10-19-2013, 05:32 PM | #1 |
17
Rep 86
Overheating warning but car isn't actually overheating?
My radiator fan seems to be going nuts all the time and after driving for 10-15 min I get a temperature warning and the car goes into extreme limp mode. Restarting the car makes this goes away for another random period of time...even hours. There are no signs of actual overheating..no burnt smell no steam under the hood coolant level is fine and not boiling. No idea what this could be, maybe coolant temp sensor?
10-19-2013, 06:27 PM | #3 |
17
Rep 86
hmm wouldn't I have symptoms of overheating then? temp warning comes on and a restart of the car makes it go away
10-19-2013, 07:29 PM | #4 | |
Rep 61
Restarting the car can make it go away since the engine itself hasn't overheated, but once the car cranks back up to 100% and notices temperature continuing to increase, it'll drop back into limp. In essence this is a fail safe built in order to prevent any chance of even momentary overheating. |
10-20-2013, 08:40 AM | #6 |
17
Rep 86
I get the red sign every time I drive and then an immediate restart of the car makes it go away. Coolant temp seems normal in logs. I'm not driving it til the coolant temp sensor I ordered comes in. If it's not that then it's the pump
10-20-2013, 10:08 AM | #7 |
European Editor
10642
Rep 22,992
Have you checked for codes? Sounds like a classic waterpump/thermostat failure to me.
10-20-2013, 11:35 AM | #9 |
European Editor
10642
Rep 22,992
You might call BMW Assist. At least over here in Germany... they will come out(and read your codes) look your car over. All work is free for the first 30 min. After that you have to pay IF you have an older car. But I would call and ask. Whats the worse they could say?
11-10-2013, 09:28 PM | #10 |
19
Rep 268
Did you figure out what it was?
I had this happen to me today
Custom Wedge MHD 2+ Aggressive, AR Catless DP, ETS 5 FMIC, BMS DCI, BMS OCC, Berk Axleback, CF Diffuser, CP-E Chargepipe
11-10-2013, 09:59 PM | #11 |
15
Rep 678
It is more than likely the water pump. our cars are notorious for water pump issues. Sometimes the pump is just broken, other times the piping literally broke and the pump is losing coolant (this is easy to check)
11-11-2013, 09:58 AM | #14 |
15
Rep 678
11-12-2013, 12:43 PM | #15 |
19
Rep 268
So I had to uninstall COBB before I took the car in (COBB AP showed tons of codes regarding water pump and e-fan failure). Now that it's uninstalled it cleared all the codes and now reads none....I really hope the dealer can replicate the problem while test driving it. Sigh
11-12-2013, 12:50 PM | #17 |
19
Rep 268
Me i'm at 55,000
11-12-2013, 08:37 PM | #18 |
Rep 17
100% water pump failure
I went through this for over a month trying to diagnose and found that water pump would just stop working them engine go into limp mode and simply by turning car off then straight back on would kick start pump again and would be ok again for anything up to a couple of days without any problems |
Dackelone10641.50 |
11-13-2013, 11:10 AM | #19 | |
17
Rep 86
11-13-2013, 01:58 PM | #20 |
19
Rep 268
It was the water pump, they said 'the codes were still there' and fixed it. Car runs great now
11-23-2013, 09:27 AM | #21 |
522
Rep 1,502
I think this happened to me last night.
driving in heavy suburb traffic. Had my a/c on for defrost. Got a yellow water temp light. I got a little nervous as it is 29 degrees out and I'm not in the best neighborhood. Turned off the a/c, opened the windows and cranked the vent to high. Noticed I had very little power in the engine, but no 1/2 power symbol. THEN BING RED TEMP WARNING and then no power. Pulled over and turned the car off. Opened the hood. Couldn't smell anything really. I've had cars that have overheated and this wasn't it. Called BMW Assist. They told me to call the Roadside Assistance. Let it sit for a few minutes. Started right up, no warnings, nothing. Drove it in some clean cold air...No problems. Drove it to a friends and let it idle for 15 minutes...No problems. Turned it off and let it sit for 6 hours and then drove home an hour...no problems Drove to work this morning...no problems. My GF and I were gonna take an overnight trip to Chicago last night, but the weather concern made us change our minds. That would've sucked. Water pump/Thermo??? called SA this morning and waiting for a call back '11 135 39,000miles
miiipilot
'24 M2 Brooklyn Grey, 6mt, Bi-Color, Black M-Color seats, '16 MG M2, DCT, Exec. Took Delivery 4/30/16 (Sold) |
02-14-2017, 11:24 AM | #22 |
Rep 1
I am with this same issue ..
I have been reading you guys, and experience the same limp situation so I guess I have to change the water pump. However, I and going to google the part and different options and I find like 3 different types of water pumps. Which is the one to change? the one with the pulley ?
