TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Angel Eye Comparisons
      09-06-2018, 02:17 PM   #1167
LuxAngelEyes
BimmerPost Supporting Vendor
LuxAngelEyes's Avatar
469
Drives: BMW
Originally Posted by JDang View Post
Alright, so I had the Lux H8 180 installed on my E92 2007 Pre-Lci for about 2 months now and so far so good. I just have a question about the installation.
I just swapped it out and put it in the hole and once it seemed secure I moved on to the next. Can you confirm that the outer ring will be more dim compared to the inner ones? Also is there a certain position by from installing the Lux H8 180 where it shines more directly onto the "optic cable"? I am asking is there any difference by rotating the unit slightly then installing it so the LED can shine directly on the optic or no matter how you put it in it will yield the same results due to how it locks in?
There is only 1 way that these can be installed due to the 3 tabs being different sizes. Once in place it will twist a bit and be snug in place from there.
The outer rings will always be a bit dimmer due the physical design of the headlight, but if you step back from the car at least 30 feet they will appear much more even.
      09-25-2018, 10:57 AM   #1168
Steini9494
Iceland
11
Drives: E91 320d LCI
LUX V7 in european LCI (ZKW brand) halogen headlights.
Big cheers to LUX for great service, i didn't read as much as i should have about the bulbs, and ordered the wrong type, they let me send them back and sent me the correct pair free of charge. They light up both rings perfectly, with no blind spots like the old bulbs, and are much, much brighter. 100% recommend these to anyone thinking of upgrading
      01-10-2019, 09:48 AM   #1169
checkr
Drives: E93 320D
Looks amazing - love it.
      04-23-2019, 09:18 AM   #1170
Phyrexia
Resident Pedant
503
Drives: '15 335i 8AT
Wanted to say I installed my V3s in my halogen LCI car last night, and I'm very pleased with the results.
I may look for a whiter headlight bulb to match the rings. Any suggestions?
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+
      04-24-2019, 10:35 AM   #1171
LuxAngelEyes
469
Drives: BMW
many people go with the MTEC 4350k or Philips 4300k halogen bulbs as a replacement. They are a good color match for the LUX E90 LCI Halogen V3
Phyrexia502.50
      05-17-2019, 05:16 PM   #1172
Scythe17
40
Drives: Jet Black 2010 M3 E93 6 Speed
Waiting for LUX to make an RGB Version of the V5, That would be awesome! My car definitely needs some V5's for now though, the stock gold has already lost the g...
      05-20-2019, 12:57 PM   #1173
LuxAngelEyes
469
Drives: BMW
RGB would not be legal so we will not make those. Only white and amber are legal for the front of the cars and that is what we offer.
      08-08-2019, 09:23 PM   #1174
lowcountryone
Drives: BMW 2007 335i coupe
interesting stuff!
      08-18-2019, 06:14 PM   #1175
Sorenn54
Drives: 2008 bmw e92 335i
Sick Halo's
      08-31-2019, 10:04 PM   #1176
mweisdorfer
mweisdorfer's Avatar
1903
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
I had MTEC v4 for many years. I just switched to Lux v7. They are definitely brighter than MTEC v4.
      09-03-2019, 02:23 PM   #1177
LuxAngelEyes
469
Drives: BMW
Thats awesome to hear
      09-03-2019, 03:28 PM   #1178
mweisdorfer
1903
2008 bmw x5  [0.00]
From what I can understand, the Lux v6 & MTECH v4 are equal in terms of brightness.
I have seen several pictures of comparisons of bulbs in the same car where the right bulb was a Lux v6 & the left bulb was an MTECH v4 for example. In those test cases, there was no visible difference that I could tell.
However, when I was able to compare the Lux v7 vs the MTECH v4, the Lux v7 was clearly brighter no question about it.
      11-19-2020, 08:02 AM   #1179
brbsqskp
brbsqskp's Avatar
Drives: Mazda cx5
OSS is best! one day ill get it!!
      12-02-2020, 07:24 PM   #1180
cliffschum
16
Drives: 2006 330
Weisslicht
My Weisslicht angel eyes have started to blink intermittently. Is this the typical failure mode for the bulbs, or, could I have an electrical issue ?
I'm getting the bulb icon light in the instrument panel, also intermittent.
Lux from ECS Tuning is my probable replacement choice. Just want to make sure this is a bulb issue and not something else in the circuit.
Thanks,
Cliff
2006 E90 (early)
      01-20-2021, 09:01 PM   #1181
Jorge Pantalones
Drives: 2006 325xi Panzerwagen
LUX V8 for the win
LUX Version 8's are nice.
One of my OEM bulbs went out on my trusty ol' 2006 E91. I replaced both sides with LUX E90 V8's. Work time was less than thirty minutes, no codes and the warning light went right out. Sorry these pictures aren't great; hopefully you can see the outer ring is the same brightness as the inner one.
Cheers!
      05-04-2021, 12:53 AM   #1182
Hotter
Hotter's Avatar
72
Drives: BMW E92 328i -> 330i
What are the best Angel Eye for E92 to light both rings most equally?
Brightness does not matter too much for me so prefer regular, not too bright LEDs. Any recommendations?
      05-04-2021, 10:45 AM   #1183
LuxAngelEyes
469
Drives: BMW
We have designed our to focus as much light as possible into the outer rings to help make them as even as possible. Please take a look at the link on our signature for information about the LUX H8 lights we offer. Thank you
      05-06-2021, 01:32 PM   #1184
E30alexym
Drives: e90
no one makes yellow angel eyes (to the temperature of the original E92s) for the E90s do they?
      05-07-2021, 10:42 AM   #1185
LuxAngelEyes
469
Drives: BMW
the color of the E90 and E92 angel eyes is the same, they both use halogen bulbs that are 2700k in color.
      06-09-2021, 12:05 PM   #1186
SplitFlex
Drives: 2011 335d Sport
2011 BMW 335D  [0.00]
Thanking about getting the oss, is that still considered the best of the best? considering thats an opinion im going off of brightness and whiteness with the bi-xenon headlights on a 2011 335d.
do we have to send our headlights to them for the install?
      01-07-2023, 09:27 AM   #1187
Hotter
Hotter's Avatar
72
Originally Posted by E93FTW View Post
I have no clue of the brand but I got them for a reallyyyyy good price installed so... Yeah...
Could you take a photo of the bulb? Where did you buy these?
