BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > LCI Halogen to LCI Xenon (non-adaptive)
      02-19-2020, 04:15 PM   #1
Nickdot
15
Drives: E90 335d & Megane 225 Trophy
Thumbs up LCI Halogen to LCI Xenon (non-adaptive)
Hi guys,
I realise this topic has been done to death, over multiple years and forums.
However.. I'm still struggling to glean some information required for this retrofit - most threads seem to be related to pre-LCI to LCI conversions.
Are the same mods required?
Acquired a pair of LCI non-adaptive bi-xenons for my LCI halogen equipped 335d, and I have fitted and coded (currently for halogen) an FRM3 MAX BROSE.
Xenon level sensors are easy (front & rear).
These need wiring to the FRM, will the loom with P/N# 61120395932, work OK? I realise it is for a 2006-2008 car.
Found the P/N here;
https://www.e90post.com/forums/showthread.php?t=912413
Haven't found a pinout as yet, so if anyone has it, that would be awesome.
Wiring modifications between the FRM and xenon clusters is where I'm struggling the most; does anyone know know exactly what's needed?
LCI Hal to LCI Xen, full OEM retrofit.
Then coding - adding $522 to the VO, resetting the FRM and CAS and going from there.
Do the bulb checks still need disabling if the car is programmed properly for Xenon clusters?
Any help would be greatly appreciated!!
      02-19-2020, 04:23 PM   #2
Nickdot
15
Quick update (literally after posting the original message..)
Pinout for the levelling sensors found;
And a cable repair set, including plugs/pins/small length of wire, which could be used to create the loom for both levelling sensors;
https://www.autodoc.co.uk/herthbuss-elparts/7694978
If the following pre-made harnesses aren't applicable to the LCI E90;
http://www.sparesdeals.com/index.php...product_id=656
      04-28-2020, 08:37 AM   #3
M3Mark
Drives: BMW 330d
Hi Nick,
I'm looking at fitting Pre Lci Xenons to my Pre Lci Halogen 56 plate E91 and wondered if you come up with a plug and play solution?
im not exactly great with wiring but did your harness 61120395932 come in the end?
Is the Levelling sensors essential for it all to work and does that harness have all connections to just plug and play?
Hope all went well.
      05-25-2021, 05:14 AM   #4
Nickdot
15
Hi there mate,
No plug and play solution, but I am currently in the process of knocking up my own looms to make this as OEM as possible (currently running xenons having modified the internals - but this doesn't work with my FLA retrofit - and I would rather they are wired as per BMW's intention).
I've gleaned information from all over the place (annoyingly ~95% of these conversions and wiring diagrams are pre-LCI!), but have been able to construct the following;
(Please correct me if I am wrong on anything - this is my no means concrete information - just what I was able to collate from hours of forum-digging).
Right headlight
1 - Pin 14 FRM (x14260 - 0.75mm" wire)
2 - GROUND (2.5mm" wire)
3 - Pin 38 FRM (x14261) - SAME AS HALOGEN
4 - GROUND - SAME AS HALOGEN
5 - Pin 41 FRM (x14260 - 0.5mm" wire)
6 - UNPOPULATED
7 - Pin 8 FRM (x14260 - 1.5mm" wire)
8 - Pin 51 FRM (x14260) - SAME AS HALOGEN
9 - Pin 32 FRM (x14260) - SAME AS HALOGEN
10 - Pin 28 FRM (x14260) - SAME AS HALOGEN
11 - Pin 30 FRM (x14260) - SAME AS HALOGEN
12 - Pin 40 FRM (x14261) - SAME AS HALOGEN
Left headlight
1 - Pin 41 FRM (x14261 - 0.75mm" wire)
3 - Pin 6 FRM (x14261) - SAME AS HALOGEN
6 - UNPOPULATED
7 - Pin 50 FRM (x14261 - 1.5mm" wire)
8 - Pin 50 FRM (x14260) - SAME AS HALOGEN
9 - Pin 19 FRM (x14260) - SAME AS HALOGEN
10 - Pin 15 FRM (x14260) - SAME AS HALOGEN
11 - Pin 17 FRM (x14260) - SAME AS HALOGEN
12 - Pin 13 FRM (x14260) - SAME AS HALOGEN
Height Sensor Front
1 - Pin 26 FRM (x14260 - 0.35mm" wire)
2 - EMPTY
3 - EMPTY
4 - Pin 49 FRM (x14260 - 0.35mm" wire)
5 - Pin 31 FRM (x14260 - 0.35mm" wire)
6 - EMPTY
Height Sensor Rear
1 - Pin 27 FRM (x14260 - 0.35mm" wire)
2 - EMPTY
3 - EMPTY
4 - Pin 48 FRM (x14260 - 0.35mm" wire)
5 - Pin 29 FRM (x14260 - 0.35mm" wire)
6 - EMPTY
TLDR;
Angel Eyes
Pin 1 on both headlights needs wiring as per the diagram using 0.75mm2 wire. On a halogen car, these are wired (to a different pin FRM side) using 0.5mm2 wiring - so it might be possible to just swap the pin?
