      04-20-2024, 03:47 PM   #1
bender128
bender128's Avatar
41
Drives: BMW 128i Coupe
2011 128i  [0.00]
F30 front grey caliper upgrade part numbers
Hey everyone, if someone that has done this upgrade could provide the part numbers for the front rotors and pads I'd greatly appreciate it.
I got the front grey brembos off an f30 and want to be 100% sure i order the right rotors and pads the first time to avoid restocking fees.
I checked the sticky but it didn't have part numbers.
Car is a 128i. Thanks in advance.
      04-22-2024, 04:28 PM   #2
rackhenry
rackhenry's Avatar
14
Drives: BMW 128, Porsche Cayman
Hi Bender, im doing the same upgrade, I would suggest you actually validate the caliper part number you have to be sure, I have the following calipers which are the grey 4 Piston brembos. Assuming they are the same ones you have, you can then go to any of the racing pad sites, such as porterfield and validate your pads that way. Or go to Real oem etc.
Calipers. Left and right
34116865538
34116865537
Real OEM URL ---
https://www.realoem.com/bmw/enUS/sho...diagId=34_2349
2011 128i
2011 Cayman
2007 Cayman S -Sold - no regrets
2007 Exige - Sold - Double Dang it!!
1990 M3 - Sold - Dang it!
      04-22-2024, 04:34 PM   #3
rackhenry
rackhenry's Avatar
14
Again please check for yourself, but I went to real oem and input the caliper part numbers and got this part number for the pad. Also you will notice that when you go to Porterfield and input any of the vehicles the calipers come on, there are a lot of cars that use the 4 piston brembos. The pad dimensions should be 113mm long
If you need me to measure my internal dimensions of my caliper or send you pics shoot me a DM. Happy to help.
Pad PN --- 34106878878
2011 128i
2011 Cayman
      04-22-2024, 09:23 PM   #4
bender128
bender128's Avatar
41
2011 128i  [0.00]
Thanks rackhenry , where do you see the part number on the caliper? I only see 20 A 788 03 / 20 A 788 02
They are the 4 piston brembos but very curious where you found the part numbers for the calipers.
      04-22-2024, 09:49 PM   #5
rackhenry
rackhenry's Avatar
14
Hi Bender,
I did not find the number on the calipers themselves. I did a bunch of research on Real OEM.
Once I got the part number I thought was correct, I used a part number search on Ebay to order the calipers. For example If I put the number in ebay the caliper I have shows up. You can also try posting the part numbers on the calipers themselves on Ebay or just a Google and the right calipers also show up.
Oh and this post is probably worth reading as well.
https://f30.bimmerpost.com/forums/sh....php?t=1590916
I just checked my calipers btw, my left caliper, 20 A788.03 and the other half 20 A787.04. Hope that helps. ( I assume your calipers have a number on each caliper half? Also there is another number on my caliper on the outside it is 340 P440
2011 128i
2011 Cayman
      04-23-2024, 06:11 AM   #6
bender128
bender128's Avatar
41
2011 128i  [0.00]
That's very helpful, thanks a lot.
      04-23-2024, 06:51 AM   #7
bender128
bender128's Avatar
41
2011 128i  [0.00]
I read somewhere that 340 is the rotor size so I guess only thing to measure is that pad is 113mm. Thanks again for your time!
      04-23-2024, 06:53 AM   #8
bender128
bender128's Avatar
41
2011 128i  [0.00]
I will double check but do you also have the rotor pn?
      04-23-2024, 07:32 PM   #9
bender128
bender128's Avatar
41
2011 128i  [0.00]
For reference, found this, has all part numbers, just scroll down to F30 section
https://www.bimmerworld.com/About-Us...-Sport-Brakes/
Almuliman511.50
      04-23-2024, 08:52 PM   #10
bender128
bender128's Avatar
41
2011 128i  [0.00]
Ordered, will update if there are issues with fitment
      04-24-2024, 09:36 AM   #11
rackhenry
rackhenry's Avatar
14
Thanks for the part numbers, I had not ordered the rotors yet
2011 128i
2011 Cayman
      04-24-2024, 10:00 AM   #12
rackhenry
rackhenry's Avatar
14
When I was researching the caliper upgrade, I had realized we are fortunate in that BMW used the same rotor on many cars! The rotor prices are very reasonable!
2011 128i
2011 Cayman
      05-05-2024, 08:37 PM   #13
bender128
bender128's Avatar
41
2011 128i  [0.00]
Everything fit perfectly! Took it for a drive and so far so good.
      05-06-2024, 09:07 AM   #14
bender128
bender128's Avatar
41
2011 128i  [0.00]
To summarize, these were the part numbers that worked with the gray f30 brembo calipers on a 128i:
Rotors: 34116792223
Pads: 34106878878
      05-06-2024, 09:11 AM   #15
bender128
bender128's Avatar
41
2011 128i  [0.00]
this is how they look behind 18 inch apex wheels
This is how they look behind 18 inch apex wheels
WrathOTM553.00
      05-07-2024, 09:29 AM   #16
rackhenry
rackhenry's Avatar
14
Did you use inpa to bleed the brakes. or just pedal bleed?
2011 128i
2011 Cayman
      05-09-2024, 12:21 PM   #17
bender128
bender128's Avatar
41
2011 128i  [0.00]
I used a motive brake bleeder
1addicts
