Question: Octane and Dinan
05-18-2008, 12:15 PM | #1 |
95
Rep 2,573
Drives: AW DCT M3
Is there any benefit to running a higher octane with the Dinan flash. With my previous tune, I was using 100 octane pretty much all the time (full tanks). Since the parameters are set with the flash (I believe) would I see any performance gain (besides draining the wallet) if I were to continue using 100 Octane?
Thanks in advance
05-18-2008, 12:21 PM | #2 |
20
Rep 216
My buddy attorneyscott just filled up with Sunoco 104 oct GTPlus and his butt dyno says it makes more power. He dyno'd it on 104 and got 339rwhp and 370rwtq with Stg. 2 (non-revised) + exhaust. He does not have any baseline on 93. FWIW, our Dinan contacts indicated that the car would in fact produce more power on 100+ oct.
"...here's a word of advice for those who have been saving their lunch money and patiently waiting for the E92 M3 V8 to come to our shores: If you encounter a 335i with a Dinan badge on the trunk, don't throw down for pink slips. This car is so fast in a straight-line drag that you'll have to hitchhike home." Roundel, April 2008 ||08 E92 335i 6MT / Montego Blue / Dinan Stage III, IC, OC, exhaust and Stage 1 Suspension / Morr VS8
05-18-2008, 12:59 PM | #4 |
330
Rep 4,484
All 335i's stock or otherwise, will make more power on higher octane and less on lower.
On a stock car I dyno tested that was on 91 Octane, I got like 4 rwhp more in a matter of minutes of powering in 100 Octane to make a 94 Octane mix. With appropriate adaptation time, I'm sure even the stock car would of picked up a couple more. The question is, unless you are racing regularly, do you feel you need to run around with 100 Octane full time? I know you did it with your PROcede because you put the levels to 100%. Personally, I'd do a 50/50 mix of 100 and 91 at most for everyday driving, then if headed to a track run that down low ahead of time and go 100% 100 Octane. I don't see why you'd feel a real need to even put in more than a gallon or two of 100 Octane per fill up for everyday driving, as a tuned 335i is faster than 97-98% of the cars out there even on straight 91 Octane. To spend $40-50 more per fill up to have an extra 8-10 rwhp in everyday driving is expensive. But unless you feel you need it since the Dinan tune seems to put out similiar torque to PROcede v1.4x down low in the rpm range, but a decent amount less horsepower than PROcede v2 above 4000 rpm and especially above 6000 rpm. Save your money, just put in a bit of the good stuff with each fill up to counteract our crappy 91 Octane gas if you feel you need it. BTW, has anybody made a major claim to Dinan yet? Since a Dinan tune still voids the BMW powertrain warranty and I've heard Dinan has been shady in the past paying larger warranty claims. Wonder how they will handle their first ($1000+) warranty claim (or a major $3000+ claim) on a Dinan flashed 335i?? |
05-18-2008, 02:12 PM | #5 | |
95
Rep 2,573
Drives: AW DCT M3
05-18-2008, 02:13 PM | #6 | |
95
Rep 2,573
Drives: AW DCT M3
I agree Michael..... I dont plan on always running full tanks as I used to...
thanks guys, Quote:
05-18-2008, 02:39 PM | #8 |
95
Rep 2,573
Drives: AW DCT M3
Even though i said it up above that I wont, I'm sure I'll still continue to do so...even if it is only a mental thing. ha ha