Ground
Needs running to pin 2 on each headlight from the ground connector combs on the chassis close to the headlights either side.
Xenon Shutter
Pin 5 on both headlights need connecting to pin 41 on the FRM connector x14260 with 0.5mm2 wire.
3 Corner LED's
Pin 7 needs connecting as per the diagram using 1.5mm2 wiring.
Level Sensors
(3 wires to each sensor) are wired as per the diagram using 0.35mm2 wiring.
The rest appears to be identical to the halogen wiring - so can be left in situ.
AHL is a different beast however, but do-able. I have the wiring information for that should anyone be interested in fitting adaptive xenons. I was going to do it myself, but non-adaptive are so much easier
Cheers!
Edit: Edited to correct wiring on Pin 6 of both headlights.
      09-28-2021, 11:33 AM   #5
Nickdot
15
Quick update on the above.
I have now completed this retrofit as OEM as I could possibly get (only the wire colours that I ran are non-OEM).
For those interested, I can confirm the wiring diagram is as follows;
Right headlight
1 - Pin 14 FRM x14260 (0.75mm2 wire)
2 - GROUND - X166 (2.5mm2 wire)
3 - Pin 38 FRM x14261 (2.5mm2 wire) - SAME AS HALOGEN
5 - Pin 41 FRM x14260 (0.5mm2)
6 - Residual from Halogen - can leave in place
7 - Pin 8 FRM x14260 (0.5mm2 wire - should be 0.75mm2) - MOVE FROM PIN 1
8 - Pin 51 FRM x14260 (0.5mm2 wire) - SAME AS HALOGEN
9 - Pin 32 FRM x14260 (0.5mm2 wire) - SAME AS HALOGEN
10 - Pin 28 FRM x14260 (0.5mm2 wire) - SAME AS HALOGEN
11 - Pin 30 FRM x14260 (0.5mm2 wire) - SAME AS HALOGEN
12 - Pin 40 FRM x14261 (0.75mm2 wire) - SAME AS HALOGEN
PROCESS
PIN 1 - 0.5mm2 from FRM X14260 pin 8 - MOVE TO PIN 7
RUN 0.50mm2 wire to PIN 5 FROM FRM x14260 PIN 41
RUN 0.75mm2 wire to PIN 1 FROM FRM x14260 PIN 14
RUN 2.5mm2 GROUND TO X166
Left headlight
1 - Pin 41 FRM x14261 (0.75mm2 wire)
2 - GROUND - X165 (2.5mm2 wire)
3 - Pin 6 FRM x14260 (2.5mm2 wire) - SAME AS HALOGEN
5 - Pin 41 FRM x14260 (0.5mm2 wire)
7 - Pin 50 FRM x14261 (0.5mm2 wire - should be 0.75mm2) - MOVE FROM PIN 1
8 - Pin 50 FRM x14260 (0.5mm2 wire) - SAME AS HALOGEN
9 - Pin 19 FRM x14260 (0.5mm2 wire) - SAME AS HALOGEN
10 - Pin 15 FRM x14260 (0.5mm2 wire) - SAME AS HALOGEN
11 - Pin 17 FRM x14260 (0.5mm2 wire) - SAME AS HALOGEN
12 - Pin 13 FRM x14260 (0.75mm2 wire) - SAME AS HALOGEN
PROCESS
PIN 1 - 0.5mm2 from FRM X14261 pin 50 - MOVE TO PIN 7
RUN 0.75mm2 wire to PIN 1 FROM FRM x14261 PIN 41
RUN 2.5mm2 GROUND TO X165
Height Sensor Front
1 - Pin 26 FRM x14260 (0.35mm2 wire)
2 - EMPTY
3 - EMPTY
4 - Pin 49 FRM x14260 (0.35mm2 wire)
5 - Pin 31 FRM x14260 (0.35mm2 wire)
6 - EMPTY
Height Sensor Rear
1 - Pin 27 FRM x14260 (0.35mm2 wire)
2 - EMPTY
3 - EMPTY
4 - Pin 48 FRM x14260 (0.35mm2 wire)
5 - Pin 29 FRM x14260 (0.35mm2 wire)
6 - EMPTY
The height sensor looms themselves are easy enough to make, I grabbed the correct size wire off of eBay and knocked them up, these were then heatshrinked (for the part that would be outside of the car);
The sensors themselves are easy enough to source. Just make sure they have the correct brackets attached (as they differ between the M3 and non-M cars).
