European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      06-29-2015, 01:33 PM   #1
MasterC17
329
Drives: 2015 BMW M3
Official F8X Track Alignment Specifications
Wanted to start a thread to get everyone's track alignment specs. Here's mine.
Front Camber: -3.0 degrees
Rear Camber: -1.5 degrees
Front Toe: 0 degrees
Rear Toe: 4mm toe in
Corner Weights (w/ 130lb driver):
LF: 991
RF: 991
LR: 903
RR: 903
50.00% Cross Weight
3788 lbs total
Suspension:
KW HAS on EDC
TCKline Camber Plates
20mm/10mm spacers
275/295 Yoko Neova AD08R
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
      06-29-2015, 02:03 PM   #2
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
Great thread idea!
What do you think about adding the parts used to achieve the alignment as well?
      06-29-2015, 03:27 PM   #3
MasterC17
329
Drives: 2015 BMW M3
Originally Posted by nicknaz View Post
Great thread idea!
Good point, edited.
      06-29-2015, 11:05 PM   #4
MaynardZed
MaynardZed's Avatar
1231
Drives: wife crazy
Front camber: -1.2
Front toe: 1/16 total toe out
Rear camber: -1.5
Rear toe: 3/8 total toe in (.375)
Suspension: stock
MasterC17: what does 4mm toe in mean? .04? Also, you've motivated me to finally start a road course laptime thread. Would you post up your WGI time once I have it up.
      06-30-2015, 08:10 AM   #5
MasterC17
329
Drives: 2015 BMW M3
Originally Posted by MaynardZed View Post
Front camber: -1.2
Rear camber: -1.5
Suspension: stock
All done, excellent thread idea! With regards to 4mm, it's equivalent to .157 of an inch, so about 1/7th of a inch.
      06-30-2015, 10:38 PM   #6
heckyeahbro69
heckyeahbro69's Avatar
518
Drives: m3
here is my specs after pss10 install. I played around with the eccentrics a bit and I couldn't get any more rear camber and still get toe to come in. if you want more then 2* camber, you'll need toe arms.
edit: pics didn't upload. I'm trying from my phone, I guess that feature doesn't work?
      06-30-2015, 10:39 PM   #7
heckyeahbro69
518
Drives: m3
front. my camber is off not due to the camber plates, but something else in the suspension. when it was brand new, it was off also.
      06-30-2015, 10:40 PM   #8
heckyeahbro69
518
Drives: m3
rear
      07-01-2015, 12:55 AM   #9
MaynardZed
MaynardZed's Avatar
1231
Drives: wife crazy
Yes, very odd it came with that much negative camber front and rear from factory. Caster was fine? It usually runs about +7 or so. I suppose it's a "good" problem to have, although I'd add a little more rear toe in.
      07-01-2015, 06:47 AM   #10
heckyeahbro69
518
Drives: m3
No, it does have camber plates, but even before they were installed, the camber was off side to side in the front. It's only slightly, but not being perfect kind of bugs me. Oh well. Converting minutes to degrees, its 2.9* and 3.0*. The minutes measurement makes it look worse. I could try more rear toe but I don't think I'll see track time again with the car before I sell it.
      07-01-2015, 07:23 AM   #11
MasterC17
329
Drives: 2015 BMW M3
Weird, mine is basically dead even side to side with camber plates.
      08-27-2015, 03:16 PM   #12
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
realigned car yesterday to change toe, and tires. Will report back after tracking with this setup. Previous setup from the factory was close to 0 rear toe and I didn't prefer that, since I felt the car would oversteer on throttle too easily.
Front Camber: -1.2 degrees
Rear Camber: -1.2 degrees
Rear Toe: 0 degrees 20 minutes total toe in (appx 4mm)
stock passive suspension, 265/40/18 and 275/40/18 RE-11 tires
Bon F80127.00
      08-28-2015, 06:17 AM   #13
CanAutM3
General
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
LF: 991
RF: 991
LR: 903
RR: 903
50.00% Cross Weight
3788 lbs total
Suspension:
KW HAS on EDC
20mm/10mm spacers
You were able to get an exact side-to-side match of your front camber with the TCK plates?
