The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Official E92 Bulb Code List
      08-26-2009, 08:19 AM   #45
kennethpetro
Drives: 2011 328i JB/Black Dakota
Originally Posted by BaMBaM4002 View Post
wait..so the cornering lights are H3 and the halos are H8 ? not the other way around ?
Yes, H3 for the cornering and H8 for the Angel Eyes.
And the reason why the LED solution for the e92 is so costly is that it's not just a simple LED. It has to be SUPER Bright so the light reaches both angel eyes and making an LED that bright causes it to heat up and malfunction. There is a lot of work that goes into ensuring the LED stays cool. They use heatsinks and resistors and a lot of other shit I really don't know too much about. Personally, i went with the HID angel eyes because they are DEFINITELY the brightest solution out there. The new LUX LED for e92's is the only one that comes close to the brightness of the HID's but i don't like how white the LUX LED's look. You can get the HID's in dozens of diff temperatures from 2,300k all the way up to 20,000k.
Hope that helped.
2011 Jet Black 328i, 6-Speed Manual, Black Dakota Leather, Brushed Aluminum, Harmon Kardon w/ Surround Sound, Navi, BMW Apps, iPod & USB Adapter, BMW Assist w/ Bluetooth, Full LED Interior, 6000k HID Fogs, Matte Black Kidney Grills, M3 Lip Spoiler, ACS Roof Spoiler, 19" Beyern Black Mesh *19x8.5 front(ET40)* *19x9.5 rear(ET30)*
      09-30-2009, 04:14 PM   #46
E92-Lighting
E92-Lighting's Avatar
860
Drives: Next Generation LED Lighting
it depends if you have halogen headlights or xenon headlights
      10-01-2009, 10:12 AM   #47
flymosquera
22
Drives: 328i
hey I think that the e90 with m tech bumper uses the 9006 bulbs..
That is what I read in another forum!
      10-01-2009, 10:15 AM   #48
flymosquera
22
Drives: 328i
Hey I have the xenon lights with the m tech package..
Can you please tell me the bulbs I need for my car please!! b/c i have seen different bulbd so I don't know which ones are they, and I know you sell them so I will guess you will know for sure!!
thanks
      10-01-2009, 10:30 AM   #49
E92-Lighting
860
e90 lci's with mtech bumper
official bulb code list
angel eyes=h8 35W bulb or h8 LED, your pick who you want to use
fog lights=9006 55W, mtec 9006 super white for OE headlight matching
and low beam's aka xenons are D1s, MTEC 6k would also be perfect matching
PS. all fully plug and play
      01-01-2010, 07:10 AM   #50
chewiechewie
chewiechewie's Avatar
Drives: 2010 BMW 335xi
I just bought a 2010 e92 and the manual says that the turn indicators are PY21Ws. Can anyone confirm this?
      01-04-2010, 02:41 PM   #51
Mike@F1 Autohaüs
Mike@F1 Autohaüs's Avatar
195
Drives: ❤
You're referring to the rear turn signals correct?
      07-16-2010, 10:48 PM   #52
hookah66
dirigir é a minha paixão
hookah66's Avatar
Drives: e93 328c N52 3.0L cabriolet
2002 325xi  [0.00]
2009 328i cabriolet  [0.00]
can Bus errors
Originally Posted by kennethpetro View Post
On a side note, i have LED's in the map lights & dome light (Bimmian Hi output LED's) and they're all wacked out. The map light ALWAYS go on correctly but the dome sometime does. When it does and i leave it on for awhile, it just goes out and the floor light LED's go on ?!?!?!?! I've tried the 24 LED from BAVauto but i didn't like the way the light looked through the cover. Any ideas?
This is indicative of canBus errors caused by controller area network in your Bimmer. It has to do with LED resistor values not matching with Bosch controller's values. I got into same issues with my e93 production model of 09/09 which got the same erratic behavior. Either you got to install resistors or buy pre-matched, i.e. "error free" LED bulbs. This is most endemic on Bimmers more than other manufacturers.
A question please....?: the angels eyes on my e93 got are 35 watts H8 bulbs/each. How am I supposed to use the roadway side lighting feature with these behemoths bulbs? My battery will be flat in less than fifteen minutes. On my old '02 e46 parking lights were just small bulbs and day running lights were dimmed high beams.
Sou fanático por conversíveis...
      07-25-2010, 01:25 AM   #53
Robben@ltbmw
118
Drives: E90 Space Grey
2007 328i  [0.00]
Anyone found the rear footwell lights the 74 one? Is it the same as replacing with a T5 LED bulb?
