Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Southwest > HPF Exhaust The Woodlands, TX $1,100
      12-10-2012, 02:27 PM   #1
01saleen77
Drives: 2007 335i
This is a used HPF cat back exhaust system off my 2010 BMW 335I. It is in great shape, was only on the car for about 100 miles before i decided to sell the car so i no longer need this. It has an amazing sound, best i have ever heard. HPF really takes pride in the work and it shows with this system. check it out on their web page horsepowerfreaks.com. I'm in the Woodlands if anyone would like to see, but will ship at buyers expense.
The HPF exhaust system is one of the highest flowing exhaust systems on the market for the BMW 335i with staggering 3.5" stainless steel piping and a 14" stainless steel high flow resonator. Simply installing the HPF exhaust and removing your factory 335i exhaust system will take 40 lbs off the weight of your car due to it's single large diameter pipe design. For those that have a wideband or want to get one, you won't need to own a welder and weld an O2 bung with this exhaust. Simply screw the wideband O2 sensor into our "pre-welded" O2 sensor bung. If you don't have a wideband don't worry, we ship the exhausts with a bung plug to seal the hole. The HPF 335i exhaust system is designed for the factory twin turbo cats all the way to our future single turbo upgrade which will be coming in the "very" near future. You won't ever need to buy another exhaust system. This exhaust will easily support the flow requirements to exceed 800rwhp. With 100% polished stainless steel and fully adjustable 3.5" titanium tips, give your 335i the look it deserves and a sound that turns heads. Think running without a muffler sounds loud? Check out the video below and see for yourself. There is minimal drone with the rubber isolated mounts and the sound is exotic.FeaturesA Staggering 40 lbs weight savings (OEM Exhaust = 75 lbs, HPF Exhaust = 35 lbs) 100% 304 Stainless Steel 3.5" Exhaust 14" Stainless Steel High Flow Resonator 3.5" Fully Adjustable Titanium Tips Super strong stainless V-Band flanges For easy installation and adjustment along with leak free operation Pre-Welded Stainless Steel Bung and Plug for Wideband Setups Fully Polished 100% Mandrel Bends Flex Section Rubber Isolated Mounts Minimal exhaust movement due to triangular mounting method Minimal Drone Aggressive Styling with Large 3.5" Tips Exotic Exhaust Note
      12-30-2012, 05:00 PM   #2
M3 2ENVY
24
Drives: 2011 E92 M3 DCT
PM sent
      02-14-2013, 08:50 PM   #3
tareemaa
Bimmer Fanatic
368
Drives: M3
still have this?
      02-18-2013, 10:32 AM   #4
01saleen77
Drives: 2007 335i
Sold... Sorry for not updating
