04-23-2015, 08:52 PM | #111 |
Newbie!
16
Rep 76
You're welcome!
Remember to also code your lights to "instant on" for lock/unlock. The default lights fade in/out will cause the LCI headlights to flicker. Good luck! Howie
BMW Z4 35i Havana Cobb Tune (Stg1-360hp) |
06-10-2015, 05:25 AM | #113 |
68
Rep 715
For those that have done it, what are the parts required? Can you just get the L + R headlight assembly and use the old ballast, bulb, etc. or would you need a whole new set of hardware?
08-03-2015, 11:43 AM | #115 |
Rep 10
just another space gray with new LCI headlights..
thanks to Fabian S. and all thread contributors for a great source of information. retrofit was performed from on e89 z4 (2010 model) with bi-xenon headlights without AHL function to original LCI headlights with AHL car was originally equipped with FRM3R PL2 (LED XE) footwell module which I had to replace with FRM3 Max Brose module (61359383050 SW180002HW13) to get AHL functionality. additionally, I have add extra wires (61122348129) from footwell module to headlights to support SMC signals. I could use OEM wiring without adding extra hardness (as there are free wires) but I wanted to make it 100% compliant with standard electrical schematic. as on optional step.. software was re-loaded from the latest V56 using Ista/P coding just to prevent any errors or compatibility issues in the future. |
09-15-2015, 09:59 AM | #116 | |
Rep 2
My z4 has bi-xenon headlights without AHL function and I wanted to install the original LCI headlights with AHL too. Do you think that I can do by myself? The only problem is the footwell module that I don't know where it is installed in the car. Maybe if I install the original bi-xenon LCI headlights without AHL, I don't have to replace the footwell module and I can install by myself |
09-19-2015, 06:03 PM | #117 |
Rep 10
emapol, try to check what footwell module you have installed in your car.
Module is located under steering-wheel.. above foot area.. Deinstall the cover and you will find it on top-left side. In case you have FRM3 version, you will not need to change it if you use non-AHL LCI headlights. Otherwise, your current FRM module will need to be replaced by FRM3 MAX Brose version, to support AHL functionality of new LCIs. In case you going to change FRM module a coding of the car will probably be needed. It would depend on release date of FRM module you get. The most recent FRM modules will not be supported by software of your car. |
05-27-2016, 02:39 PM | #118 |
Rep 28
Another one about to take the plunge?
Well, turning lemons into lemonaid. My 2013 35iS was the victim of a parking lot incident - a Honda Pilot backed into my front-end. Long story short, my driver's headlight is smashed.
Given that we're going to have to replace one headlight anyway, wondering about swapping to the LCI headlights. My car is fairly late production and loaded, so I suspect I'd have the FRM3 module. Aside from the headlight units themselves (with LED bulbs) and possibly a wiring harness, do I need to buy anything else? I've read and re-read the thread. it is possible that I'm just illiterate, but I remain a bit confused as to what is actually required in this case. Can I not re-use the Xenon Adaptive units? Also, any pointers for a north american looking to get these purchased at less than full dealer retail? HELP! Dying to get my beauty back on the road, but don't want to miss an opportunity to have insurance help cover the cosmetic surgery. Thanks! ----- This is what I have on the to be purchased list so far Left Housing (AKL): 63127348953 -> $1300 Right Housing (AKL): 63127348954 -> $1300 Retrofit harness: 61122348129 -> $25 LED Ballast: 63117342174 (2 of them) -> $440*2 LEDs: 63117348935 (2 of them) -> $130*2 Screw?: 46637659479 (30 of them?!?!) -> $60 Mama mia! total back of napkin cost of ~$3600 plus shipping + taxes. **** Not Needed ? **** Xenon module: 63127296090 --> $424 *2 Last edited by IMR; 05-30-2016 at 02:10 PM.. |
09-12-2018, 01:01 PM | #119 |
44
Rep 249
Hoping to resurrect this old thread and get some clarification. I am looking to do the LCI headlight retrofit. There are multiple people on here claiming success but with what seem like dramatically different degrees of complexity.
One claimed to only need coding and: 63127348949 63127348950 Another claimed to need coding and: 63127348953 63127348954 Others claim to need those parts and much more. My Z4 is a 2013 (produced 11-14-2012), has Adaptive Headlights (S524A), LHD, United States Any guidance would be much appreciated! Thanks in advance |
02-22-2019, 09:48 AM | #120 |
29
Rep 182
So here is my experience with LCI Headlights retrofit.
