSM > 3000 > Gurtkontakt_Fahrer -> nicht_aktive ( was aktive ) ( this is the seat belt contact for the driver ) After this I disconnected E-Sys, opened Tool32 and did the following: File / Load SGBD ( F3 ) Select F01.PRG From the select Job: F01 window, select FS_LOESCHEN_FUNKTIONAL Select from main menu Job / Start Job once only ( F5 ) Would this work with my setup of full backets without original belt & buckle? Also, I don't have Tool32 is this step necessary or can it be done with E-sys or ISTA? |
