DIY - Amplifier/Sub Install for E92 with I-Drive
05-15-2019, 10:48 PM | #89 |
Rep 68
So I have the base sound system without a stock amp and I couldn't find the these wires
SUB LEFT Red/White + Brown/Yellow - SUB RIGHT Red/Blue + Brown/White - So my question is, what wires do I tap into for the sub to LOC convertor? I tried searching all over and couldn't find what wire to tap to. I'm looking around the harness that connects to the Idrive computer.?? please help |
11-12-2019, 05:14 PM | #91 |
Rep 23
When I did this in my e82, I tapped directly into the sub lines and went bypassed the high to low line converter and got very poor bass notes (remedied this by installing an aftermarket deck and installing directly from the deck) so would adding that high-low level converter mean that I get more bass, like when I hooked up a custom head unit?
12-23-2019, 04:02 AM | #92 | |
27
Rep 189
If you use the RCA outs to a sub amp and sounds terrible, chances are its your Sub Woofer / sub box set up. Make sure cross over point is like 80hz and down to the sub. Hope this helps
Thanks
Stylin20 |
04-10-2020, 08:23 PM | #93 | |
Rep 37
I also would like to know how can I add a subwoofer, because i don't have a factory AMP. Should I run the rca converter of the back speaker harness on the doors? |
01-05-2021, 01:28 PM | #94 |
Rep 1
Bass tube/ hide away
I'm looking to add a sub in my trunk, but I'm over the bulky box. Any opinions on the Kicker Hide away 46hs10 or bass tube 46CWTB104? Will either of these be worth it?
01-05-2021, 02:08 PM | #95 |
Rep 68
01-23-2021, 12:58 PM | #97 |
Rep 68
02-05-2021, 01:09 AM | #99 | ||
Rep 68
If it's really necessary I can do a full DIY But I kinda don't want to do it since I just swapped out the clutch and that was a pain in the ass and don't really want to work on the car for a while haha |
02-10-2021, 08:37 AM | #100 | |
Rep 9
video?
03-08-2021, 10:01 PM | #101 | ||
Rep 68
04-06-2024, 07:35 AM | #102 | |
Rep 1
Bass in Very Low
My car has iDrive. I tapped into the sub wires and ran directly to my amp (Hertz HDP1) as it takes high level inputs. I checked the bass settings on the stock head unit. I have adjusted the subsonic cross over, the low pass cross over as well as the level/gain to make sure they are correct. Bass is still low. jerryscheery - did you fix your issues? Does anyone have any ideas? Edit: I somewhat fixed the low bass issues. I triple checked all connections and found a connection I tapped into one of the sub wires a but questionable. I redid it and the sound has gone from poor to ok. I assume only half the power coming in leading to the low bass output. Last edited by jon949; 04-07-2024 at 12:55 AM.. Reason: Found a solutioom |
