      02-16-2016, 09:34 PM   #331
froop
froop's Avatar
171
Drives: 08 AW 6MT E82
Originally Posted by Dynamic1 View Post
My 08 135i is at 92k miles and the rotors and pads were done (although the sensor still hadn't gone off)... so I took a look at my calipers and everything was in order. I'm all about some spirited driving (3 years in Germany to boot), and I'm surprised the original pads and rotors lasted this long. Sorry I didn't get more/better pics.
Spirited driving and track driving are quite different. Unless you're threshold braking corner after corner on the street, the heat generated is going to be a lot less.
The calipers on my car are about 30,000kms old and at least 60% of the dust boots are completely shot. The pistons themselves look in fine condition though. I'm using upgraded pads, ECS 2-piece rotors, Ti shims and no dust shields. In those 30,000kms over 3 years I've done maybe 10 or so circuit days.
      02-17-2016, 06:01 AM   #332
Dynamic1
Dynamic1's Avatar
Drives: 2008 135i
2008 135i  [10.00]
Right - I get that it's different... I saw somewhere in the thread a request for comparison to high milage calipers, so I was just sharing what I saw.
      02-18-2016, 08:28 PM   #333
froop
froop's Avatar
171
Ahhh ok.
Yeah I have an E88 135i with 148,000kms and the dust caps and pistons on those were fine. I've tracked it maybe 2-3 times but using stock brake pads but nothing like how I've tracked the E82. The E82 also has a lot more power and better pads so will generate a lot more heat.
      07-09-2018, 05:04 AM   #334
SamN
Drives: 2012 135i M-Sport, Man
Backing plate for brake cooling
By way of comparison, this is what a race-specific cooling plate looks like. I run these on my Spec3 race car. Notice the flange is angled slightly towards front and that air is directed to center of hub/rotor to force flow into and through cooling veins.
http://www.bimmerworld.com/BrakeCool...es_E36__WM.jpg
Better yet, e82 specific part:
http://www.bimmerworld.com/E9X-E8X-N...ate-Right.html
      06-21-2021, 05:14 PM   #335
Fortugs
Drives: 2008 BMW 135i M sport
I bought an 08 135i with 88,000kms a month ago. Brakes became very noisy last few weeks. Pulled brakes apart to inspect/service- still had around 5mm pad front and rear. Came to find the caliper pistons are all badly corroded to the point they are crumbling apart. Have never seen this before on any vehicle ever. Been a technician for 10yrs. Any explanations?
      06-21-2021, 06:45 PM   #336
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
Possible the car was tracked? Those ceramic pistons are known to crumble under heavy load: https://www.1addicts.com/forums/showthread.php?t=221203
EDIT** Just noticed I linked back to this same thread... oops
      06-22-2021, 03:56 PM   #337
Thunderguts
Thunderguts's Avatar
829
Drives: 2009 128i Sport MT
There are a couple different aluminum piston upgrades. The ceramic ones don't hold up to high heat, or so I'm told.
Official BMWP Whore - BMWP suspension kit w/ M3 arms, BMWP big brake kit, BMWP intake w/Mishimoto tube, BMWP exhaust, BMWP carbon strut brace, BMWP short shifter, and BMWP carbon spoiler. OZ Leggera HLT w/ 245 square setup.
      06-24-2021, 07:42 PM   #338
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
Drives: E82 Mutt, M57 Truck
This. The brakes are quite good and durable once shims and metal pistons are done. Remove the "ears" and switch to true 2pc floating rotors and they're not even that heavy.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      06-25-2021, 08:04 AM   #339
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2336
Drives: 2013 128i LMB 6MT ZMP Slicktop
2013 128i  [9.58]
Ears are f'ing 1.4 pounds per corner!
Inertia is the enemy!
My car's photo history: https://www.1addicts.com/forums/show....php?t=1570551
      06-25-2021, 10:13 AM   #340
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
Indeed. And serve no detectable purpose that I can feel.
      06-25-2021, 10:19 AM   #341
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2336
2013 128i  [9.58]
Probably to mitigate brake squeal.
      06-25-2021, 11:28 AM   #342
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
The horror
      06-25-2021, 03:16 PM   #343
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2336
2013 128i  [9.58]
The horror
I know, right?
Brake harder and shorter and the brake squeal goes away, anyway.
      10-31-2021, 04:54 PM   #344
08SlowE82
08SlowE82's Avatar
53
Drives: 08 e82 128i
It's good practice to clean your calipers after every race weekend. Especially around the pistons. Simple green works well using a small nylon brush similar to a tooth brush. And rinse throughly with water, dry with micro fiber. What happens is the piston get jammed up with brake dust and prevents them from retracting smoothly or fully which can cause dragging on the rotor and excessive heat. We do this in motorcycle racing at the end of every day during a race weekend and it makes a big difference. Cheers 🍻
      02-27-2023, 11:24 AM   #345
Thunderguts
829
Originally Posted by LordBabington View Post
I dunno. But I seem to have started having brake issue too. Each time I press it there is a nasty squeaking sound from inside the wheel part. Can't figure out what it is.
Did you use stop squeak on the shims? Sometimes I use it and sometimes I don't. I haven't noticed a huge difference even if I don't.
Check your rotors for scoring. Sometimes a small pebble or other debris can get wedged in the pad and cause all kinds of noises and damage to the rotor.
1addicts
