N52 with Velocity Stacks (throttle body+maf deleted)
11-21-2023, 11:51 PM | #1 |
204
Rep 172
Just got the velocity stack prototype in. Will have it on the dyno hopefully by next week and share some numbers. Sounds pretty cool Filter panel and cold air feed will be added later.
Sound Clip- https://youtube.com/shorts/9-xE2tBTs...sLpZUeqFAz_6Ds
I don't check PM, DM me on Instagram @rai_n52
22RPD Vendor - 2006 330i - N54 Intake Manifold l N54 Throttle Body l Gruppe-M Intake l MILVS l 22RPD E85 Tune l S65 Injectors l HZ Racing Headers l TCKLINE SA Coilovers l M3 Front Arms l VWETISH Diff Brace l 3,91 Differential Last edited by Raimund; 11-22-2023 at 12:07 AM.. |
PhaceN52174.50 Torgus3781.50 The Nightman1090.00 spidertri400.50 rackhenry12.00 colorado.e9x3088.00 chilledn5265.00 4 Doors1169.00 CornerGorillaPit238.50 |
11-22-2023, 12:30 PM | #3 | |
204
Rep 172
It needs to be tuned to drive properly, which will be done on the dyno likely next week. There are two other guys with homemade cut manifolds that 22rpd tuned that are daily driving them for awhile now with no issues. It'll drive good with the tune 🙂 |
11-22-2023, 12:43 PM | #4 |
Rep 13
Raimund,
How did you get these? The ends could be theoretically shrunken down to port match the s54 m3 intake manifold. If someone could make an adapter to fit the n52 throttle body as well, we could run the s54 intake manifold without having to mess around with itb’s and the problems associated with such ie. (mounting, programming etc.). |
johnnyorange58.50 |
11-22-2023, 12:46 PM | #5 | |
2307
Rep 4,169
The issue has always been finding a solution to having the failsafe and not actually making it run. Curious to see what it will put down, I've seen 255+/- but I'm sure it would be more with the MILVS and a better set of headers and exhaust,
Mods: Yes.
11-23-2023, 11:08 AM | #6 | |
204
Rep 172
These are being developed by 22RPD, my car is being used for testing. What you suggested would probably be possible too |
11-23-2023, 11:10 AM | #7 | |
204
Rep 172
I will post results on dyno hopefully next week |
Torgus3781.50 |
11-23-2023, 12:32 PM | #8 | |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
I wonder if you could fab something like these up for the filter vs using one large filter over all of the ITBs: vs. Shame to hide the ITBs! But if you want a 'cold' air feed not many options. edit: Are you going to play around with different lengths of trumpets etc inside the box?
Raimund204.00 |
11-24-2023, 02:37 AM | #9 | |
175
Rep 189
I don't think the OP is particullary concerned about that if he modified that way his engine, if his valvetronic will fail hell'shut off the engine as he said and repair it The engine start button should cut off the fuel pump as well, doesn't it? Cool build and awesome sound, keep us updated |
Raimund204.00 |
11-24-2023, 08:19 AM | #10 |
3060
Rep 3,913
It'll just sit on the rev limiter if the valvetronic fails...until it's shut off by pressing the start/stop button as usual. Not ideal, but hardly an issue since he knows what might happen and what to do about it. I'd far prefer that over the prospect of a diesel runaway, that's for sure!
11-26-2023, 06:52 PM | #11 | |
204
Rep 172
Hey Torgus!
I attached of photo of the design for a filter panel. Individual ones could be made too, or run socks, but they would make less power. I did do a baseline dyno and am keeping everything the same and re-dynoing with the trumpets, and then again with a custom tune for them. I attached the current dyno. Keep in mind this is an automatic transmission car with more drivetrain loss. There is an issue with the exhaust merge placement which you can see that midrange dip from. I'll be redoing the exhaust after we get the velocity stacks dyno. As for playing with runner lengths, we may be testing different lengths, I forget what the consensus was on that. Quote:
22RPD Vendor - 2006 330i - N54 Intake Manifold l N54 Throttle Body l Gruppe-M Intake l MILVS l 22RPD E85 Tune l S65 Injectors l HZ Racing Headers l TCKLINE SA Coilovers l M3 Front Arms l VWETISH Diff Brace l 3,91 Differential |
11-26-2023, 10:14 PM | #12 |
Cometh
1090
Rep 1,308
Drives: Boy's Soul
This is incredible. Brings me so much joy to see our measly N52 with velocity stacks, just like a "real" BMW.
11-27-2023, 06:14 PM | #13 |
23
Rep 46
This looks and sounds great, are you looking at a CSL style carbon intake to go with it ?
Subbed and excited to see where this goes. |
12-13-2023, 12:49 PM | #14 |
401
Rep 467
Drives: 11 128i 6MT Sport
Saw the latest 22RPD clip, sounds incredible!
11 128i slicktop
13 WK2 19 Alltrack S |
01-12-2024, 01:02 PM | #16 |
Rep 3
Just found this and it makes me VERY excited! I have been wanting ITBs on the N52, purely for the sound they make. This is even better since I think Valvetronic is super cool. Does the tune that they are developing run in AlphaN mode? I would think it would have to. Just wondering if it will make dailying the car not feasible.
02-11-2024, 04:50 PM | #17 |
204
Rep 172
Ladies and gentlemen, we did it. Huge Success.
Update videos + dyno + release coming in the next few days. Will be posted on instagram @rai_n52 or @22rpd
02-12-2024, 08:06 PM | #18 |
204
Rep 172
Video demo of the V2 velocity stacks-
https://www.instagram.com/reel/C3Q5K...l5NjI3M3dzYg== |
The Nightman1090.00 |
02-13-2024, 04:21 AM | #21 |
175
Rep 189