We're you just lucky, or there is some sort of additional adjustment?
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      08-28-2015, 12:36 PM   #14
AM4ZING
AM4ZING's Avatar
1205
Drives: M4 MW/SO 6MT, E46 M3 AW/IR 6MT
2004 BMW M3  [0.00]
2015 BMW M4  [0.00]
Would anyone be able to give ballpark specs(range to be in) for proper alignment during aggressive canyon road driving?
MILA | E46 BMW M3 | AW/IR | 6MT | KW V3 | CSL | Vorsteiner |
EMILY | F82 BMW M4 | MW/SO | 6MT | M Carbon Ceramic Brakes | M Performance Exhaust |
      08-28-2015, 02:23 PM   #15
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
For a stock car, I think what I posted above would be ok for that. It is all within the OEM recommended range, except for the rear toe (I have put more rear toe in)
Might be worth it to get more negative camber in the rear, maybe -1.5 to -1.8 range, but I didn't want to change too many things at once so I kept my current -1.2 setting
      08-30-2015, 07:41 PM   #16
MasterC17
329
Drives: 2015 BMW M3
Guess I was just lucky, no additional adjustments made.
      11-01-2016, 08:49 AM   #17
JMon
FAST
JMon's Avatar
371
Drives: Porsche GT3 Cup
Bringing up this old thread... Any newer additions?
      11-04-2016, 01:45 AM   #18
zac5
zac5's Avatar
China
152
Drives: F95 X5M
Front Camber: -3.2 degrees
Rear Camber: -2.0 degrees
Rear Toe: 5mm toe in
Corner Weights (w/ 83kg driver):
LF: 457kg
RF: 444kg
LR: 423kg
RR: 411kg
49.97% Cross Weight
1735 kg total
Suspension:
MCS 2wayNR with true coil rear
WORK MCOracing CS 18X9.5/10.5
265/35,285/35 Hankook TD
"Learn the rules like a pro, so you can break them like an artist."
      11-04-2016, 08:21 PM   #19
SD ///M4
///Multiple
SD ///M4's Avatar
2992
Drives: M4 Coupe | M3 | Z4M Roadster
Did this last week prior to a weekend HPDE at Buttonwillow:
Front Camber: -2.5 degrees
Corner Weights w/185 lb. driver):
LF: 1018
RF: 996
LR: 904
RR: 882
Total Weight: 3800 lbs.
Cross Weight: 1900 lbs. 50%
Suspension:
Ground Control camber plates
Dinan Coilover (HAS) suspension kit
Nitto NT01, 275/35 front, 305/35 rear
Apex EC-7, 18x10 ET24 front, 18x11 ET44 rear
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18
The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
      11-05-2016, 01:59 AM   #20
Shmelgy
B.E.
Shmelgy's Avatar
444
Drives: F80 M3 & 1969 Mustang Fastback
Front: -2.9 degrees camber
Rear: -2.3 degrees camber
Front has 0 toe but I forgot what the amount of toe in is for rear.
Suspension: KW Clubsport 2-way
19" FI-R with 265/35 and 305/30 Toyo R888
Current: 2022 TRX & 2010 GT3RS
Past: 2016 M3 Individual Grigio Telesto Pearl, Sakhir Orange/Black Full Leather w/ CF trim, 6MT, ZCP, CCB, etc...
Previous: 2011 E92 M3 Melbourne Red on Black 6MT ZCP. --> now 2010 dedicated track car
ferrarif1320.00
      12-01-2016, 03:15 PM   #21
JMon
FAST
JMon's Avatar
371
Dinan Tension Arm Bearings
Ground Control Camber Plates on EDC
RE71-R
Just had the work done by the dealer
On the street, the car drifts slightly right (4 seconds to leave the lane)
and seems a little darty at highway cruising speeds.
Going to take it back and see what is up. I don't know if it is because of so much camber or because of so little toe?
      12-01-2016, 03:59 PM   #22
YMB_M3
YMB_M3's Avatar
227
Drives: 2018 BSM M3 6MT
RE71-R
If your tires are wider than stock you could be experiencing tram lining which would explain the dartiness
f80post
