05-22-2023, 06:43 PM | #1 |
19
Rep 24
iDrive Control Knob Stuck
Hi all,
My iDrive controller knob is stuck whenever I toggle it to the right. It won’t return to center unless I manually move it back. It works though, just annoying. Has anyone experienced this before? Have you had any luck fixing it without replacing the whole unit? Thank in advance! |
05-23-2023, 08:33 AM | #2 |
4530
Rep 7,584
If the earlier knob (like yours) is like the later knob (slightly larger)...there is an inner plastic ring that cracks and hangs up the movement.
There are threads with images...I'll stop know to search for that info and edit later. EDIT: Here's a link to a thread on replacement of the smaller iDrive controller...it may give some indication of what to check or replace...even though it may be a different platform...the iDrive controller design is the same: https://www.e90post.com/forums/showthread.php?t=1608933 Below is a pic of the broken plastic ring...and here's a link to a thread on the topic (again, I'm not sure if this applies to the smaller iDrive controller or not): https://f10.5post.com/forums/showthread.php?t=1611701
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-23-2023 at 08:40 AM.. |
xidamaaa18.50 TinCanSailor641.00 |
05-23-2023, 04:49 PM | #3 | |
19
Rep 24
01-29-2024, 06:47 PM | #4 | |
Rep 1