My car:2011 35is with Adaptive Headights(standard option in the US) LCI lights: Driver side 2013 and passenger side 2015, both bought from EBAY with all the modules on the lights. First attempt: So get the lights to work, had to code the FRM module to Max the brightness for DRL lights, or else the DRL's would flicker. Now the Adaptive lights would not work. Would give the Adaptive lights error on the info screen. Second attempt: Swapped the Adaptive lights module from my old lights to the new ones and played with the FRM coding and it works. Conclusion: At least what I think is you will have to swap your AHL module from your old lights to the new ones or buy an updated(new) FRM module to work with the new lights. |
06-16-2023, 05:55 PM | #121 |
Rep 8
Bumping this up in case anyone has done the retrofit in the intervening years since this thread started. It's been linked in numerous other forums I've visited so hopefully keeping the conversation in this same thread will help those searching the subject, just as I did.
Given the number of passing years, and headlight units becoming more easily obtained 2nd hand at a reduced cost, has anyone successfully completed this retrofit? I've got my hands on a pair of complete LCI headlight units and fit them to my car. That part was easy enough, as far as it goes (getting some of the trim off was the most difficult part). They're plugged in and set up. All lights working individually, but when the angel eyes/halos are on with the low beams & high beams, they flicker. I have Carly so have tried coding all the options available to make the halos brighter/increase the voltage to reduce flickering, but I've run out of options available in Carly. Should note here that they ONLY flicker when the low beams/high beams are on. When it's just DRLs, they're fine. Indicators also work without issue. Based on previous posts in this thread, I think the solution is to increase the voltage for the halos so they don't flicker, but since Carly doesn't have an option to change the brightness w/low beams/high beams on, I can't change that. What solutions has anyone else found? Would Bimmergeeks ProTool be able to code the lights properly? I'm reluctant to spend £150+ and try it in case it doesn't work, similarly with INPA/ISTA (can't remember the right name) as I don't have a laptop so would need to buy one and don't really want to spend £400-500 fixing a flickering light. Any help would be very much appreciated. Thanks! |
06-16-2023, 06:29 PM | #122 | |
36
Rep 121
I didn't bother reading the whole thread I have a 2013... what is the difference with the LCI lights? I have the adaptive ones with HBA and changed it the halos to a very bright LED 6,000k bulbs |
07-10-2023, 05:50 PM | #124 |
Rep 8
Hi again. Some more issues coming up.
I got the ProTool app and Bluetooth adapter and coded the DRLs brightnesses up and eliminated the flickering, so that's all sorted. All the lights/bulbs work nicely now. However I've discovered a new issue and that is that the automatic lights control doesn't work anymore. It did work on the pre-lci headlights I had installed but it isn't working on the new LCI headlight units that I retro-fitted. I've checked the coding and this is enabled in ProTool to make the lights turn on when it's dark, but the lights don't come on in the dark when set to automatic mode. Does anyone know of any other settings that might be affecting this? I'm getting no error messages or codes at all when I scan the car. There is an option in ProTool for a Rain Light Sensor (RLS) unit but when I tap that it says there's no RLS module installed in the car. Is that right? I would imagine a car that has the auto-wipers and auto-lights functions would have an RLS to control that? Has the RLS unit failed? Also where is that if so? |
04-16-2024, 06:01 PM | #125 |
44
Rep 155
I’m looking into this retrofit, but the retrofit cable is no longer available.
What is the purpose of this cable? Is it just to light up the eyebrows? Anyone have a schematic or at least a picture of it? I found a picture of an X1 e84 retrofit cable (which is also discontinued), if it’s ruffly the same, I’ll just make my own. https://www.ebay.com/itm/143764620194 Edit; never mind. I found the official retrofit manual earlier in this thread. Last edited by awt; 04-16-2024 at 10:28 PM.. |
04-24-2024, 03:53 AM | #127 | |
162
Rep 622
Drives: E89 Atacama Yellow 35is
Some folks it’s worked perfectly some have struggled
Much modified 2011 Atacama Yellow 35is…previously a much modified 2012 Atacama Yellow 20i MSport
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0 Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886 |
04-24-2024, 12:23 PM | #129 |
162
Rep 622
I didn’t …others have…
erraksr0.00 |