The wiring through the cabin was the next big hurdle.
For the front sensor, it was a simple task of wiring along the existing wiring up to where it joins the main harness back into the cabin.
For the rear sensor, removing the arch liner and alarm revealed a spare hole in the grommet into the cabin next to the rear seats - perfect for this wiring;
Then along the main harness towards the front of the car;
Wiring the additional wires for the passenger headlight and front sensor loom into the cabin itself required the DDE to be removed, but it meant there was plenty of room to feed through the bulkhead and to make a tidy job of it;
With all of the wiring in the passenger footwell (UK spec car), this then needed passing behind the dash into the drivers footwell towards the FRM. This was a bit of a struggle, but there is a channel along the back in which you can pass an electricians draw wire, and pull the looms through (I also took this opportunity to tape everything together to keep it neat and tidy;
I don't have a picture, but you can then follow the loom up and over the pedals to reach the FRM;
As for the drivers side wiring to the headlight, this can be run alongside the harness down this side of the car;
And then fed through the bulkhead behind the master cylinder/ABS pump (this was a struggle);
I left the wiring of the headlight connectors themselves to last, so that I could continue to drive the car in between wiring jobs (as it took a few days to complete in total).
Wiring in the earths to the ground combs on either side of the chassis was a piece of cake;
The looms were then taped up to keep them as neat as possible;
Lastly, the headlight wiring was terminated and plugged in (take care on this part to use the correct size seals (green/black)), as the green seals are smaller then the black ones.
Shutter;
Sidelight/halo;
Re-terminated OLD sidelight wire (going to PIN 7) for the 3 LED's, as the black seal was too big for its new position, and needed a green seal;
Voila;
The easiest part of this retrofit was the termination and wiring of the connectors on the FRM (as per the above) - I found it easiest with the FRM removed;
As for the two wires into a single connector for the Xenon shutter, I simply soldered them together, and then onto a small 'tail' which would then plug into the FRM connector;
Done;
I hope that helps anyone hoping to attempt this retrofit to this capacity.
It was rather difficult at times, I can't count on a single hand the amount of hours I was on my back in the drivers footwell staring up under the dash trying to run the wiring neatly.
I went through meters and meters of loom tape. I swore a lot. But it was definitely worth it.
Happy to answer any questions if anyone has any
EDIT: Lots more photos added.
Appreciate 3
1 AKY459.00
Cal122181.00
      09-28-2021, 11:36 AM   #6
neilvan
neilvan's Avatar
858
Drives: 09 E90 335i M-Sport 6MT RWD
I gotta say that's ballsy and very impressive to do a wiring project spanning the whole car and properly/cleanly run. kudos!
      09-28-2021, 06:02 PM   #7
Nickdot
15
Thanks very much!
It was a fair amount of effort, but I did have some fun with it - haven't done anything so wiring intensive before, so was a bit of a learning curve.
Just hope the above post helps anyone else wanting to do the same!
      09-29-2021, 04:28 AM   #8
Sir_Dave
Asset Finance Broker
Sir_Dave's Avatar
55
Drives: e91 335i
Absolutely excellent work!!!
      09-29-2021, 07:51 AM   #9
Rich_D
Rich_D's Avatar
95
Drives: E90 330d M Sport LCI
Skills
BMW E90 330d M Sport LCI in Sapphire Black
      07-09-2022, 05:59 PM   #10
krispykreme
46
Drives: e90 328i
Right headlight
PROCESS
Left headlight
PROCESS
Height Sensor Front
2 - EMPTY
3 - EMPTY
6 - EMPTY
Height Sensor Rear
2 - EMPTY
3 - EMPTY
6 - EMPTY
Shutter;
Sidelight/halo;
Voila;
Done;
Interested in making and selling the wiring loom?
