02-11-2012, 08:14 PM | #1 |
108
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
Caliper Bolt - Part Number?
Does anyone know if the below part can be purchased separately? I looked at realoem but can't find the actual part, seems to be as part of the caliper. This is for the front caliper by the way.
I snapped one in two pieces, and I would hate to buy the entire caliper to replace one bolt. Any feedback is appreciated. Thanks
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
02-12-2012, 08:48 AM | #2 |
140
Rep 2,234
actually I need to pick up a set too. was planning on picking up from local dealer.
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
02-12-2012, 10:22 AM | #3 |
108
Rep 1,973
I need to go by tomorrow, hopefully the dealer carries it.
02-12-2012, 11:09 AM | #4 |
Rep 103
No luck
I tried for almost two months to get this bolt from three different dealers and even got in touch with Brembo. They will not sell you this bolt. Apparently this bolt is never to be removed and when removing the brakes you are supposed to remove the caliper and mounting bracket as a whole by removing part #2 in the diagram above. I do however think you could get these bolts at a hardware dealer like Grainger. I will try to take the bolt in soon and let you guys know what I find. I agree that it is much easier to remove the hex bolt than the #2 bolts shown in the diagram. I used to crew for a race team and we always removed the hex bolts instead of the #2 bolts show in the diagram.
02-12-2012, 11:36 AM | #5 |
European Editor
10624
Rep 22,992
Do you know the dimensions of that bolt? Length and thread pitch?
I would try a place that sells metric fasteners like Wurth or Zelenda. Zelenda machine and tools - are one of the largest metric fastener importers for the USA. http://www.zelenda.com/ Most indi repair shops get their nuts and bolts (fasteners) from Wurth. But Wurth will not sell direct, they only sell to repair shops. Or maybe even a mail order parts place like Pelican parts might be able to help you out. http://www.pelicanparts.com/catalog/...th6-detail.htm IF you could find out the size of that bolt... there is a huge metric fastener shop here where I live in BA... I am sure they would have the right bolt for you. Let me know in a PM. Dackel |
02-12-2012, 03:50 PM | #6 | ||
108
Rep 1,973
Thanks for the feedback Quote:
I'll check the dimensions with a Caliper, the thread however will be a tricky one.. thanks again
02-13-2012, 10:31 AM | #7 |
140
Rep 2,234
a quick update I was able to order the hex bolts from a local dealer. the part # is 34116772117. they were $4.95 each
02-13-2012, 10:42 AM | #8 |
106
Rep 2,696
Prob not a bad idea to have a couple of these in the tool box as a spare for us track junkies.
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
02-13-2012, 10:44 AM | #9 |
106
Rep 2,696
Kori,
When I search online it comes back with the description Part Number 34116772117 Part Name Carrier Bolt Back...you sure it's teh right one?
02-13-2012, 10:51 AM | #10 |
140
Rep 2,234
you know I just called the guy back and double checked if these are the two bolts that secures the caliper to the spindle and he said yes. I hope they got it right
02-13-2012, 01:51 PM | #12 | |
European Editor
10624
Rep 22,992
Here it is on RealOEM.com but they don't really have a good picture of the bolt. http://www.realoem.com/bmw/showparts...34&fg=95&hl=10 That bolt is used on A LOT of bmw's... http://www.realoem.com/bmw/partxref.do?part=34116772117 bolt size: M12 X 1,5 X 43 looks like its zinc coated (?) = ZNS3 |
02-13-2012, 02:06 PM | #13 |
140
Rep 2,234
we'll find out on wednesday. they had to order it
02-13-2012, 02:37 PM | #14 |
108
Rep 1,973
I visited a local dealer, and they told me they dont' sell that bolt.. #2 on that diagram is a different animal all together; but hopefully you have the right part..
02-15-2012, 03:35 PM | #15 |
140
Rep 2,234
reporting back in about the bolts. as had been mentioned earlier the bolts are not sold. this is just ridiculous! I am thinking of not loosening those bolts anymore to get to the pads. I have removed those bolts so many times over the last two years that I am sure they must be stressed by now. we should try to find replacements somehow! how can we make replacements? any ideas?
02-15-2012, 03:45 PM | #16 |
106
Rep 2,696
Makes no sense they wouldn't have those replacement bolts...so dumb
02-15-2012, 04:04 PM | #17 |
117
Rep 1,998
im trying an ave that may not pan out... but i will let you guys know tomorrow. too late today on the east coast .
regards..
X1, R58 JCW, M2 in my future if planets align
02-15-2012, 04:27 PM | #18 | |
108
Rep 1,973
thread width length and this has to be available somewhere..
02-15-2012, 07:24 PM | #19 |
140
Rep 2,234
I have faith in Drivehard. we should be able to find a suitable replacement
02-16-2012, 10:15 AM | #20 |
37
Rep 2,084
02-16-2012, 10:37 AM | #22 |
140
Rep 2,234
yeah I am torquing at 70 lbs/in but those bolts can easily be snapped. at this point breaking a bolt is a very expensive proposition