      07-25-2010, 02:48 PM   #54
E92-Lighting
860
74 and T5 are exactly the same bulb type
      07-29-2010, 05:23 PM   #55
Robben@ltbmw
118
2007 328i  [0.00]
thanks! i'll try to see if the T5 will not throw error on the rear footwell lights.
      07-31-2010, 01:13 PM   #56
E92-Lighting
860
My T5 and 74 led bulbs are error free
      07-31-2010, 07:30 PM   #57
Robben@ltbmw
118
2007 328i  [0.00]
haha thanks but.. I was trying to pry the cover for the rear footwell lights and its almost impossible. Can't get it to open, so can't even access the bulbs. >,<
      10-16-2010, 04:07 PM   #58
alberto335
LORD 335
alberto335's Avatar
Mexico
14
Drives: bmw 335 08
really helpfull
--------------------335--------------------------------
      12-09-2010, 11:00 PM   #59
Mrbig
106
Drives: 15 M3
Rear footwell bulb e92 is wat bulb ?
      12-10-2010, 08:17 AM   #60
hookah66
hookah66's Avatar
2002 325xi  [0.00]
if it is the same as in e93, then your best bet is to retrofit it with a Luxer1 (http://store.ijdmtoy.com). You got two pea size bulbs each side, but you need only one Luxer1, which would be the same set up for the front visor vanity lighting. If you are referring to the light at the bottom of the door, then it is a standard type 194 wedge. Contrary to what others have said, these locations are not influenced by canBus errors. Mainly you got to watch out for the dome & map lights which will give you a canBus error unless you use the one with built in resistor chip in-series to mimic incandescent bulbs, at least that has been my experience. Just pry it off gently, using a clean thin flat (or wrapped in electric tape to prevent scuffing) screwdriver from its top or bottom side. Once out, take the connector out, and then snap out the back cover. They are tiny, and girls fingers are better suited for this task than ours. I asked my wife who unwillingly agreed to dislodge the pea size bulbs, and snap in the new Luxer1 mini module.
      12-10-2010, 08:29 AM   #61
hookah66
hookah66's Avatar
2002 325xi  [0.00]
Not all type led bulbs are same, even though they all look the same. I put red ones at bottom of the door sills. My best experience has been type 194 wedge lcd's from http://www.hidxenonlights.com I like them cauz they give a slight blueish tint, it is sort of cool.They are pricey, but once installed never had problems. I have been using since 09/09, their led bulbs are not influenced by canBus errors in all locations other than in front (e93) and in center domes for other body models.
      01-08-2011, 01:30 AM   #62
snipersix
snipersix's Avatar
228
Drives: Retired 2017 F87 M2
2017 BMW M2  [0.00]
anybody have the bulb list for the 2011 e92 335 lci?
2017 M2 Coupe:|Black Sapphire Metallic|DCT|Nav/Idrive|M Performance CF Spoiler|M Performance CF DCT Interior| M Performance Gloss Black Kidney Grills| M Performance Steel Pedals | Eventuri CF CAI | 19" Brixton Rims | KW V3 Clubsport |
Retired: |2008 328i Sedan|Montego Blue|
      01-09-2011, 04:42 PM   #63
serge086
Drives: 07 335i coupe
Thanks
      02-06-2011, 05:35 PM   #64
watrob
watrob's Avatar
Australia
140
Drives: MY2022 X5 M-Sport 45e White
HI, All,
I am in the process of changing the cornering front linner light bulbs on my daughters new 2011 m-sport pack 3 series coupe 330d which has xenon lights. The angel eyes are leds & the fogs are H11.
Now on my previous M3 e93 the cornering bulbs were a H3, on removing this bulb from the 330d it says E1 24watts, whats the go? is this european bulb numbering and I always thought they were a H3 35watt bulb anyway?
Has there been a change in the cornering bulb in the 2011 model?
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked.
      02-07-2011, 02:17 PM   #65
Lefty061182
25
Drives: 2024 X5 M60i (Marina/Black)
Originally Posted by watrob View Post
HI, All,
You may come across the testing standards E1 mark. The E1 code denotes that the bulb has been tested in Germany, which is widely regarded within the automotive industry as superior. Should be H3....is that no where on there?
Last edited by Lefty061182; 02-07-2011 at 02:18 PM.. Reason: spelling mistake in my reply
      02-25-2011, 12:50 PM   #66
VWtoBMW
VWtoBMW's Avatar
68
Drives: 2021 X5
Looking for this as well !
2018 540d xDrive Carbon Black Metallic on Cognac leather. Spec'd out to the max
2017 Mercedes C43 AMG Coupe. Black on black
