E90 335i - 2FDB fuel high press
06-23-2019, 04:19 PM | #1 |
24
Rep 190
Morning All, been a while since I have been on here, just looking for some quick advice. Car has just ticked over 91,000km. On the weekend, I barely drive the car now, I got a cel. I was accelerating past the a typical 95% (can’t drive or help themselves in life) hit about 4000rpm and the car started studdering. Stopped at the lights and got a rough idle. Accelerated gently from one set of lights to the next and idle was smooth again. I remembered I recently had an O2 cel, it they Are less than 5k old, so I cleared it and thought it must be that.
Parked the car for 30, drove home and now it studders really bad ( no power) at 4000rpm approx. I plugged in my MHd code reader and have a misfire on cylinder 5 and got the subject code. Also a degraded O2 sensor. I am not a mechanic, but I did some reading and nothing was conclusive. Question to the wise ones, I am guessing either HPFP replacement time or fuel sensor on the rail? FCP euro would be my friend here still...correct? Thanks all...
BMW 335i October 2007 Build. VR Speed down pipes, heat coated by HiOctane, BMS DCI, MHD Stage 2, Index 12 Injectors, Eldor Coils. RB Outlets & Inlets installed. Wagner Evo 2 Comp installed, Charge pipe with Tial BOV installed. Stage 2 lpfp installed. Motiv ethanol sensor and flex fuel installed. MHD v8 stage 2+ e50 map installed.
06-24-2019, 08:51 PM | #2 | |
899
Rep 6,285
How old is your hpfp? Seems like that could be the culprit |
Montye9023.50 |
06-26-2019, 06:05 PM | #3 | |
374
Rep 1,392
Montye9023.50 |
07-06-2019, 08:56 PM | #4 |
24
Rep 190
No long cranks. New O2 sensor fixed it, so far...
Installed Motiv ethanol sensor and flex box. Having fun getting MHD monitoring to analyse the ethanol content %... not sure if anyone else has done this yet?
07-06-2019, 09:00 PM | #5 |
24
Rep 190
Thanks Coupes, less than 5000km brand new index 12 injectors have been installed. Interesting enough, after installing the e50 map, that’s where the detonation was occurring. Also have less than 5000km elder coils as well as spark plugs...
12-05-2023, 07:43 AM | #6 |
Rep 72
Drives: BMW 335i
Which was the relation between the O2 sensor and HPFP shadow code?
