BIMMERPOST Universal Forums General BMW News and Cars Discussion
      03-01-2024, 06:25 AM   #1
purewalk
Drives: BMW Z4 M40i
Coolant bleeding electric pump not starting
My Z4 M40i has had the intercooler/radiator changed after sustaining some damage following accident repair. The garage is trying to bleed the system, but cannot get the electric pumps to activate. tried the sequence of:
1. Ignition on.
2. Headlight on manually.
3. Fan on minimum.
4. Heat on full.
5. Hazards on.
6. Holding accelerator down for 15 seconds.
Followed the instructions from the video below but pump is not starting bleed process. Where are we going wrong?
      03-05-2024, 08:09 PM   #2
fe7565
fe7565's Avatar
553
Drives: 2012 BMW 328i N26
What kind of garage is this? Don't they have ISTA+ as an option to do a bleed routine?
Is the car in "eco-pro" mode? Move to "comfort".
https://f30.bimmerpost.com/forums/sh...93&postcount=5
From that link:
"The electric pump is very quiet and sounds a little like varying tones like what you'd hear during an ear test. Make sure your radio/music is off so you can hear the pump running.
The battery needs to be on a full charge, or connected to a wall charger because the process won't start if the battery voltage is too low.
Don't open/close windows/doors/etc.
Push the ignition switch without pressing the clutch (accessory mode).
Left the headlight switch in "auto" (no hazard lights).
Left the driving experience mode in "comfort" (switch is NOT in the ECO PRO switch position).
Turn off the auto climate control (important!), and adjust the heating to maximum temperature (28C) and adjust the fan to the lowest level.
Floor the accelerator pedal and hold for 10 s.
The automatic cooling system bleeding routine will be initiated. The electric coolant pump is enabled.
The engine will NOT start.
Process lasts for 8-12 minutes and when finished the tones will stop and the car will be VERY quiet. No notices on dash or screen before/during/after.
The engine bay can be open/closed (doesn't matter), and the coolant container caps can be open during the procedure to verify fluid circulating or to top up."
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