      07-11-2022, 08:55 AM   #11
Nickdot
15
Unfortunately not mate - although it isn't terribly difficult.
2 x 3 wire looms for the height sensors
2 x 2 wire looms for the headlights themselves
Then 2 x earths for the front lights again
Wire you can grab in every size/colour from eBay, same goes for the contacts themselves (or https://www.lllparts.co.uk/ - although delivery can take a while).
You then need a crimp tool, I use the following and have never had an issue;
https://uk.rs-online.com/web/p/crimp-tools/7106499
      10-14-2022, 10:58 PM   #12
E92_James
E92_James's Avatar
38
Drives: 2019 440i | 2020 X3 X30i
2019 F36 440i  [0.00]
Hey I'm slowly doing this to my E90 and I bought the OEM brown wiring and I guessed which terminal contacts I needed for the ground and I got that to work, but the rest of the wires I need to add into the FRM to the headlights (such as pin 1 and 5), do you have the part numbers of the exact pin contacts you used? And how many meters of wire did you order/use? And the part number for the green seal for pin 7, I can't seem to find it anywhere on realoem.
Thanks a lot this is a big help!
2019 F36 440xi B58 | 2011 E90 328xi N51 | 2010 E92 335xi N54 (sold) | 2015 F32 435xi N55 (sold) | 2020 G01 X3 30i B46 | 1996 E36 328iS M52 (RIP)
      10-24-2022, 10:07 AM   #13
Matt_E90
Matt_E90's Avatar
Drives: BMW 330d M Sport
Do you still need the part numbers, I will look them up
      10-25-2022, 02:35 PM   #14
E92_James
E92_James's Avatar
38
I've managed to guess 90% of the seals and connectors, all that's left is the small pins on the headlight I cannot for the life of me figure out what contact goes on that but I think I managed to order the correct one, we will see when it arrives
I've got grounds hooked up and the two pairs of wires running from the FRM to the headlights so it's just those contacts going to the small pins on the headlight holding the retrofit back
      10-25-2022, 02:48 PM   #15
Matt_E90
Matt_E90's Avatar
Great work, I shall be doing this myself shortly just waiting on the right set of lights to come up
      10-29-2022, 02:57 PM   #16
E92_James
E92_James's Avatar
38
I had to purchase two sets of headlights because the first pair, the drivers side was busted inside, where the bracket that holds the projector (has a ball joint) that goes into this plastic white colored socket on a screw (i think it's a horizontal adjustment screw) so the projector shakes left and right loosely, but the passenger side was good, so then I went to buy another pair just for the drivers side since the guy gave me a good deal, and funny enough the same damage happened to the passenger side
Lesson learned, be careful when buying these headlights because looks like they get internal damage when in an accident. The good side from the first pair had the typical lazy eye but I fixed that by popping in the little adjustment motor, wish I could've fixed the other damage that easy
I'll post some pictures to show you what exactly broke because I definitely got fooled thinking it was just a simple fix of lazy eye, but at least I have a full good pair and a full bad pair
Good news is I finally have every terminal connector so now today I'm gonna crimp them on the wires and hopefully have the harness complete and finished by tonight
      09-28-2023, 07:34 AM   #17
Cal122
181
Drives: 2006 325i 2011 328i xDrive
Nickdot Sorry to bring up an old thread, but thank you for this amazing write up. I'm going through the same with my Halogen LCI model and comparing wiring diagrams.
The Pre-LCI official retrofit instructions indicate another 2 wire "Connection Cable" is needed between the Junction Box (JFFB) and the FME (Pins 43 & 44). Do you recall if this cable was still necessary on your LCI Model?
Thanks!
      11-30-2023, 06:19 AM   #18
Nickdot
15
Thanks!
Hi there mate - sorry for the delayed response (I'm not on here too often).
I do not remember running any cabling between the JBBF and the FEM on my LCI.
Cheers!
      12-18-2023, 09:33 AM   #19
Will_460cs
209
Drives: E46m3 e91 N53 e90 n55
Brilliant just what I needed! now to find some headlights!
      04-09-2024, 10:52 AM   #20
Ryan Emad
Drives: BMW X2 18i
Hey, I’m about to tackle this DIY but I need help, I didn’t understand the part numbers as it’s very confusing when it comes to wiring and these small plugs and all, can someone please help me out and list to me all the part numbers that I need to complete this retrofit? Thank you.
