      06-28-2017, 12:25 PM   #89
d k
47
Drives: BMWless for few weeks
So whats the consensus then?
Is it worth going with the M3 arms or mod stock ones?
      09-04-2017, 05:46 PM   #90
AndyW
Supreme Galactic Commander (one galaxy over...)
AndyW's Avatar
675
Drives: '08 E93, '12 E82, '13 E93 M3
What I get from the thread is that there is little gain in technical suspension performance going from OE to M3 bits in the back, unlike the pretty much universally agreed upon gains from the front OE to M3 bits mod. But there should be no harm.
Best,
Andy
'12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune
      09-04-2017, 10:02 PM   #91
WhatsADSM
228
Drives: 2011 135i
Yup. The front stuff is worth it to go M3.
Things get a little more complicated in the back. In the rear the upper guide arm is worth it.
The upper camber arm doesn't really do much except reduce a few hundred grams (and obviously looks better). The trailing arm is the same already.
The toe arm bushings in the rear have a ton of compliance in them and should be replaced, however the M3 ones are NOT a bolt on replacement. Most people use Megan toe arm replacements in the back, there are also some sphericals as well like the bimmerworld or rouge engineering arms, if you are willing to go solid.
Appreciate 3
AndyW674.50
Dackelone10632.50
bchalks31.50
      09-08-2017, 07:36 PM   #92
AndyW
AndyW's Avatar
675
These? http://www.ebay.com/itm/Megan-Racing...19.m1438.l2649
Best,
Andy
      09-09-2017, 04:05 PM   #93
WhatsADSM
228
Drives: 2011 135i
Yup those are the ones. They are actually pretty nice quality. I think I actually ordered mine from the same guy on eBay.
AndyW674.50
      09-09-2017, 07:39 PM   #94
AndyW
AndyW's Avatar
675
I am always tempted by the "make offer" option...
Best,
Andy
      06-04-2018, 07:10 AM   #95
Yangorang
67
Drives: 2008 BMW 328xi
Is the lower camber arm completely incompatible between the M3 and non-M? It looks like the bushings are the same but the wheel carrier / hub are very different. The shock bolts in differently as well.
https://www.ecstuning.com/b-genuine-...h/33326772899/
https://www.ecstuning.com/b-genuine-...t/33322283885/
      06-04-2018, 10:05 AM   #96
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2336
Drives: 2013 128i LMB 6MT ZMP Slicktop
2013 128i  [9.58]
The camber arms are a direct swap, though you'll have to use different shocks. The TC Kline SA rear shocks I used are the same as listed for the E46 with the addition of some aluminum spacers for the lower bolt.
Inertia is the enemy!
My car's photo history: https://www.1addicts.com/forums/show....php?t=1570551
      06-04-2018, 11:43 AM   #97
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
You will also need to make a bracket for the head light level sensor, if you have one, on the driver side.
      06-04-2018, 01:36 PM   #98
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
Drives: E82 Mutt, M57 Truck
Have you detailed this anywhere?
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      06-04-2018, 05:27 PM   #99
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2336
2013 128i  [9.58]
I posted a photo with part numbers superimposed. I'm not anywhere convenient to search for it at the moment, though.
ShocknAwe3238.50
      06-04-2018, 05:55 PM   #100
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
Definitely shoot me details when you have a moment, might be the missing link for my rear end work.
      06-05-2018, 08:01 AM   #101
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2336
2013 128i  [9.58]
Here you go.
lab_rat394.50
      06-05-2018, 08:19 AM   #102
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
Here you go.
Thanks.
Questions:
Stock nonM subframe? What toe arm did you use? Why the E46 damper instead of the 1M/M3 damper?
      06-05-2018, 08:29 AM   #103
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Thanks.
Questions:
When you order the 1m SA rear shock, TC sends the E46 part with the spacers for the lower mounting point, so I am assuming it is the same for the 1m and E46.
KEY NOTE IN HIS PICTURE ABOVE: you see he could not use the upper powerflex bushing. This is the issue I had when I ordered the single action 1m rear shock. I could not get the nut to thread using the stock or Dinan bushings. Once TC confirmed the DA 1M shock had a longer threaded shaft, I swapped them out. A lot of wasted time trying to get the SA to work and I had to spend more money, but it worked out in the end because I love the DA rear shock.
I have stock subframe, m3 LCA, and am using the bimmerworld toe arm for a non M e82. The only piece that is custom I believe is the little headlight level sensor bracket that mounts to the LCA. HPA makes one, but it only comes with their LCA kit.
      06-05-2018, 09:57 AM   #104
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2336
2013 128i  [9.58]
Thanks.
Questions:
Yes, stock subframe. Stock toe arms work, too, though I have the Rogue bits. I didn't look into the 1M/M3 shaocks as I wanted the Konis, but I'm sure they're a drop in.
      06-05-2018, 10:03 AM   #105
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
Sorry was referring to the E46 SA damper. Is it the same as the 1M SA?
      06-05-2018, 10:39 AM   #106
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2336
2013 128i  [9.58]
The Misumi washers I used for the upper shock mounts came to $23.79 shipped. Not too bad. I couldn't justify an extra $500 for the DAs as I was only going for a "fast road" build.
The Misumi washers are a Shore 90, ether based polyurethane. Currently $8.19 each and ship in 7 days.
      06-05-2018, 10:40 AM   #107
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2336
2013 128i  [9.58]
Yes.
      06-05-2018, 10:54 AM   #108
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
Fantastic. Thank you for working out how to install the shorter shaft Mtype SA damper.
Looks like HPA sells the level sensor bracket a-la-carte now for ~$50. Is there any reason to buy their lower camber link kit? The OE 1M/M3 link is cheaper.
Think the Misumi washer can be installed with the remaining pieces of the Dinan RSM?
      06-05-2018, 11:24 AM   #109
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2336
2013 128i  [9.58]
Don't know, TBH.
      06-05-2018, 11:27 AM   #110
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2336
2013 128i  [9.58]
As much as Iike HPA it was far less expensive to order from TheBMWPartStore.
1addicts
