BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Winter tires
      08-05-2018, 08:36 AM   #1
Stuartlogan77
33
Drives: 2013 BMW M5
Winter tires
Anyone know what size rims/tires recommended.
I have an old set of 285/35 square set up for my x5m. The fronts on the m5 are 275/35.
Anyone know of the 285/35 all square would fit?
Thanks
      08-05-2018, 09:23 AM   #2
Miko M
///M
Miko M's Avatar
6654
Drives: 2020 M2C. 2020 X3M
BMW recommends 705M wheels in ferric grey
19by9.5 ET26 all around
PT# 36 11 8 043 663
Life is too short...enjoy your life
///M
      08-05-2018, 11:57 PM   #3
vesko06
103
Drives: F90 M5
i ordered winter wheel setup - F90 M5 M5 Winter wheel&tire M double spoke 705M with tire size 265/40R19 102V.
      08-09-2018, 09:49 AM   #4
kdeleon
94
Drives: M5
So if I do the equivalent of front tires all around, does that mean I need to add spacers on the back wheels or it will look pushed in as they are narrower tires?
      08-09-2018, 11:17 AM   #5
zuschnell
zuschnell's Avatar
556
Drives: '19 m5, '18 991.2 gt3,
Yes. Your rear wheels will be tucked in about an inch compared to the fronts as the standard rear wheels are 10.5 inches. You will need a stud kit and spacers of about 20-25 mm to get them back out to regular oem look.
Gone but not forgotten: '10 X5M, '14 550ix, '17 M3 zcp, '11 aw e90 M3 zcp, ?11 sg e90 M3, '17 X5M, 19 F90 M5
Current: ?13 e92 m3 ESS 585, 22 f95 x5m Comp, Track - '18 manual 991.2 GT3, Wife's family truckster - '20 Volvo XC90 T8
      08-09-2018, 12:24 PM   #6
sybaek9
sybaek9's Avatar
94
Drives: 2018 M5
Thanks
What's wrong with the Michelin tires currently on the M5?
      08-09-2018, 12:52 PM   #7
AGS
AGS's Avatar
501
Drives: 2022 M5 Competition
They're summer performance tires, not designed for winter driving. Once the temperatures get below 40 degrees they'll turn into bricks (think hockey puck on ice). An forget about any traction in the snow.
Current: 2022 Donnington Grey M5 Competition, 2014 Anvil WW Jeep Wrangler
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7
      08-09-2018, 10:31 PM   #8
sybaek9
sybaek9's Avatar
94
Drives: 2018 M5
Anyone planning to still keep the summer performance tires during winter? I'm in DC area and we get some cold below freezing days and 1-2 snow storms (which I normally don't drive in)
I've never changed tires in the winter for any of my cars in the past.
      08-16-2018, 02:25 PM   #9
Stuartlogan77
33
Drives: 2013 BMW M5
I would never drive on a 1/4 inch of snow with summer tires on. They just won't get traction any incline will basically take you for a ride you wont enjoy.
      08-16-2018, 04:34 PM   #10
scotty91ss
182
Drives: 19 M5, '15 X5M,'91Chev454ss
Don't forget braking. If you need to do an emergency stop in the winter on all seasons, you have substantially increased your braking distance. Slide right through an intersection.
      08-16-2018, 10:38 PM   #11
sybaek9
sybaek9's Avatar
94
Drives: 2018 M5
So where can I order the winter tires and wheel setup?
      08-16-2018, 11:18 PM   #12
vtknight
vtknight's Avatar
967
Drives: 2019 F90 M5 Competition
Question - I have a 19" Pirelli Sotozero 3 245's all round winter tire/wheel setup for the M550ix as BMW provided those to Canadian customers because the 20" wheels and PS4's were not ready at delivery (for about 1000 bucks)...Does anyone know if I can still use those on the M5 with steelies?
      08-17-2018, 12:26 AM   #13
stbm5
261
Drives: 2018 M5 DG
What's the bolt pattern for the 550 wheels?
      08-17-2018, 06:35 AM   #14
zuschnell
zuschnell's Avatar
556
I think they will work but will be very tucked in as they are 8" wheels and the offsets don't really compensate for the difference in width. Are these the wheels you have? You would need at least 20mm spacers in front and 25mm in back to get even close to stock look. Actually like 35mm in rear.
https://www.shopbmwusa.com/Product/6...L-AND-TIRE-SET
      08-17-2018, 08:05 AM   #15
Who's on first
Who's on first's Avatar
2464
Drives: A-10C
Start shopping for your next car. And save for a lawsuit.
(Maryland Resident here)
Anyone who drives on summers, below 40degrees should be found negligent, should an incident arise.
Clearly going against the manufacturers specifications and warnings.
      08-17-2018, 08:07 AM   #16
Who's on first
2464
Drives: A-10C
What other tires, did you not change? Be specific here... all seasons... or ultra-high performance summers?
      08-17-2018, 08:08 AM   #17
Who's on first
2464
Drives: A-10C
My understanding is the bolt pattern from the 550 if different then the M5.
Tires, will be fine.. you'll need to find different wheels.
      08-17-2018, 08:17 AM   #18
Who's on first
2464
Drives: A-10C
Dramatically worse for summer versus winter, not all seasons.
      08-17-2018, 10:34 AM   #19
zuschnell
zuschnell's Avatar
556
If the 550 is current generation, then the bolt pattern is the same as current m5. The problem is the offsets.
      08-17-2018, 05:56 PM   #20
stbm5
261
Drives: 2018 M5 DG
i concur about the statement regarding driving summer high performance tires in the winter. if its sub 40 degrees and even a little wet out it then its just plain dangerous. you will definitely lose traction. for a vehicle with this kind of power its just plain negligent to not put on winter tires, it simply must be done.
      08-21-2018, 06:57 AM   #21
sybaek9
sybaek9's Avatar
94
Drives: 2018 M5
Where did you order from and how much total?
      08-23-2018, 12:18 PM   #22
bengals9
24
Drives: M5
Any opinion, good or bad, on using these year round? Found them thru a call to Tire Rack
Pilot Sport A/S 3+ 275/40/ZR19 front
Pilot Sport A/S 3+ 285/40/ZR19 rear
m5post
