I cloned my MSV70 DME
09-19-2014, 12:10 PM | #45 | |
3973
Rep 7,215
another issue is checksums but I should be able to figure that out pretty easily. pretty sure the 325i file I have is a 3l. eventually I'll get a full dump off our 325xi. |
09-19-2014, 12:20 PM | #46 | |
Combined Applications Group
1061
Rep 680
I guess the OFT guys made sure it is buried or deleted. I believe there was a OBD to USB cable involved and the same programs you mentioned above. Also you mentioned the need to change the check-sums in order for changes to be implemented, do you have access to these once you open the dump files? Thx Hass |
09-19-2014, 01:18 PM | #48 | |
2465
Rep 9,004
09-19-2014, 01:26 PM | #49 |
3973
Rep 7,215
yes but it doesn't go full lift until much later in the RPM curve. look at 100 rf at 2000rpm, 330i is at 9.7mm while 325i is only 5.8.. that's a huge difference. I'm guessing the 330i can go to full lift earlier because of better filling from the 3 stage intake?
09-20-2014, 09:52 AM | #52 |
3973
Rep 7,215
I think thats the rev limiter. Its a "soft" limiter that i think pulls timing, fuel, and i belive vanos. I think that could be tweaked, i much prefer a hard ful cut.. lol
09-20-2014, 11:47 AM | #53 | |
1061
Rep 680
on N/A its not bad but if you mess up a fuel cut style limiter on a turbo car it could go boom |
09-20-2014, 11:57 AM | #54 |
Freight Dawg
104
Rep 2,103
The 325i closes the throttle a bit at high rpm. Cheap way of limiting power to keep off the 330i's toes.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
09-20-2014, 12:19 PM | #55 |
3973
Rep 7,215
I think you could do it if you can disable the spark cut, there's a threshold for RPM above the rev limit for a hard fuel cut. Just set that to zero, perhaps.
09-20-2014, 12:28 PM | #56 |
Freight Dawg
104
Rep 2,103
I was just about to mention this. You can actually hit the hard cut in neutral or first gear. The soft limiter is too slow.
--Marcelo
09-22-2014, 09:57 PM | #60 |
3973
Rep 7,215
it's encrypted so I don't know how you can tell.
also, unfortunately since it's encrypted it means you can't use OFT to flash custom tunes. it really is sort of worthless.. |
09-22-2014, 10:12 PM | #61 |
65
Rep 243
Im not sure what you mean? I can load any .bin file to it and flash it...
As far as the .bin itself, it doesn't appear to be any kind of encrypted. I can view it in TunerPro without a problem. And I can tell you that my Valve Lift map is indeed modified. Last edited by LaCross; 09-22-2014 at 10:18 PM.. |
09-22-2014, 11:34 PM | #64 |
2465
Rep 9,004
Pictures of the valve lift map?
09-23-2014, 09:14 AM | #66 |
2465
Rep 9,004
