11-01-2013, 02:36 AM | #1 |
108
Rep 524
Coding for 6NR BMW Apps?
Assuming I have the FSC code, can someone tell me how to enable 6NR BMW apps? Tried searching but could not find what needs to be activated through ESys. Thank you in advance.
11-01-2013, 05:58 PM | #2 |
5702
Rep 3,226
If you shoot Shawnsheridan a PM I'm positive he will be glad to help you.
Shawn is the Yoda of coding and has helped me on many occasions. |
JuicedboXed4212.00 mrpingu189.00 |
11-01-2013, 08:40 PM | #4 |
10493
Rep 40,998
Drives: 2018 Alpina B6 650ix GC
You would have to add 6NR to your VO, write VO to car, Import and Activate the 9C FSC Code into Head Unit, then VO Code Head Unit / Combox.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
12-15-2013, 01:10 AM | #5 | |
108
Rep 524
A4A_REMOTE_APPS = aktiv - Adds "Apps" under Main Menu = > Connected Drive with Sub Menu BMW Apps (Facebook, Twitter, Web Radio). If 6NR is in the VO, or enabling this with no valid 6NR FSC Code, it will override CONNECTED_DRIVE = aktiv setting and ConnectedDrive on Main Menu will revert back to BMW Assist. Where do I find the listing for the A4A_Remote_Apps? |
12-15-2013, 03:10 AM | #6 | |
10493
Rep 40,998
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
12-15-2013, 05:10 AM | #7 |
108
Rep 524
Shawn, then is that the end of the process after I click CODE or do I still need to go find the CIC HU and Combox and edit additional options?
12-15-2013, 05:21 AM | #8 |
10493
Rep 40,998
That's it. The benefit of VO Coding is that based on the option codes in the VO, it automatically makes all the required FDL Code changes needed to support those options.
12-16-2013, 07:48 AM | #10 |
108
Rep 524
Coded the ECU as instructed but had two errors and now I have the drivetrain malfunction and fuel system malfunction indicators on. How do I clear these or do I need to visit the dealer?
12-16-2013, 10:25 AM | #11 | |
10493
Rep 40,998
You can try clearing them with Tool32: Assuming the fault condition no longer exists, to clear the fault code. 1) Launch C:\EDIABAS\Bin\TOOL32.EXE 2) Hit F3 3) Load C:\EDIABAS\Ecu\F01.PRG 4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL 5) Hit F5 6) "Results" window should show "JOB_STATUS = OKAY" Hopefully, Problem Solved. Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
12-16-2013, 10:35 PM | #12 | |
108
Rep 524
Unfortunately, the drivetrain malfunction would not go out. I guess it was a fluke that the malfunction happened as I was coding it. The car is at the dealer now. |
12-16-2013, 11:00 PM | #13 | |
10493
Rep 40,998
02-11-2014, 12:00 AM | #14 |
Rep 81
02-11-2014, 05:42 AM | #15 | |
10493
Rep 40,998
But BMW Apps requires a 9C FSC Enabling Code issued by BMW AG for your VIN be imported and Activated in the head unit fist. Do you have the FSC Code?
08-14-2014, 07:26 AM | #17 |
Rep 11
How does one find that FSC code? Does BMW sell them or something? If they do, I'm sure they'll do the coding for you as part of the purchase... so what's the use case for doing this yourself?
(sorry, I know it's an old thread, but it's a related question) |
08-14-2014, 11:02 AM | #18 | |
10493
Rep 40,998
And in cases where you cannot get official "6NR BMW Apps Retrofit", you can usually obtain the FSC Code from various sellers, and perform an "unofficial "6NR BMW Apps Retrofit". So, you do it yourself to either save money, or out of necessity when you can't get an official "6NR BMW Apps Retrofit".
Bugra8.50 |
08-18-2014, 05:39 AM | #21 |
10493
Rep 40,998
Kitster is correct. You need 609 Nav Pro in order to have 6NR Apps.
hazretidentist0.00 |
08-18-2014, 08:37 AM | #22 |
BimmerPost Supporting Vendor
668
Rep 1,980
Drives: 2020 G20 320i M Sport
Have any of you guys gone back to the dealer for a software update after importing an activating the 6NR FSC code?
I know from factory, a CIC equipped F30 with 6NR would have 6NF and 6NL as their Bluetooth option. Will there be any conflicts with 6NH and 6NR written to the FA on VCM?
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
