      10-23-2023, 09:06 AM   #1
bender128
bender128's Avatar
41
Drives: BMW 128i Coupe
2011 128i  [0.00]
Looking for 128i alignment specs for track
I am getting a set of Vorshlag camber plates installed in 2 weeks and looking for alignment specs people are running for track use. Car is 128i on Bilstein b14 coilovers.
Saw this recommendation from amg6975 - "As much front camber as you can get, and about a degree less in the rear. zero toe in the front, very slightly in in the rear."
Please let me know what you are running/suggesting I should run.
      10-23-2023, 09:07 AM   #2
bender128
bender128's Avatar
41
2011 128i  [0.00]
quote taken from here: https://www.1addicts.com/forums/show...rack+alignment
      10-26-2023, 10:16 AM   #3
Brian_
11
Drives: '11 128i, '18 VW Golf
2011 BMW 128i  [0.00]
That's a pretty solid plan, wouldn't get too wrapped up in exact precise #s to chase.
You'll definitely want all the camber you can get up front with the slightly softer spring rates on the b14s.
If the car is a dual duty daily driver that sees a lot of highway miles then a small amount of toe in up front can make it easier to live with between track days and you won't really miss the difference in turn-in as a novice. But the tramlining isn't too bad on mine with 0* toe up front.
houtan707.00
      10-26-2023, 11:17 AM   #4
spidertri
spidertri's Avatar
405
Drives: 11 128i 6MT Sport
Amg's recommendation is spot on, that's what I run on my car.
11 128i slicktop
13 WK2
19 Alltrack S
Appreciate 4
houtan707.00
Brian_10.50
mkeiser471.00
      10-27-2023, 08:30 AM   #5
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Agree with amg as well. Although I can’t do more camber in the rear to make the difference 1 degree front to rear. Tires start to rub the frame in the rear if I add too much camber. Here is my last alignment. Was great on track and around town.
Appreciate 2
      02-28-2024, 12:14 PM   #6
bender128
bender128's Avatar
41
2011 128i  [0.00]
I forgot about this thread, so back when I got them installed I ended up getting -2.7 front and -2.4 back, which it looks like is against the recommendations in this thread.
I just started this thread as well but I guess you answered my question
https://www.1addicts.com/forums/show....php?t=2085912
I'll revisit and get rear neg camber dialed down to -1.7
thanks all!
      04-22-2024, 08:17 AM   #7
bender128
bender128's Avatar
41
2011 128i  [0.00]
Updating the thread, never went in to get realigned but issue went away.
Maybe tires just needed to be driven a bit after being stored for 6 months.
I'll still get the rear camber dialed to 1.7 once i need alignment for m3 arms which i will inevitably install.
Thanks for the valuable input everyone!
Appreciate 2
1addicts
